Discuss
Ignitor test/Have multi meter
 in
How can I test if the ignitors are getting enough,or using enough amps? First time doing this stuff. I borrowed
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Ignitor test/Have multi meter
  #1 (permalink)
Old 08-12-2011, 06:30 AM
Junior Member
scottkoch is on a distinguished road
Default Ignitor test/Have multi meter
Model Number: ARG7300w   Brand: Amana   Age: More than 10 years
How can I test if the ignitors are getting enough,or using enough amps? First time doing this stuff. I borrowed a Electro- tek meter, with probes. Can not afford a new oven right now!
Ads By Google
Related Models
Amana ARG7300W RANGE- S/C S/I DDRAFT GAS
Amana ARG7300WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7301L RANGE- S/C S/I DDRAFT GAS
Amana ARG7301LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7301W RANGE- S/C S/I DDRAFT GAS
Amana ARG7301WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7302CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7302LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7302WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7303CC RANGE- S/C F/S GAS
Amana ARG7303LL RANGE- S/C F/S GAS
Amana ARG7303WW RANGE- S/C F/S GAS
Amana ARG7600CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7600L RANGE- S/C S/I DDRAFT GAS
Amana ARG7600L RANGE- S/C F/S GAS
Amana ARG7600LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7600W RANGE- S/C S/I DDRAFT GAS
Amana ARG7600WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7600WW RANGE- S/C F/S GAS
Amana ARG7800CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7800E RANGE- S/C S/I DDRAFT GAS
Amana ARG7800LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7800SS RANGE- S/C S/I DDRAFT GAS
Amana ARG7800WW RANGE- S/C S/I DDRAFT GAS
Amana ARGS7650CC RANGE- S/C S/I GAS
Amana ARGS7650E RANGE- S/C S/I GAS
  #2 (permalink)
Old 08-12-2011, 12:20 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Scott,
You can't check the voltage to the igniters, not without a special meter anyway, the DC voltage is too high.
You can check the igniters and wires for resistance and possible shorts to the chassis,panels or pipes.
Here's a helpfull post from the APP Repair Forum, if you need it :
How To Check Continuity With Ohmmeter
You most likely have an issue with the spark module, or a lot of debris on the burner bases and igniters, based on your post description.
Part number: AP4041505
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-13-2011, 06:03 AM
Junior Member
Default
The ignitors on the oven are the "stone" type, They turn red. but no gas. I've read to check the AMP draw from the ignitor. The oven ignitor comes on when it is in bake mode,the broil ignitor is on when in broil. To check the AMPS, would I keep one wire "solid" and split the other and check with the tester? I Thank you for replies. Can not afford a new oven now. Times are tough, can't get a decent oven for under $500.00 dollars!(on the cheap end!)
  #4 (permalink)
Old 08-13-2011, 07:19 AM
Senior Expert
Default
Scott,
Sorry, I guess I misunderstood your question, my fault.
What you want to test is voltage to the bake burner valve(s).
You want to trace the wire from the igniter to the gas valve. With a temperature programmed, when the glow bar is glowing, there should be 3.2 to 3.6 VAC across the two wires attached to the gas valve. Voltage below 3.2 VAC at the wires, will not open the switch in the valve and gas will not be released.
If you have a "Clamp On" amp meter, the system should draw 3.2 to 3.6 amps , while the igniter is glowing ( just clamp the meter around one of the wires). I'm sure all you need is an igniter,
Part number: AP4012072
But you will be positive after the tests.
Good Luck,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 02-25-2013, 02:49 PM
Junior Member
pingu is on a distinguished road
Default
I found it very convenient to just plug my stove power cord into KILL A WATT voltage/amp/KWH meter (about $20-30 online) instead of pulling things apart and reaching underneath with an AC clamp meter. I could see my oven igniter only drawing 2.5A and the broiler igniter drawing 3.4A. Those igniters look like the same parts; I might just swap them for a test before ordering the part!
  #6 (permalink)
Old 02-26-2013, 07:09 AM
Senior Expert
Default
Quote:
Pingu, You could "swap" the igniters, it will help to verify the issue, But you already know that's the issue. If the igniter doesn't draw 3.2 to 3.6 amps, it won't open the safety valve or ignite the gas supply. Also "swapping" the igniter will keep you going, until the new part arrives.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Which thermostat connectors do I test with ohm meter? topfreeze Refrigerator & Freezer Repair 1 12-11-2010 05:26 AM
How do I test an oven ignitor? belac Oven Repair (including Ranges and Cooktops) 5 04-22-2010 02:06 PM
Dryer runs; Will not heat; no meter to test jmmoore Dryer Repair 1 09-06-2009 07:31 AM
Ignitor test question davedorsett Oven Repair (including Ranges and Cooktops) 3 01-12-2009 10:24 AM
