Discuss
Kenmore Electric Range clock / oven control panel
 in
Hello, I had a bad clock / oven control unit p/n WB27T10007. On you Kenmore Radiant 30'' Electric Free-Standing
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Electric Range clock / oven control panel
  #1 (permalink)
Old 11-26-2007, 06:28 PM
dezrailer dezrailer is offline
Junior Member
dezrailer is on a distinguished road
Question Kenmore Electric Range clock / oven control panel
Model Number: 911.95975891   Brand: Kenmore   Age: 1 - 5 years
Hello,
I had a bad clock / oven control unit p/n WB27T10007. On you Kenmore Radiant 30'' Electric Free-Standing Range. I ordered an new unit from Sears. I recieved a replacement part p/n WB27T10208. This is suppose to be a replacement for the old part number. It has a different layout on the back for the wiring to plug in. I dont want to install it wrong and have to start over.
I called Sears and asked for help with this, They said i should have recieved a instruction sheet with the new unit. But they dont have a copy. They will try to research this and get back to me in 3-5 days.
This is no help and i dont think they are going to be of any help at all.
Could you please give me some help with this?
Thank You for your help.
Related Models
Kenmore 911.9967710  KENMORE PORTABLE MICROWAVE OVEN
Kenmore 911.9967910  MICROWAVE
Magic Chef 9112VPV Walloven - Std Gas
Magic Chef 9112VUV Walloven - Std Gas
Magic Chef 9112WPA Walloven - Std Gas
Magic Chef 9112WPW Walloven - Std Gas
Magic Chef 9112WUA Walloven - Std Gas
Magic Chef 9112WUT Walloven - Std Gas
Magic Chef 9112WUV Walloven - Std Gas
Magic Chef 9112XPB Walloven - Std Gas
Magic Chef 9112XUB Walloven - Std Gas
Kenmore 9113012990 GAS OVEN
Kenmore 9113012991 24" GAS BUILT-IN OVEN
Kenmore 9113012992 24" GAS BUILT-IN OVEN
Kenmore 91130158590 24" GAS BUILT-IN OVEN
Kenmore 91130168690 24" GAS BUILT-IN OVEN
Kenmore 91130168791 24" GAS BUILT-IN OVEN
Kenmore 91130168792 24" GAS BUILT-IN OVEN
Kenmore 91130168894 GAS BUILT-IN OVEN
Kenmore 91130169690 24"(GAS BUILT-IN OVEN
Kenmore 91130169791 24" GAS BUILT-IN OVEN
Kenmore 91130169792 24" GAS BUILT-IN OVEN
Kenmore 91130169894 GAS BUILT-IN OVEN
Kenmore 9113018892 GAS BUILT-IN OVEN
Kenmore 9113022190 Wall Oven, Gas
Kenmore 9113022191 24" GAS BUILT-IN OVEN
Kenmore 9113022192 24" GAS BUILT-IN OVEN
Kenmore 9113022990 GAS OVEN
Kenmore 9113022991 24" GAS BUILT-IN OVEN
Kenmore 9113022992 24" GAS BUILT-IN OVEN
Kenmore 9113042590 GAS WALL OVENS
Kenmore 9113042591 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042592 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042593 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042990 ERC TOUCH PADS HARD TO PUSH/F2 CODE-GAS WALL OVENS
Kenmore 9113042991 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042992 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113042993 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130465690 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130465791 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130465792 24" GAS BUILT-IN OVEN
Kenmore 91130465893 24" GAS BUILT-IN OVEN
Kenmore 91130465894 GAS BUILT-IN OVEN
Kenmore 91130469690 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130469791 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 91130469792 24" GAS BUILT-IN OVEN
Kenmore 91130469893 24" GAS BUILT-IN OVEN
Kenmore 91130469894 GAS BUILT-IN OVEN
Kenmore 9113118892 GAS BUILT-IN OVEN
Kenmore 9113128812 GAS BUILT-IN OVEN
Kenmore 9113128892 GAS BUILT-IN OVEN
Kenmore 9113138818 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138819 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138890 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138891 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138898 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113138899 EXTENDED DELAYED IGNITION-SELF CLEAN.GAS WALL OVEN
Kenmore 9113302090 36" GAS COUNTER UNIT
Kenmore 9113302190 36" GAS COUNTER UNIT
Kenmore 9113312591 GAS COUNTER UNIT
Kenmore 9113312592 GAS COUNTER UNIT
Kenmore 9113312593 GAS COUNTER UNIT
Kenmore 9113312991 GAS COUNTER UNIT
Kenmore 9113312992 GAS COUNTER UNIT
Kenmore 9113312993 GAS COUNTER UNIT
Kenmore 91133202100 30" GAS COOKTOP
Kenmore 91133202101 30" GAS COOKTOP
Kenmore 91133203100 30" GAS COOKTOP
Kenmore 91133203101 30" GAS COOKTOP
Kenmore 91133204100 30" GAS COOKTOP
Kenmore 91133204101 30" GAS COOKTOP
Kenmore 91133209100 30" GAS COOKTOP
Kenmore 91133209101 30" GAS COOKTOP
Kenmore 91133212100 COOKTOP
Kenmore 91133212101 36" GAS COOKTOP
Kenmore 91133213100 36" GAS COOKTOP
Kenmore 91133213101 36" GAS COOKTOP
Kenmore 91133214100 36" GAS COOKTOP
Kenmore 91133219100 COOKTOP
Kenmore 91133219101 36" GAS COOKTOP
Kenmore 91133255590 RANGE
Kenmore 91133255591 36" GAS COUNTER UNIT
Kenmore 91133255592 36" GAS COUNTER UNIT
Kenmore 91133259590 RANGE
Kenmore 91133259591 36" GAS COUNTER UNIT
Kenmore 91133285091 COOKTOP
Kenmore 91133285890 36" GAS COUNTER UNIT
Kenmore 91133289091 COOKTOP
Kenmore 91133289890 36" GAS COUNTER UNIT
Kenmore 91133355590 RANGE
Kenmore 91133355591 36" GAS COUNTER UNIT
Kenmore 91133355592 36" GAS COUNTER
Kenmore 91133356590 RANGE
Kenmore 91133356591 36" GAS COUNTER UNIT
Kenmore 91133359590 RANGE
Kenmore 91133359591 36" GAS COUNTER UNIT
Kenmore 91133384100 36" GAS COOKTOP
Kenmore 91133384101 36" GAS COOKTOP
Kenmore 91133385100 36" GAS COOKTOP
Kenmore 91133385890 36" GAS COUNTER UNIT
Kenmore 91133386890 36" GAS COUNTER UNIT
Kenmore 91133389100 36" GAS COOKTOP
Kenmore 91133389890 36" GAS COUNTER UNIT
Kenmore 9114012190 ELEC BUILT-IN OVEN
Kenmore 9114012191 ELEC BUILT-IN OVEN
Kenmore 9114012192 24" ELECTRIC BUILT-IN OVEN
Kenmore 9114012193 24" ELECTRIC BUILT-IN OVEN
Kenmore 9114012990 ELEC BUILT-IN OVEN
Kenmore 9114012991 ELEC BUILT-IN OVEN
Kenmore 9114012992 24" ELECTRIC BUILT-IN OVEN
Kenmore 9114012993 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140161690 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140161791 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140161792 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140168792 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140169690 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140169791 24" ELECTRIC BUILT-IN OVEN
Kenmore 91140169792 24" ELECTRIC BUILT-IN OVEN
Kenmore 9114018813 ELECTRIC BUIL-IN OVEN
Kenmore 9114018893 ELECTRIC BUIL-IN OVEN
  #2 (permalink)
Old 11-27-2007, 03:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Unfortunately I'm not able to find the installation instruction for this control board. The part must come with the complete installation instructions and if it's missing, you have to return the part to Sears and get a full credit.
You can buy this part from a different places and AppliancePartsPros.com has it in stock too.
- APP part number for the oven control board AP3423580
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing oven control panel brad Oven Repair (including Ranges and Cooktops) 2 07-14-2008 03:55 PM
Kenmore dishwasher control panel Lori Jane Dishwasher Repair 4 01-30-2008 04:26 AM
Kenmore 30" electric self-cleaning slide in range dennisjane Oven Repair (including Ranges and Cooktops) 0 11-21-2007 03:18 AM
Range/Oven/Clock Don't Work Merlyn Oven Repair (including Ranges and Cooktops) 0 09-22-2007 10:21 PM
electric range/oven clock not working 50fbn Oven Repair (including Ranges and Cooktops) 1 07-21-2007 12:47 AM
