| » Gas Oven Burner Will not light |
Model Number: ACS3350 Brand: Amana Age: 1 - 5 years
My oven has been taking a long time to heat up. Now it will not start. Broiler ignites fine. Oven ignitor is brilliant Bright Orange, & has no smell of gas. Tried to light with a Flame to see if igniter was not hot enough to allow ignition, with NO luck.
Reviewed parts listing and not sure if my trouble shooting diagnosis is correct! Valve, gas AP3970480 needs replacement, in that the valve solenoid is not opening to let gas out. Ads By Google Related Models Last edited by Matthew Wakefield : 11-30-2007 at 05:55 AM. |
Most likely the problem with your oven is a bad igniter.
You can learn how the oven igniter works from the one of my previous posts here: Oven won't lite? - The part number for the oven igniter AP172397 The bracket for the igniter you can use from the old one. - Here are the break down diagrams for the Amana range Model ACS3350AB Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Oven burner wont light or takes a long time to light | shadyray | Oven Repair (including Ranges and Cooktops) | 4 | 01-30-2011 08:26 PM |
| Thermador oven burner won't light | rrs | Oven Repair (including Ranges and Cooktops) | 4 | 02-25-2010 06:26 PM |
| Oven burner won't light | kencroz | Oven Repair (including Ranges and Cooktops) | 0 | 11-21-2009 10:52 AM |
| oven burner will not light | rockerjim | Oven Repair (including Ranges and Cooktops) | 0 | 08-09-2009 08:13 AM |
| oven burner won't light | doc | Oven Repair (including Ranges and Cooktops) | 1 | 11-16-2007 02:01 PM |
