Discuss
F8/F1 Codes and Convection
 in
I accidentally pushed the "Clean" button, then "Cancel" and proceeded to push "Bake" and set the temperature. About 2 minutes
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » F8/F1 Codes and Convection
  #1 (permalink)
Old 04-03-2009, 01:29 PM
Junior Member
kmacklin2 is on a distinguished road
Default F8/F1 Codes and Convection
Model Number: PLEB27T8ACA   Brand: Frigidaire   Age: 5 - 10 years
I accidentally pushed the "Clean" button, then "Cancel" and proceeded to push "Bake" and set the temperature. About 2 minutes later it started beeping and displayed "F8". I cancelled it and about 1-2 minutes later it started again. I cancelled both ovens (as directed in manual) with the same result. We then tried flipping the breaker to see it that would reset it. The "lock" light came on when we turned the power back on and I set the temperature - it flashed F1 after 1-2 minutes. Last attempt was to turn the power off for a longer time. After a few hours, I turned it back on and again got the "lock" light and then "F8".
In addition, about 6 months ago the convection portion of the top oven stopped working. We believe the oven is approximately 7 years old. We would not like to spend more than necessary, but are not sure how involved our problems are and whether we should repair or replace it. We can live without the convection portion depending on the total expense of the repairs. I would appreciate any help you can give me.
Ads By Google
Related Models
Frigidaire PLEB27T8ACA Frigidaire/electric Wall Oven
Frigidaire PLEB27T8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB27T8CCA Frigidaire/electric Wall Oven
Frigidaire PLEB27T8CCB Frigidaire/electric Wall Oven
Frigidaire PLEB27T9DCA Frigidaire/walloven
Frigidaire PLEB27T9DCB Frigidaire/electric Walloven
Frigidaire PLEB27T9DCC Frigidaire/walloven
Frigidaire PLEB27T9FCA Frigidaire/wall Oven
Frigidaire PLEB27T9FCB Frigidaire/walloven
Frigidaire PLEB30M9ECA Frigidaire/wall Oven/microwave Combo
Frigidaire PLEB30M9ECC Frigidaire/wall Oven/microwave
Frigidaire PLEB30M9ECD Frigidaire/walloven - Microwave Combo
Frigidaire PLEB30S8ACA Frigidaire/electric Range
Frigidaire PLEB30S8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB30S8CCA Frigidaire/electric Wall Oven
Frigidaire PLEB30S8CCB Frigidaire/wall Oven
Frigidaire PLEB30S8CCC Frigidaire/wall Oven
Frigidaire PLEB30S9DCA Frigidaire/walloven
Frigidaire PLEB30S9DCB Frigidaire/electric Walloven
Frigidaire PLEB30S9FCA Frigidaire/wall Oven
Frigidaire PLEB30S9FCB Frigidaire/wall Oven
Frigidaire PLEB30T8ACA Frigidaire/electric Wall Oven
Frigidaire PLEB30T8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB30T8CCA Frigidaire/wall Oven
Frigidaire PLEB30T8CCB Frigidaire/electric Wall Oven
Frigidaire PLEB30T9DCA Frigidaire/electric Walloven
Frigidaire PLEB30T9DCB Frigidaire/wall Oven
Frigidaire PLEB30T9DCC Frigidaire/walloven
Frigidaire PLEB30T9FCA Frigidaire/wall Oven
Frigidaire PLEB30T9FCB Frigidaire/walloven
Frigidaire PLEC30S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECC Frigidaire/cooktop
Frigidaire PLEC36S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECC Frigidaire/cooktop
Frigidaire PLEF398ACA Frigidaire/range
Frigidaire PLEF398ACB Frigidaire/electric Range
Frigidaire PLEF398ACC Frigidaire/electric Range
Frigidaire PLEF398CCA Frigidaire/electric Range
Frigidaire PLEF398CCB Frigidaire/electric Range
Frigidaire PLEF398CCC Frigidaire/electric Range
Frigidaire PLEF398CCD Frigidaire/electric Range
Frigidaire PLEF398CCE Frigidaire/electric Range
Frigidaire PLEF398DCA Frigidaire/electric Range
Frigidaire PLEF398DCB Frigidaire/electric Range
Frigidaire PLEF398DCC Frigidaire/electric Range
Frigidaire PLEF398DCD Frigidaire/range
Frigidaire PLEF398DCE Frigidaire/range
Frigidaire PLEF398DCH Frigidaire/range
Frigidaire PLEF398DCJ Frigidaire/electric Range
Frigidaire PLEF489ACA Frigidaire/electric Range
Frigidaire PLEF489ACB Frigidaire/electric Range
Frigidaire PLEF489ACC Frigidaire/electric Range
Frigidaire PLEF489ACD Frigidaire/electric Range
Frigidaire PLEF489CCA Frigidaire/electric Range
Frigidaire PLEF489CCB Frigidaire/electric Range
Frigidaire PLEF489CCC Frigidaire/electric Range
Frigidaire PLEF489CCD Frigidaire/electric Range
Frigidaire PLEF489CCE Frigidaire/electric Range
Frigidaire PLEF489CCF Frigidaire/electric Range
Frigidaire PLEF489CCG Frigidaire/electric Range
Frigidaire PLEFM399DCA Frigidaire/electric Range
Frigidaire PLEFM399DCB Frigidaire/electric Range
Frigidaire PLEFM399DCC Frigidaire/electric Range
Frigidaire PLEFM399DCD Frigidaire/range
Frigidaire PLEFMZ99ECA Frigidaire/range
Frigidaire PLEFMZ99ECC Frigidaire/range
Frigidaire PLEFMZ99ECE Frigidaire/electric Range
Frigidaire PLEFMZ99ECF Frigidaire/electric Range
Frigidaire PLEFMZ99ECG Frigidaire/range
Frigidaire PLEFMZ99ECJ Frigidaire/electric Range
Frigidaire PLEFMZ99ECK Frigidaire/range
Frigidaire PLEFZ398ECA Frigidaire/electric Range
Frigidaire PLEFZ398ECB Frigidaire/electric Range
Frigidaire PLEFZ398ECC Frigidaire/range
Frigidaire PLEFZ398ECD Frigidaire/electric Range
Frigidaire PLEFZ398ECE Frigidaire/range
Frigidaire PLEFZ398ECF Frigidaire/range
Frigidaire PLES389ACA Frigidaire/electric Range
Frigidaire PLES389ACB Frigidaire/electric Range
Frigidaire PLES389ACC Frigidaire/electric Range
Frigidaire PLES389ACD Frigidaire/electric Range
Frigidaire PLES389CCA Frigidaire/electric Range
Frigidaire PLES389CCB Frigidaire/electric Range
Frigidaire PLES389CCC Frigidaire/electric Range
Frigidaire PLES389DCA Frigidaire/electric Range
Frigidaire PLES389DCB Frigidaire/electric Range
Frigidaire PLES389DCC Frigidaire/electric Range
Frigidaire PLES389DCD Frigidaire/electric Range
Frigidaire PLES389DCE Frigidaire/electric Range
Frigidaire PLES389ECB Frigidaire/electric Range
Frigidaire PLES389ECC Frigidaire/electric Range
Frigidaire PLES389ECD Frigidaire/electric Range
Frigidaire PLES389ECE Frigidaire/range
Frigidaire PLES389ECF Frigidaire/electric Range
Frigidaire PLES389ECG Frigidaire/electric Range
Frigidaire PLES389ECH Frigidaire/electric Range
Frigidaire PLES399ECB Frigidaire/electric Range
Frigidaire PLES399ECC Frigidaire/electric Range
Frigidaire PLES399ECD Frigidaire/range
Frigidaire PLES399ECE Frigidaire/electric Range
Frigidaire PLES399ECF Frigidaire/electric Range
Frigidaire PLES399ECG Frigidaire/electric Range
Frigidaire PLEW27S3ECA Frigidaire/warmer Drawer
Frigidaire PLEW27S3FCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3ACA Frigidaire/warmer Drawer
Frigidaire PLEW30S3CCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3DCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3DCB Frigidaire/warmer Drawer
Frigidaire PLEW30S3FCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3FCB Frigidaire/warmer Drawer
Frigidaire PLFU1777DS0 Frigidaire/freezer
Frigidaire PLFU1777DS1 Frigidaire/freezer
Frigidaire PLFU1777DS2 Frigidaire/freezer
Frigidaire PLFU1778ES0 Frigidaire/freezer
Frigidaire PLFU1778ES1 Frigidaire/freezer
Frigidaire PLFU1778ES2 Frigidaire/freezer
Frigidaire PLFU2067DS0 Frigidaire/freezer
Frigidaire PLFU2067DS1 Frigidaire/freezer
  #2 (permalink)
Old 04-04-2009, 01:37 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for FRG PLEB27T8ACA | AppliancePartsPros.com
Here is a wiring diagram
ftp://ftp.electrolux-na.com/ProdInfo.../318046110.pdf
Sounds like the door lock switches are out of sync.
F8 is a door lock issue.
Here is a couple things to try
1. Press and hold the door latch handle in the unlocked position and press Cancel for a few seconds.
2. Push the door interlock switch. Hold for 20 to 30 seconds. Should hear the door latch go to the unlock position. Release the switch. Turn oven to 350 for one minute and see if the error will clear. Also try pushing cancel for a few seconds while holding the door switch closed
Am not sure either of the above will work but worth a try.
Check for loose wires going to and at the door latch switches.
Check the switches with a meter.
On the convection pr4oblem could be the element is shot.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Micro/convection:e 02 No Convection buddyoven Microwave Repair 0 01-20-2010 06:17 PM
No Codes deirpo Oven Repair (including Ranges and Cooktops) 0 11-28-2009 10:43 AM
F codes Harry_Tech Oven Repair (including Ranges and Cooktops) 1 02-10-2009 09:10 PM
Convection fan whitet3260 Oven Repair (including Ranges and Cooktops) 0 02-03-2009 12:53 PM
pf codes Ben Mc Daniel Oven Repair (including Ranges and Cooktops) 1 05-30-2008 06:21 PM
