this oven is cussing a lot of trouble first from the beginning the sparkler dont stop sparking at cooking now the clock which is the control computer board shows to call the 800 # for repair and the oven stops working what is my options can any one help
Originally Posted by: rachel11211 this oven is cussing a lot of trouble first from the beginning the sparkler dont stop sparking at cooking now the clock which is the control computer board shows to call the 800 # for repair and the oven stops working what is my options can any one help Rachel, You have several options. Your top burner igniter sparking issue, could be due to a bad spark module, ignition switch, or "dirty" burner, and several more. Your display issue, is usually caused by several attempts to program and use the range, when there has been a failure. Do you remember any "Fail Codes" "F3, F1,F0" etc. ? Let us know which direction you want to take , and we'll be happy to assist you. :) :) :)
