2 Pages<12
#11 Posted : Tuesday, September 30, 2008 5:20:35 PM(UTC)
Every CW orifice turn will decrease amount of gas, coming out of the orifice.
mercedes
#12 Posted : Sunday, October 19, 2008 5:00:27 PM(UTC)
mercedes
I have just purchased new house with no information on this range. The top burneres work fine, the oven stoped operating at any temperature but broil. The ignitior glows bright on broil only, as soon as you turn it to a spec temp, the flame goes out and the glow dies down. Is this a bad board, not sending voltage to ignitor , only sending voltage on the broil position?
thanks
sean
#13 Posted : Sunday, October 19, 2008 10:42:26 PM(UTC)
Hi Sean,
In order to provide most accurate advise we need the complete model number of the range. You can find it behind the bottom drawer.
mercedes
#14 Posted : Tuesday, October 28, 2008 2:07:50 PM(UTC)
mercedes
model number JGBP28BEA1WH Serial number HT213335P
Poss bad lower ignitor?
Thanks, Sean
#15 Posted : Tuesday, October 28, 2008 3:39:29 PM(UTC)
Sean,
Remove the bottom drawer, unplug the igniter wires and check the igniter for continuity. Check for 120VAC to the igniter while the control calls for Bake.
If the igniter is open or there is 120VAC to the igniter then the igniter is bad.
- The part number for the igniter is AP2014008
How do I replace the oven igniter on a GE XL44 Range? (Oven Repair (including Ranges and Cooktops))
by rwbarrett 12/20/2010 8:47:55 AM(UTC)
GE XL44 Range Wont reach target temp (Oven Repair (including Ranges and Cooktops))
by mdm6713@aol.com 12/14/2010 6:28:25 PM(UTC)
2 Pages<12
