I have a SS Astagna Spagno by Sky Enterprise SS range hood vent and the halogen light turns on and off by itself. I checked and it is NOT loose.
It started with shutting off if the stove is hot and the lamp has been on for a few minutes and eventually come back on if it has been off for a few minutes to cool down. Now it does not even do that but sometimes comes on in the middle of the night when it is left on.
I called Sky Enterprise and they said that I should call the manufacturer but the only info in the manual was that of Sky.
Someone said that halogen lamps have safety switches to prevent fires in cases of overheating. I do not know how true it is but it makes engineering sense.
I wonder if there are the greener LED conversion kits or bulbs.
Help!!!! I just got this 2-1/2 years ago. I can't afford to get another one.
Thanks,
Geo
