Discuss
oven doesn't heat up
 in
Whenever I turn on my top oven on bake, the temperature light indicator flashes on and immediately off again. When
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven doesn't heat up
  #1 (permalink)
Old 11-25-2007, 01:32 PM
Junior Member
Saskia is on a distinguished road
Question oven doesn't heat up
Model Number: RK777g   Brand: Hotpoint   Age: More than 10 years
Whenever I turn on my top oven on bake, the temperature light indicator flashes on and immediately off again. When I turn it on broil, the temperature light stays on. However, in both settings the oven heats up slightly, and then stops heating up. I tried replacing the bake element, but that didn;t help. Does anybody has any suggestions?
Ads By Google
Related Models
General Electric RK777G*D1 Electric range
General Electric RK777G*D2 Electric range
General Electric RK777G*J1 Electric range
General Electric RK777G*J2 Electric range
General Electric RK777G*J3 Electric range
General Electric RK777G*J4 Electric range
General Electric RK777G*J5 Electric range
General Electric RK777G*J6 Electric range
General Electric RK777G*M1 Electric range
General Electric RK777G*T7 Electric range
General Electric RK777G*T8 Electric range
General Electric RK777G*T9 Electric range
General Electric RK955G*01 Electric range
General Electric RK955G*D1 Electric range
General Electric RK959G*01 Electric range
General Electric RK959G*D1 Electric range
General Electric RK960G*01 Electric range
General Electric RK960G*02 Electric range
General Electric RK960G*03 Electric range
General Electric RK961G*01 Electric range
General Electric RK961G*J1 Electric range
General Electric RK961G*J2 Electric range
General Electric RK961G*J3 Electric range
General Electric RK962G*K1 Electric range
General Electric RK962G*K2 Electric range
General Electric RK962G*K3 Electric range
General Electric RK964GP1 Electric range
General Electric RK964GP2BG Electric range
General Electric RK964GP3BG Electric range
General Electric RK966G*06 Electric range
General Electric RK966G*07 Electric range
General Electric RK966G*08 Electric range
General Electric RK966G*09 Electric range
General Electric RK966G*10 Electric range
General Electric RK966G*11 Electric range
General Electric RK966G*12 Electric range
Amana RKD394 WALLOVEN- STD MWAVE ELE
Amana RKD395 WALLOVEN- STD MWAVE ELE
Amana RKS-396 RANGE- S/C S/I DDRAFT GAS
Amana RKS394 WALLOVEN- STD MWAVE ELE
Amana RKS395 WALLOVEN- STD MWAVE ELE
Amana RKT-396 RANGE- S/C S/I DDRAFT GAS
Amana RL-3 RANGE- S/C S/I DDRAFT GAS
Amana RL-3 MWAVE- CNTRTP / STAND ALONE
Amana RL322T MWAVE- CNTRTP / STAND ALONE
Amana RL322T1 MWAVE- CNTRTP / STAND ALONE
Amana RL358P MWAVE- CNTRTP / STAND ALONE
Amana RL53 MWAVE- CNTRTP / STAND ALONE
Amana RL53A MWAVE- CNTRTP / STAND ALONE
Amana RL55 MWAVE- CNTRTP / STAND ALONE
Amana RL55A MWAVE- CNTRTP / STAND ALONE
Amana RL59 MWAVE- CNTRTP / STAND ALONE
Amana RL59A MWAVE- CNTRTP / STAND ALONE
Amana RL6-10 RANGE- S/C S/I DDRAFT GAS
Amana RL6-10 MWAVE- CNTRTP / STAND ALONE
Amana RL6-1020 MWAVE- CNTRTP / STAND ALONE
Amana RL6-1020ET MWAVE- CNTRTP / STAND ALONE
Amana RL6-10ET RANGE- S/C S/I DDRAFT GAS
Amana RL6-10ET MWAVE- CNTRTP / STAND ALONE
Amana RL6-5 RANGE- S/C S/I DDRAFT GAS
Amana RL6-5ET RANGE- S/C S/I DDRAFT GAS
Amana RL6-920 MWAVE - FAMILY SIZE (60 HZ)
Amana RL635T MWAVE- CNTRTP / STAND ALONE
Amana RLA112 RANGE- S/C S/I DDRAFT GAS
Amana RLA312 RANGE- S/C S/I DDRAFT GAS
Amana RLA313 RANGE- S/I STD GAS
Amana RLA314 RANGE- S/C S/I DDRAFT GAS
Amana RLA315 RANGE- S/I STD GAS
Amana RLA319 RANGE- S/C S/I DDRAFT GAS
Amana RLA335 RANGE- S/I STD GAS
Amana RLA339 RANGE- S/I STD GAS
Amana RLA353 RANGE- S/C S/I DDRAFT GAS
Amana RLA393 RANGE- S/I STD GAS
Amana RLA395 RANGE- S/C S/I DDRAFT GAS
Amana RLA612 RANGE- S/C S/I DDRAFT GAS
Amana RLA668 RANGE- S/C S/I DDRAFT GAS
Amana RLD112 RANGE- S/I STD GAS
Amana RLD312 RANGE- S/I STD GAS
Amana RLD313 RANGE- S/I STD GAS
Amana RLD335 RANGE- S/I STD GAS
Amana RLD339 RANGE- S/I STD GAS
Amana RLD340 RANGE- S/I STD GAS
Amana RLD341 RANGE- S/I STD GAS
Amana RLD345 RANGE- S/I STD GAS
Amana RLD346 RANGE- S/I STD GAS
Amana RLD351 RANGE- S/I STD GAS
Amana RLD352 RANGE- S/I STD GAS
Amana RLD353 RANGE- S/I STD GAS
Amana RLD354 RANGE- S/I STD GAS
Amana RLD356 RANGE- S/I STD GAS
Amana RLD357 RANGE- S/I STD GAS
Amana RLD358 RANGE- S/I STD GAS
Amana RLD359 RANGE- S/I STD GAS
Amana RLD364 RANGE- S/I STD GAS
Amana RLD369 RANGE- S/I STD GAS
Amana RLD379 RANGE- S/I STD GAS
Amana RLD395 RANGE- S/I STD GAS
Amana RLD640 RANGE- S/I STD GAS
Amana RLD661 RANGE- S/I STD GAS
Amana RLD664 RANGE- S/I STD GAS
Amana RLD666 RANGE- S/I STD GAS
Amana RLD669 RANGE- S/I STD GAS
Amana RLD679 RANGE- S/C S/I DDRAFT GAS
Amana RLN330UW RANGE- S/I STD GAS
  #2 (permalink)
Old 11-26-2007, 01:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would check are the knobs for the oven thermostat and the selector switch.
The knob consists of two pieces: the outer part with the temperature settings (or mode marks on the selector switch knob) and the central piece which goes on the shaft.
If the outer piece got dislodged, then it's very easy to put it back in the wrong position (180 degrees around).
If it happened then the dial reading does not match the real setting.
If this is the issue, assemble the knob in the right way and, using couple drops of a Crazy Glue, attach both pieces together.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-26-2007, 09:46 PM
Junior Member
Default
Thank you, Gene.
Unfortunately, this wasn't the problem, the knobs are configured just fine.
  #4 (permalink)
Old 11-26-2007, 09:48 PM
Junior Member
Default
Thank you Gene
  #5 (permalink)
Old 11-26-2007, 10:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Turn off the circuit breaker for the oven, open the control panel and inspect all wires to the oven thermostat and the oven selector switch for burned wires.
If this is not the issue, look for the envelope with the wiring diagram inside the control compartment and check for continuity the selector switch and the oven thermostat according the wiring diagram.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
Oven/clock Control Panel is no longer lit but oven does heat. jthomas@abrakadoodle.com Oven Repair (including Ranges and Cooktops) 1 12-05-2009 04:07 PM
Oven broiler and burners work - oven will not heat fatbuford Oven Repair (including Ranges and Cooktops) 0 11-27-2009 05:50 AM
Caloric double oven/bottom oven doesn't heat kj0505 Oven Repair (including Ranges and Cooktops) 1 12-10-2008 09:14 AM
Bosch 27" Dbl oven Powering on but no heat either oven badace Oven Repair (including Ranges and Cooktops) 0 12-02-2007 09:56 AM
