Discuss
Upper oven won't heat
 in
I have an older Maytag 24" double wall oven that came with my house when I bought it in '05.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Upper oven won't heat
  #1 (permalink)
Old 08-21-2011, 08:01 AM
Junior Member
HHammer is on a distinguished road
Thumbs down Upper oven won't heat
Model Number: CWE5100AC ??   Brand: Maytag   Age: More than 10 years
I have an older Maytag 24" double wall oven that came with my house when I bought it in '05. It has served me pretty well through that time, though I did have to replace the upper oven bake element once. I moved away for a couple of years and rented out my house and while I was gone the renters seem to have scrubbed the ID plate so hard that the model # is missing now. I say that to clarify the ?? in the model tag above. I can't positivly ID my model anymore but by internet search the CWE5100AC seems like a slightly newer version of what I have.
On to the problem. The upper oven bake element wouldn't come one but the broil element worked so one day (BONEHEAD move alert) I decided to pull the element and test for continuity to see if it had burned out. The problem is that I didn't shut off the breaker first and it seems one of the terminals was a little off the connecter so when I pulled the element out it touched the metal of the oven box and shorted. There were a few sparks and the terminal connector that had stayed in place was a little crispy but no other apparent damage. The breaker didn't trip and the clock stayed on. Well I learned my lesson and shut off the power, pull and tested the element and it works fine. I replaced that terminal end and set everything back up but still no love. Now both the bake and broil elements won't heat up, though the oven is acting like they should. When I switch the oven to either bake or broil and set the temp the fan comes on like it should but the oven heating light doesn't light and the elements don't heat. I pulled the whole thing apart figuring that I fried something and would be able to see what it was to replace it but everything LOOKS fine. the question is what should I be replacing to get my oven back to working? I would rather not but start replacing random parts as that gets expensive.
BTW the lower oven still works fine.
Sorry about the length of this post but wanted to be thorough.
thanks in advance
Ari
Ads By Google
Related Models
Maytag CWE5200ACB Walloven - S/c Ele
Maytag CWE5200ACE Walloven - S/c Ele
Maytag CWE550 Walloven - S/c Ele
Maytag CWE5500ACB Walloven - S/c Ele
Maytag CWE5500ACE Walloven - S/c Ele
Maytag CWE5500BCB Walloven - S/c Ele
Maytag CWE5500BCE Walloven - S/c Ele
Maytag CWE5800ACB Walloven - S/c Ele
Maytag CWE5800ACE Walloven - S/c Ele
Maytag CWE5800ACS Walloven - S/c Ele
Maytag CWE600 Walloven - S/c Ele
Maytag CWE601 Walloven - S/c Ele
Maytag CWE602 Walloven - S/c Ele
Maytag CWE6020ACB Walloven - S/c Ele
Maytag CWE6200ACB Walloven - S/c Ele
Maytag CWE6200ACE Walloven - S/c Ele
Maytag CWE6200ADB Walloven - S/c Ele
Maytag CWE6200ADE Walloven - S/c Ele
Maytag CWE6230ACB Walloven - S/c Ele
Maytag CWE6230ACE Walloven - S/c Ele
Maytag CWE6230ADB Walloven - S/c Ele
Maytag CWE6230ADE Walloven - S/c Ele
Maytag CWE6800ACB Walloven - S/c Ele
Maytag CWE6800ACE Walloven - S/c Ele
Maytag CWE6830ACB Walloven - S/c Ele
Maytag CWE6830ACE Walloven - S/c Ele
Maytag CWE700 Walloven - S/c Ele
Maytag CWE7000ACB Walloven - S/c Ele
Maytag CWE7000ACE Walloven - S/c Ele
Maytag CWE701 Walloven - S/c Ele
Maytag CWE7800ACB Walloven - S/c Ele
Maytag CWE7800ACE Walloven - S/c Ele
Maytag CWE7830ACB Walloven - S/c Ele
Maytag CWE7830ACE Walloven - S/c Ele
Maytag CWE900 Walloven - S/c Ele
Maytag CWE9000ACB Walloven - S/c Ele
Maytag CWE9000ACE Walloven - S/c Ele
Maytag CWE9000BCB Walloven - S/c Ele
Maytag CWE9000BCE Walloven - S/c Ele
Maytag CWE9000BCM Walloven - S/c Ele
Maytag CWE9000BDB Walloven - S/c Ele
Maytag CWE9000BDE Walloven - S/c Ele
Maytag CWE9000CDB Walloven - S/c Ele
Maytag CWE9000CDE Walloven - S/c Ele
Maytag CWE9000DDB Walloven - S/c Ele
Maytag CWE9000DDE Walloven - S/c Ele
Maytag CWE9030BCB Walloven - S/c Ele
Maytag CWE9030BCE Walloven - S/c Ele
Maytag CWE9030BDB Walloven - S/c Ele
Maytag CWE9030BDE Walloven - S/c Ele
Maytag CWE9030DDB Walloven - S/c Ele
Maytag CWE9030DDE Walloven - S/c Ele
Maytag CWE9900 Walloven - S/c Ele
Admiral CWEA100ACB Walloven - Std Ele
White Westinghouse CWEF309ES1 White Westinghouse/electric Range
White Westinghouse CWEF310ES1 White Westinghouse Canada/electric Range
White Westinghouse CWEF310FSA Ww Canada/electric Range
White Westinghouse CWEF311ES1 White Westinghouse/electric Range
White Westinghouse CWEF312ES1 Ww Canada/electric Range
White Westinghouse CWEF312FSA Ww Canada/electric Range
White Westinghouse CWEF312FSB White Westinghouse/range
White Westinghouse CWEF320ES1 Whiet Westinghouse Canada/electric Range
White Westinghouse CWEF322ES1 Ww Canada/electric Range
White Westinghouse CWEF322ES3 W - W Canada/electric Range
White Westinghouse CWEF322ES4 Ww Canada/electric Range
White Westinghouse CWEF322ES5 Ww Canada/electric Range
White Westinghouse CWEF355ES1 White Westinghouse/electric Range
Maytag CWG300 Walloven - Std Gas
Maytag CWG301 Walloven - Std Gas
Maytag CWG302 Walloven - Std Gas
Maytag CWG3020AAB Walloven - Std Gas
Maytag CWG3020AAE Walloven - Std Gas
Maytag CWG3020BAB Walloven - Std Gas
Maytag CWG3020BAE Walloven - Std Gas
Maytag CWG3100AAB Walloven - Std Gas
Maytag CWG3100AAE Walloven - Std Gas
Maytag CWG3100AAS Walloven - Std Gas
Maytag CWG3100AAW Walloven - Std Gas
Maytag CWG351 Walloven - Std Gas
Maytag CWG3510AAB Walloven - Std Gas
Maytag CWG3510BAB Walloven - Std Gas
Maytag CWG3600AAB Walloven - Std Gas
Maytag CWG3600AAE Walloven - Std Gas
Maytag CWG3600AAQ Walloven - Std Gas
Maytag CWG3600AAS Walloven - Std Gas
Maytag CWG400 Walloven - Std Gas
Maytag CWG401 Walloven - Std Gas
Maytag CWG402 Walloven - Cont Clean Gas
Maytag CWG4020AAB Walloven - Cont Clean Gas
Maytag CWG4020BAB Walloven - Cont Clean Gas
Maytag CWG4100AAB Walloven - Std Gas
Maytag CWG450 Walloven - Std Gas
Maytag CWG451 Walloven - Cont Clean Gas
Maytag CWG4510AAB Walloven - Cont Clean Gas
Maytag CWG4510BAB Walloven - Cont Clean Gas
Maytag CWG4600AAB Walloven - Std Gas
Admiral CWGA200AAB Walloven - Cont Clean Gas
Admiral CWGA800AAB Walloven - S/c Gas
Admiral CWGA800AAE Walloven - S/c Gas
Whirlpool CWI1701W0
Whirlpool CWI1701W1
Whirlpool CWI2101W0
Whirlpool CWI2101W1
Frigidaire CWS3600AS0 Fs Washer - Frig/best Buy
Frigidaire CWS3600AS1 Frigidaire/washer
Frigidaire CWS445RGS0 Gib(v0) / Free Standing Washer
Frigidaire CWS445RGS1 Gib(v0) / Free Standing Washer
Maytag CX8670RB Surface Unit - Ele
Maytag CX8670RV Surface Unit - Ele
Maytag CX8670TB Surface Unit - Ele
Maytag CX8670TV Surface Unit - Ele
Maytag CX9875VVV Walloven - S/c Ele
Maytag CX9875VYV Walloven - S/c Ele
Maytag CX9875XYB Walloven - S/c Ele
Whirlpool CXA1300W0
Whirlpool CXA1300W1
Whirlpool CXA1300W2
Whirlpool CXA1300W3
Whirlpool CXA1300W4
Whirlpool CXA1300W5
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bosch shx55m no heat and no upper arm spin williemon Dishwasher Repair 6 05-11-2011 06:43 PM
upper oven doesnt heat adcre175 Oven Repair (including Ranges and Cooktops) 0 11-02-2010 06:55 PM
upper oven doesnt heat adcre175 Oven Repair (including Ranges and Cooktops) 0 11-02-2010 06:51 PM
Maytag Electric Wall Oven upper bake element won't heat Keithmcelroy Oven Repair (including Ranges and Cooktops) 0 09-06-2009 09:52 AM
Viking electric upper oven doesn't heat semojim Oven Repair (including Ranges and Cooktops) 1 11-28-2008 02:16 PM
