Oven Bake lights and preheats fine. After a while(less than an hour) it fails to light and maintain temperature. I removed the flame spreader and bottom to observe. I did not have a problem and observed the oven burner cycling on and off for over 2 hrs. I put the flame spreader and bottom back in oven. It worked for a while and then the oven quit lighting within a half an hour. The control says it is heating( the warm light is on) but it is not lit. I adjusted the burner flame full range, but it did not make any difference. When it quits heating, I can hear the gas come on and the ignitor fire. It sounds like it lights but then goes out immediately.
