| » Oven Turns On All By Itself!!! |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: JGBS23BEA2WH Brand: GE Age: 5 - 10 years
Hello, I Have A Possessed Stove. I Have A 2nd Hand Stove And When The Electric/gas Were Connected, The Oven Energized The Ignighter, The Gas Valve Opened And The Over Burner Ignited And Began To Run Although The Knob Was In The "off" Position. I Was Able To Turn It Off By Turning The Knob On/off, Listening To The "clicks" Of The Microswitch In The Knob Assembly. The Oven Will Energize Quit Regularly And Will Heat For A Bit And Then Turn Itself Off WHILE THE OVEN KNOW IS IN THE "OFF" POSITION. It Is Obviously A Problem. I'm Looking For Suggestions. I Don't Know If It Is The Thermastate Assebly Or The Gas Valve Or Something Else. I Thank U For Ur Support.
Most likely the problem is a bad thermostat and to fix it the thermostat has to be replaced.
- The part number for the oven thermostat AP2623073 - Here are the break down diagrams for the GE range Model JGBS23BEA2WH Gene.
__________________
Professional appliance repair services in Orange County, California. |
Quote:
THANK U SIR, I KINDA THOUGHT THAT AND B4 I MADE THE INVESTMENT INTO "PROBABLY" THE POSSESSED PART I JUST WANTED 2 C WAT ANY1 ELSE MIGHT HAVE THOUGHT. IM GONNA GIVE IT A TRY AND I WILL LET U KNOW HOW IT TURNED OUT IN A COUPLE OF DAYS!!! |
| Display Modes | |
| Dishwasher turns on and off | slangzang | Dishwasher Repair | 1 | 11-11-2007 04:19 PM |
| Dryer turns on,continues to run | lagerman1 | Dryer Repair | 3 | 10-26-2007 02:44 PM |
| Dryer Squeaks When Drum Turns | Ruben1 | Dryer Repair | 2 | 10-10-2007 07:31 PM |
| Something hitting the drum when it turns | janjan | Washer Repair | 2 | 10-05-2007 03:49 PM |
| Only 1 fan speed / Unit turns itself off | KenK | Heating, Ventilation, and Air Conditioning (HVAC) | 0 | 08-09-2007 08:25 AM |
