| » Lower oven lights just quit, won't go on |
Model Number: SECD272 Brand: Thermador Age: 1 - 5 years
This is a dual convection (over/under) setup, and is not quite 2 years old. The bulbs (12v Halogen G4 Base) in the lower oven won't go on. I removed them (using surgical gloves) and tested them for continuity and they show up as OK. I also checked the door switch and it shows current at the slide-on metal crimps, and the switch checks out OK on the continuity as well. I even bought two new bulbs and carefully installed them... still no light. Any ideas or should I just call the repair guys? The upper oven lights up just fine.
| Display Modes | |
| Ge Spacemaker surface lights quit working | flash215 | Microwave Repair | 0 | 01-09-2010 05:46 PM |
| Maytag Gemini Dual Gas Oven Lower oven won't work | edlakes | Microwave Repair | 1 | 06-16-2009 06:48 PM |
| Lower lights won't turn off | mcgillis | Microwave Repair | 0 | 06-03-2009 04:23 PM |
| Lower element won't heat....lights not working | AirTahoe@comcast.net | Oven Repair (including Ranges and Cooktops) | 1 | 11-19-2008 09:43 PM |
| Dacor double oven, lower oven failure | tuckspub | Oven Repair (including Ranges and Cooktops) | 2 | 09-02-2008 09:48 AM |
