| » Amana Stove won't light. |
Model Number: ARG7301L Brand: Amana Age: 5 - 10 years
We have an Amana stove, Model ARG7301L, Serial 9703247854, MFG P1143315N L. The range works, the broiler works, however, the stove only works sometimes.
When I turn the stove on, I hear ticking, however, the gas does not turn on. If you remove the bottom drawer and hit where the gas valve is located, this makes the gas turn on and the stove heats up. When it reaches temperature, the gas will shut off, however, it may or may not heat back up when it cools below the requested temperature. When this happens, I wait about three minutes, and when the gas does not turn on, I tap the gas valve again and the gas turns on and the stove heats back up. If I do not tap the gas valve, the stove will cool all the way down. There are times, however, when the stove works when turned on, but it may not turn on after it reaches temperature and the gas turns off. I guessed that the problem lies with the gas valve. I bought a gas valve for it yesterday from your agency, installed it today, and the problem still exists. We are not sure what to do at this point. Oh, there were not installation directions with the gas valve. There were red tabs on the new part. Were these to be removed before installation? I'm guessing no, since the stove works, however, the problem still exists. Any suggestions would be helpful! Ads By Google Related Models |
| Display Modes | |
| Glass for amana stove | vincentgrnm | Oven Repair (including Ranges and Cooktops) | 0 | 07-21-2010 07:15 PM |
| Amana stove igniter | Heybhai | Oven Repair (including Ranges and Cooktops) | 0 | 07-04-2010 11:01 AM |
| Electric stove amana | Linda Polo | Oven Repair (including Ranges and Cooktops) | 1 | 06-04-2010 05:57 PM |
| Amana Stove won't heat up. | sundown12 | Oven Repair (including Ranges and Cooktops) | 0 | 07-18-2009 10:34 AM |
| Amana stove: Two questions | smokysun | Oven Repair (including Ranges and Cooktops) | 0 | 08-06-2007 02:26 PM |
