Discuss
Magic Chef/Matag 30" gas gange
 in
Hello, Thanks in advance for your help. As of today the oven will not work as there is no gas
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Magic Chef/Matag 30" gas gange
  #1 (permalink)
Old 08-28-2011, 12:47 PM
Junior Member
joebif is on a distinguished road
Default Magic Chef/Matag 30" gas gange
Model Number: 31211SSA   Brand: Magic Chef   Age: 5 - 10 years
Hello,
Thanks in advance for your help. As of today the oven will not work as there is no gas going to the burner. The igniter appears to be working fine, but the gas valve is not opening to allow the gas to flow into the burner. Again your help would be most appreciated. Also will I be able to check for your answer, or answers later?
Thank you,
Joe B
Ads By Google
Related Models
Magic Chef 31211WAA Range - F/s Std Gas
Magic Chef 31211WAM Range - F/s Std Gas
Magic Chef 31211WAV Range - F/s Std Gas
Magic Chef 31211WAW Range - F/s Std Gas
Magic Chef 31211XAA Range - F/s Std Gas
Magic Chef 31211XAS Range - F/s Std Gas
Magic Chef 31211XAT
Magic Chef 31211XAW Range - F/s Std Gas
Magic Chef 31213SAA Range - F/s Std Gas
Magic Chef 31213SAW Range - F/s Std Gas
Magic Chef 31213WAA Range - F/s Std Gas
Magic Chef 31213WAM Range - F/s Std Gas
Magic Chef 31213WAQ
Magic Chef 31213WAV Range - F/s Std Gas
Magic Chef 31213WAW Range - F/s Std Gas
Magic Chef 31213XAA Range - F/s Std Gas
Magic Chef 31213XAT
Magic Chef 31213XAW Range - F/s Std Gas
Magic Chef 3121SPA Range - F/s Std Gas
Magic Chef 3121SPL
Magic Chef 3121SPW Range - F/s Std Gas
Magic Chef 3121SRA Range - F/s Std Gas
Magic Chef 3121SRW Range - F/s Std Gas
Magic Chef 3121STA Range - F/s Std Gas
Magic Chef 3121STW Range - F/s Std Gas
Magic Chef 3121WPA Range - F/s Std Gas
Magic Chef 3121WPL
Magic Chef 3121WPV Range - F/s Std Gas
Magic Chef 3121WPW Range - F/s Std Gas
Magic Chef 3121WRA Range - F/s Std Gas
Magic Chef 3121WRV Range - F/s Std Gas
Magic Chef 3121WRW Range - F/s Std Gas
Magic Chef 3121WTA Range - F/s Std Gas
Magic Chef 3121WTV Range - F/s Std Gas
Magic Chef 3121WTW Range - F/s Std Gas
Magic Chef 3121XPA Range - F/s Std Gas
Magic Chef 3121XPL Range - F/s Std Gas
Magic Chef 3121XPS Range - F/s Std Gas
Magic Chef 3121XPW Range - F/s Std Gas
Magic Chef 3121XRA Range - F/s Std Gas
Magic Chef 3121XRA-UX Range - F/s Std Gas
Magic Chef 3121XRA-X Range - F/s Std Gas
Magic Chef 3121XRS Range - F/s Std Gas
Magic Chef 3121XRW Range - F/s Std Gas
Magic Chef 3121XRW-UX Range - F/s Std Gas
Magic Chef 3121XRW-X Range - F/s Std Gas
Magic Chef 3121XTA Range - F/s Std Gas
Magic Chef 3121XTS Range - F/s Std Gas
Magic Chef 3121XTW Range - F/s Std Gas
Magic Chef 3126SRA Range - F/s Std Gas
Magic Chef 3126SRW Range - F/s Std Gas
Magic Chef 3126STA Range - F/s Std Gas
Magic Chef 3126STW Range - F/s Std Gas
Magic Chef 3127STA Range - F/s Std Gas
Magic Chef 3127STW Range - F/s Std Gas
Magic Chef 3127WTA Range - F/s Std Gas
Magic Chef 3127WTV Range - F/s Std Gas
Magic Chef 3127WTW Range - F/s Std Gas
Magic Chef 3127XTA Range - F/s Std Gas
Magic Chef 3127XTW Range - F/s Std Gas
Magic Chef 31311SAA Range - F/s Std Gas
Magic Chef 31311SAW Range - F/s Std Gas
Magic Chef 31311WAA Range - F/s Std Gas
Magic Chef 31311WAW Range - F/s Std Gas
Magic Chef 31315VAM Range - F/s Std Gas
Magic Chef 31315VAV Range - F/s Std Gas
Magic Chef 31315VBM Range - F/s Std Gas
Magic Chef 31315VBV Range - F/s Std Gas
Magic Chef 31315WAM Range - F/s Std Gas
Magic Chef 31315WAV Range - F/s Std Gas
Magic Chef 31315XAA Range - F/s Std Gas
Magic Chef 31315XAW Range - F/s Std Gas
Magic Chef 31315XBA Range - F/s Std Gas
Magic Chef 31315XBW Range - F/s Std Gas
Magic Chef 3141XRA Range - F/s Std Gas
Magic Chef 3141XRW Range - F/s Std Gas
Magic Chef 3141XTA Range - F/s Std Gas
Magic Chef 3141XTW Range - F/s Std Gas
Magic Chef 3147XRA Range - F/s Std Gas
Magic Chef 3147XRA-X Range - F/s Std Gas
Magic Chef 3147XRW Range - F/s Std Gas
Magic Chef 3147XRW-X Range - F/s Std Gas
Magic Chef 3147XTA Range - F/s Std Gas
Magic Chef 3147XTW Range - F/s Std Gas
Magic Chef 3167VTV Range - F/s Std Gas
Magic Chef 3167VTW Range - F/s Std Gas
Magic Chef 3167VUV Range - F/s Std Gas
Magic Chef 3167XRA Range - F/s Std Gas
Magic Chef 3167XRA-X Range - F/s Std Gas
Magic Chef 3167XRW Range - F/s Std Gas
Magic Chef 3167XRW-X Range - F/s Std Gas
Magic Chef 3167XTA Range - F/s Std Gas
Magic Chef 3167XTA-X Range - F/s Std Gas
Magic Chef 3167XTW Range - F/s Std Gas
Magic Chef 3167XTW-X Range - F/s Std Gas
Magic Chef 3167XUA Range - F/s Std Gas
Magic Chef 3167XUA-X Range - F/s Std Gas
Magic Chef 3167XUW Range - F/s Std Gas
Magic Chef 3167XUW-X Range - F/s Std Gas
Magic Chef 3167XYA Range - F/s Std Gas
Magic Chef 3167XYW Range - F/s Std Gas
Magic Chef 3187VRA Range - F/s Std Gas
Magic Chef 3187VRV Range - F/s Std Gas
Magic Chef 3187VTA Range - F/s Std Gas
Magic Chef 3187VTV Range - F/s Std Gas
Magic Chef 3187VUA Range - F/s Std Gas
Magic Chef 3187VUV Range - F/s Std Gas
Magic Chef 3187XRA Range - F/s Std Gas
Magic Chef 3187XRW Range - F/s Std Gas
Magic Chef 3187XTA Range - F/s Std Gas
Magic Chef 3187XTW Range - F/s Std Gas
Magic Chef 3187XUA Range - F/s Std Gas
Magic Chef 3187XUW Range - F/s Std Gas
Magic Chef 31F-8KX-OC Range - F/s Std Gas
Magic Chef 31F6-7K Range - F/s Std Gas
Magic Chef 31FA-1 Range - F/s Std Gas
Magic Chef 31FA-10 Range - F/s Std Gas
Magic Chef 31FA-10-FJ Range - F/s Std Gas
Magic Chef 31FA-10K Range - F/s Std Gas
Magic Chef 31FA-10K-49 Range - F/s Std Gas
  #2 (permalink)
Old 08-29-2011, 11:26 AM
Junior Member
Default Magic Chef/Matag 30" gas range
Of my post of yesterday I forgot to mention that it appears that the problem is in the oven only, as the 4 burners are getting gas OK
Thanks,
Joe B
  #3 (permalink)
Old 08-29-2011, 04:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Joe,
Most likely the problem is a bad (weak) oven igniter. It can be bad even if does glow because it does not draw enough current to open the gas valve.
- The oven igniter Part number: AP4012072
Here are the breakdown diagrams and Replacement parts for MAGIC CHEF 31211SAA RANGE- F/S STD GAS | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #4 (permalink)
Old 09-10-2011, 06:10 AM
Junior Member
Default To Gene & Appliance Parts Pros
Quote:
Originally Posted by Gene View Post
Hi Joe,
Gene,
Sorry it took so long to thank you for your help. You were right on as it was the oven igniter. And thank you Appliance Parts Pros for your help in that you had the exact part that I needed, and at a very considerate price. Your help made it much easier, and less stressful, and financially able to resolve my dilemma.
joebif
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
magic chef oven won"t heat up elaine10 Dishwasher Repair 0 11-23-2010 07:22 AM
Magic Chef Electric Range reeplace 7" element jorrell Oven Repair (including Ranges and Cooktops) 0 04-02-2010 04:29 PM
magic chef oven doesn"t ignite gary robbins Oven Repair (including Ranges and Cooktops) 0 10-29-2009 04:07 PM
Magic Chef Downdraft "popup vent" won't turn on jeffmit Oven Repair (including Ranges and Cooktops) 0 10-25-2009 07:41 PM
Magic Chef. "Click" Help! C-17. Refrigerator & Freezer Repair 4 11-28-2008 10:00 AM
