Electric Oven, Wall unit GE Convection Oven Model number JKP70B0M1BB
Symptoms:
Regular Bake: Oven will not preheat past 125 degrees. Broil element not hot Broil: Oven will not heat, broil element not hot. Convection Bake: Oven preheats and heats just fine. Works as normal. Broil element doesn't heat.
I'm assuming it is the broil element that has failed here. Please advise.
