Discuss
Kenmore Electric Oven no Bake or Broil
 in
Kenmore Electric range Model # 790.91062601 It has no bake or broil function, all else works. Have done some troubleshooting,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Electric Oven no Bake or Broil
  #1 (permalink)
Old 08-17-2011, 09:53 AM
Junior Member
bcsman is on a distinguished road
Default Kenmore Electric Oven no Bake or Broil
Brand: Kenmore   Age: 1 - 5 years
It has no bake or broil function, all else works. Have done some troubleshooting, here's what I've checked:
1) 230VAC at L1 & L2 on control unit
2) 1100 ohms on oven probe leads
3) 120VAC to ground on each lead for the bake and broil elements
4) 0 VAC across the leads for the bake and broil elements
5) 18 ohms across the leads of the bake and broil elements
6) infinity from each bake element to ground
7) 19 mega ohms from each broil element to ground
when I put to either bake or broil the control clicks once then clicks again, waits a few moments then repeats.
I appear to need the control panel from what I've gathered but does the broil element also seem bad with the 19 M ohm reading to ground?? Thanks!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Electric Range: No Heat From Bake Or Broil Element john7 Oven Repair (including Ranges and Cooktops) 5 11-30-2012 03:35 AM
Electric Oven wont bake, broil, or clean utnuc Oven Repair (including Ranges and Cooktops) 16 08-20-2011 05:56 PM
Sears Kenmore oven won't heat on bake or broil wingnut9999 Oven Repair (including Ranges and Cooktops) 5 12-30-2010 09:20 PM
top electric wall oven won't heat (bake or broil) kenoven Oven Repair (including Ranges and Cooktops) 0 12-30-2009 07:33 AM
GE Electric Double Wall Oven won't bake or broil tjp Oven Repair (including Ranges and Cooktops) 1 01-21-2009 07:15 AM
