| » Igniter glows bright, but no ignition |
Model Number: 362.75205891 Brand: Kenmore Age: 5 - 10 years
I have a Kenmore oven, model number 362.75205891. The 4 surface burners all light with no problems. The oven will not ignite however. I was going to order a new igniter, but it seems to be working fine. It glows and gets quite hot, but the gas does not seem to be turning on. Is there a heat sensor somewhere that is not detecting that the igniter is working? Or do I really have a igniter problem?
Thanks in advance, Kevin Related Models |
The igniter is most likely still your problem even though it is glowing. If your igniter is round it must pull between 2.5 and 3 amps to open the gas valve. If your igniter is flat it must pull between 3.4 and 3.6 amps to open the gas valve. If you don’t have an amp-meter then I suggest replacing the igniter because it’s your most likely cause. Hope this helps!! For more on gas oven repair visit Gas Oven Repair Guide
| Display Modes | |
| ignitor glows bright orange but no gas to oven, broiler works fine | browndeer | Oven Repair (including Ranges and Cooktops) | 2 | 08-07-2009 07:33 AM |
| gas oven igniter glows orange but won't light | johngi | Oven Repair (including Ranges and Cooktops) | 1 | 06-22-2009 08:33 PM |
| Gas dryer, igniter glows but no flame | alpeters | Dryer Repair | 5 | 04-15-2009 06:07 PM |
| Igniter Glows Replaced Coils Still no Heat | Friar Dryer | Dryer Repair | 1 | 12-05-2008 01:53 PM |
| Igniter glows but no flame. | zab | Dryer Repair | 1 | 08-06-2007 06:55 PM |
