Discuss
Bottom Element on wall oven won't heat
 in
Our wall oven heats VERY slowly. When checked, the top element heats but the bottom element is stone cold. The
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Bottom Element on wall oven won't heat
  #1 (permalink)
Old 08-12-2011, 04:49 PM
Junior Member
CookeB is on a distinguished road
Default Bottom Element on wall oven won't heat
Model Number: CGEB27S7CB1   Brand: Frigidaire   Age: 1 - 5 years
Our wall oven heats VERY slowly. When checked, the top element heats but the bottom element is stone cold. The clock is working fine. We can hear the oven clicking on and off frequently.
We replaced the temperature sensor. No change. We replaced the terminal block. No change. We replaced the bottom element. Still no change.
We have check all the wiring on the back of the oven and in the junction box and they appear intact. No sign of burn marks or arcing around any of the wires.
Could the problem be the control panel? If so,what is the best way to approach this problem. Any other ideas? Help!
Thank you for any advice that you can muster.
Ads By Google
Related Models
Frigidaire CGEB27S7CB2 Frigidaire/walloven
Frigidaire CGEB27S7CS2 Frigidaire/walloven
Frigidaire CGEB30S9DB2 Frigidaire/electric Walloven
Frigidaire CGEB30S9DB4 Frigidaire Canada/wall Oven
Frigidaire CGEB30S9DS2 Frigidaire/electric Walloven
Frigidaire CGEB30S9DS3 Frigidaire Canada/wall Oven
Frigidaire CGEB30S9FB1 Frigidaire/wall Oven
Frigidaire CGEB30S9FS1 Frigidaire/wall Oven
Gibson CGEF309ES1 Gibson/electric Range
Gibson CGEF310ES1 Gibson Canada/electric Range
Gibson CGEF310ES2 Gibson Canada/electric Range
Gibson CGEF310FSA Gibson Canada/electric Range
Gibson CGEF312ES1 Gibson Canada/electric Range
Gibson CGEF312ES2 Gibson/range
Gibson CGEF312FSA Gibson Canada/electric Range
Gibson CGEF312FSB Gibson/range
Gibson CGEF316AS1 Frigidaire Elrange Cgef316as1
Gibson CGEF317AS1 Elrange Gibson Cgef317as1
Gibson CGEF322AS1 Lerange Gibson Cgef322as1
Gibson CGEF322ES1 Gibson Canada/electric Range
Gibson CGEF322ES3 Gibson Canada/electric Range
Gibson CGEF322ES4 Gibson/range
Gibson CGEF322ES5 Gibson/range
Thermador CGEI-19
Thermador CGEI-29
Frigidaire CGF140CES0 Frigidaire/dryer
Crosley CGF3C6CVK Range - F/s Std Gas
Crosley CGH3C6CVK Range - F/s Std Gas
Crosley CGHA821 Surface Unit - Gas
Crosley CGHA821K Surface Unit - Gas
Crosley CGHS821 Surface Unit - Gas
Crosley CGHS821K Surface Unit - Gas
Crosley CGHW821 Surface Unit - Gas
Crosley CGHW821K Surface Unit - Gas
Crosley CGHY821 Surface Unit - Gas
Crosley CGHY821K Surface Unit - Gas
Magic Chef CGL1100ADQ Range - F/s Std Gas
Magic Chef CGL1100ADW Range - F/s Std Gas
Magic Chef CGL1120ADH Range - F/s Std Gas
Magic Chef CGL1120ADL Range - F/s Std Gas
Magic Chef CGL1120ADT Range - F/s Std Gas
Magic Chef CGL1125ADH Range - F/s Std Gas
Crosley CGLA821K Surface Unit - Gas
Crosley CGLB821K Surface Unit - Gas
Frigidaire CGLEF379DBE Frigidaire/range
Frigidaire CGLEF379DBF Frigidaire/range
Frigidaire CGLEF379DBG Frigidaire/range
Frigidaire CGLEF379DBH Frigidaire Canada/electric Range
Frigidaire CGLEF379DBJ Frigidaire Canada/electric Range
Frigidaire CGLEF379DBK Frigidaire Canada/electric Range
Frigidaire CGLEF379DCE Frigidaire/range
Frigidaire CGLEF379DCG Frigidaire/range
Frigidaire CGLEF379DCH Frigidaire/range
Frigidaire CGLEF379DCJ Frigidaire/electric Range
Frigidaire CGLEF379DCK Frigidaire Canada/electric Range
Frigidaire CGLEF379DCM Frigidaire/range
Frigidaire CGLEF379DCN Frigidaire/range
Frigidaire CGLEF379DSE Frigidaire/range
Frigidaire CGLEF379DSF Frigidaire/range
Frigidaire CGLEF379DSG Frigidaire/range
Frigidaire CGLEF379DSH Frigidaire Canada/electric Range
Frigidaire CGLEF379DSJ Frigidaire Canada/electric Range
Frigidaire CGLEF379DSK Frigidaire Canada/electric Range
Frigidaire CGLEF384DS2 Frigidaire/range
Frigidaire CGLEF384DS3 Frigidaire/range
Frigidaire CGLEFM97DBB Frigidaire Canada/electric Range
Frigidaire CGLEFM97DBF Frigidaire Canada/electric Range
Frigidaire CGLEFM97DSB Frigidaire Canada/electric Range
Frigidaire CGLEFM97DSD Frigidaire/range
Frigidaire CGLEFM97DSF Frigidaire Canada/electric Range
Frigidaire CGLES385EB1 Frigidaire Canada/electric Range
Frigidaire CGLES385EB2 Frigidaire/electric Range
Frigidaire CGLES385ES1 Frigidaire Canada/electric Range
Frigidaire CGLES385ES2 Frigidaire/electric Range
Frigidaire CGLES385FB1 Frigidaire Canada/electric Range
Frigidaire CGLES385FB2 Frigidaire Canada/electric Range
Frigidaire CGLES385FS1 Frigidaire Canada/electric Range
Frigidaire CGLES385FS2 Frigidaire Canada/electric Range
Frigidaire CGLES389EB1 Frigidaire Canada/electric Range
Frigidaire CGLES389EB2 Frigidaire Canada/electric Range
Frigidaire CGLES389EB3 Frigidaire Canada/electric Range
Frigidaire CGLES389EB4 Frigidaire Canada/electric Range
Frigidaire CGLES389EB5 Frigidaire/range
Frigidaire CGLES389ES1 Frigidaire Canada/electric Range
Frigidaire CGLES389ES2 Frigidaire Canada/electric Range
Frigidaire CGLES389ES3 Frigidaire Canada/electric Range
Frigidaire CGLES389ES4 Frigidaire Canada/electric Range
Frigidaire CGLES389ES5 Frigidaire/range
Frigidaire CGLES389FB1 Frigidaire Canada/electric Range
Frigidaire CGLES389FB2 Frigidaire Canada/electric Range
Frigidaire CGLES389FS1 Frigidaire Canada/electric Range
Frigidaire CGLES389FS2 Frigidaire Canada/electric Range
Frigidaire CGLGF382DSC Frigidaire/range
Frigidaire CGLGF382DSE Frigidaire/range
Frigidaire CGLGF382DSF Frigidaire/range
Frigidaire CGLGF382DSG Frigidaire/range
Frigidaire CGLGF388DBC Frigidaire/range
Frigidaire CGLGF388DBE Frigidaire/range
Frigidaire CGLGF388DBF Frigidaire/range
Frigidaire CGLGF388DBG Frigidaire Canada/gas Range
Frigidaire CGLGF388DQC Frigidaire/range
Frigidaire CGLGF388DQE Frigidaire/range
Frigidaire CGLGF388DQF Frigidaire/range
Frigidaire CGLGF388DQG Frigidaire Canada/gas Range
Frigidaire CGLGF388DSC Frigidaire/range
Frigidaire CGLGF388DSE Frigidaire/range
Frigidaire CGLGF388DSF Frigidaire/range
Frigidaire CGLGF388DSG Frigidaire Canada/gas Range
Frigidaire CGLMV168CB1 Frigidaire/microwave
Frigidaire CGLMV168CQ1 Frigidaire/microwave
Frigidaire CGLMV168CS1 Frigidaire/microwave
Frigidaire CGLMV168KB1 Frigidaire/microwave
Frigidaire CGLMV168KQ1 Frigidaire/microwave
Frigidaire CGLMV168KS1 Frigidaire/microwave
Frigidaire CGLMV169DBB Frigidaire/microwave
Frigidaire CGLMV169DQB Frigidaire/microwave
Frigidaire CGLMV169DSB Frigidaire/microwave
Crosley CGLS821K Surface Unit - Gas
Crosley CGLW821K Surface Unit - Gas
Whirlpool CGM2751JQ0
  #2 (permalink)
Old 08-12-2011, 06:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad Electronic Oven Control (aka a clock/timer). Unfortunately this part is no longer available.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 08-12-2011, 06:58 PM
Junior Member
Default
Quote:
Thank you for your expertise Gene. Doesn't sound good for our oven though. We appreciate your response.
  #4 (permalink)
Old 08-14-2011, 06:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. Unfortunately nothing last forever.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bottom oven, bottom heating element won't heat weber7062 Oven Repair (including Ranges and Cooktops) 0 02-28-2011 02:38 PM
lost bake element connector wires behind oven wall in wall oven wdeather98 Oven Repair (including Ranges and Cooktops) 1 01-01-2011 08:24 PM
Bottom oven element won't heat up HammerJ88 Oven Repair (including Ranges and Cooktops) 0 03-05-2010 05:43 PM
Maytag Electric Wall Oven upper bake element won't heat Keithmcelroy Oven Repair (including Ranges and Cooktops) 0 09-06-2009 09:52 AM
GE OVEN bottom element wont heat Foe Oven Repair (including Ranges and Cooktops) 0 04-29-2008 11:02 AM
