| » How to replace relay board? |
Model Number: rsd30 Brand: Dacor Age: 5 - 10 years
All the functions in my dual fuel oven still works, but intermittently it beeps and show an F1 code. Resetting or turning off the circuit breaker stops the problem for a few minutes, and as long as a day. The keypad control, timer, etc. all function as they should.
I am ready to replace the relay board 105C (your part AP3880742), but would like to know where it is located, and the most logical way to access it, without taking the entire stove apart. Is it under the cook top, behind the control panel, behind the grille, which is located between the control panel and the top of the oven? I have tried to find a diagram of this stove but have been unsuccessful. A step by step instruction would obviously be most welcome, but some general guidance would be equally appreciated. Thank you. Marc |
With an F1 failure code the ERC (Electronic Range Control) is picking up a command to supply heat without receiving an input from the key pad.
In such situation the ERC has to be replaced, not the relay board. The job could be done from the front. - The part number for the ERC AP3390975 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Gene, Thank you very much.
Do you think that cleaning and trying it, before replacing would be a waste of time? On computers, removing a board, dusting it, cleaning the contacts and re-inserting it, often seems to do the job. Would it work on a stove? Marc. |
I don't think so but you can try.
__________________
| Display Modes | |
| Can I replace the motor control board? | Homerepairbob | Washer Repair | 1 | 11-24-2007 07:10 PM |
| Thermador built in oven - relay board | meganluk | Oven Repair (including Ranges and Cooktops) | 0 | 11-21-2007 06:21 PM |
| How can I check the relay and/or cap | frepair | Refrigerator & Freezer Repair | 1 | 10-18-2007 08:37 PM |
| How to replace retaining clip and cover over relay/capacitor of the compressor | kouklos | Refrigerator & Freezer Repair | 0 | 10-18-2007 11:27 AM |
| Starter relay | tv guy | Refrigerator & Freezer Repair | 0 | 08-10-2007 02:08 PM |
