Here's what's happening: I turn the oven knob on and I hear clicking and smell gas but see no sparks coming from the oven ignitor. If however I turn on a burner ignitor at the same time I turn on the oven knob, the oven ignitor does spark! If I plug the oven ignitor into the spot for a burner ignitor on the control module and turn on a burner, the oven ignitor works fine too. Doesn't seem to be a problem with the oven ignitor. I even replaced the oven ignitor, and it sparked the first few times but haven't had any luck getting it to spark (without the burner ignitors being on too) since. What in the world is the problem here? Seems to be some sort of charge build-up issue, from my limited electrical knowledge.
Very appreciative of any help!
