The switch light for the oven is broken and needs to be replaced.(Parts of the edge that should hold the button out have chipped away or corroded causing the button to fall into the hole on the upper right panel of the oven) I have ordered the part and was told I could go to this forum for instructions on how to do this job. I am handy but not too experienced. I just used the info here to fix a poorly draining dishwasher.
All help will be appreciated! Thanks
