Digital display is out, but top burners ok oven and broiler not operating. When the 9 prong conector is moved it is loose, but will light digital panel temporary when it is held to panel (AP2025107) than goes out. Dont know where the problem is, hope you can help...AW:confused:
Here are the parts Replacement parts for GE JSP26GN2 | AppliancePartsPros.comDont know where the problem is I would say you have found the problem. AP2025107 is the relay board, it looks like it has a transformer which probably supplies the low voltage AC to the control board. Unplug the unit and remove the board, try to figure out why the connection is loose. Check the soldering on the back of the board, you may have a bad solder joint or a cracked trail. Check the pins to make sure they have not backed out of the plug and are properly crimped. Also that none of them are deformed. Would not be a bad idea to clean the plug and receptacle on the board with electronics contact cleaner or isopropyl alcohol and a toothbrush, Just make sure all solvent has evaporated before reconnecting. |
THIS FORUM IS DEAD!!!!!!! |
I removed the board, and found the connections were very loose, so I soldered them to the board. Had to use a jumper on a cracked trail. All is operating OK for now..Thanks to your good instuctions AW
