| » Jenn-Air Range Error code FF |
Model Number: SVE47600B Brand: Jenn-Air Age: 5 - 10 years
We started the clean cycle two nights ago and durring the night it started beeping and would not stop.
It woke the teenager up and he could not get it to stop beeping so he turned of the cuircit beaker. In the morning I turned it back on and the fan for cooling the top runs full time and will not stop. the burners work but if we try to use the oven we get a FF code about 2-5 seconds after trying to start the oven. Help! I have looked around the net but have not found a error code FF for Jenn-Air Money is extremly tight so I am trying to fix it myself rather than do without a oven. Ads By Google Related Models
__________________
Tony Wagner |
Replacement parts for JENN-AIR SVE47600B | AppliancePartsPros.com Here is a service manual, should be close to yours http://www.servicematters.com/maytag...s/16010191.pdf FF looks like a temp sensor problem. I think PRB stands for Power Relay Board. Below is info on checking the temperature sensor http://www.applianceaid.com/oven_temp_sensors_help.html
__________________
| Display Modes | |
| Jenn Air Over with F5 error code | jimwhitingtx | Oven Repair (including Ranges and Cooktops) | 0 | 01-16-2010 08:37 AM |
| Jenn-air F1 error code | Curt Geisbush | Oven Repair (including Ranges and Cooktops) | 0 | 03-16-2009 08:09 PM |
| Jenn Air F1 Error Code | noyneksiwel | Oven Repair (including Ranges and Cooktops) | 3 | 11-24-2008 08:45 PM |
| Jenn-Air F5 error code. | rlb1950 | Oven Repair (including Ranges and Cooktops) | 3 | 11-10-2008 12:48 PM |
| Jenn Air range error code F1-8 when hot | JimSimpson | Oven Repair (including Ranges and Cooktops) | 1 | 09-25-2008 09:19 PM |
