Mark A
#1 Posted : Tuesday, August 16, 2011 12:07:52 PM(UTC)
Mark A
I have a Kitchen Aid dble oven model # KEBS208DSS11. One of the doors will not close all the way, leaving the light on. The hinge and assembly has been changed. After hinge replacement the door still would not close correctly. When doors were interchanged the door having the problem remained the same so the fault must be in the door itself. When the door was disasaembled there are not any obvious bent door parts. Is there an interior part to replace to correct this problem besides the hinges?
