Discuss
Error Code F2
 in
Just got this error code which apparently means that the oven is sensing temperatures of over 900 degrees - not good.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Error Code F2
  #1 (permalink)
Old 11-24-2007, 12:28 PM
mrcclc mrcclc is offline
Junior Member
mrcclc is on a distinguished road
Default Error Code F2
Model Number: JGBP30WEA2WW   Brand: GE   Age: 5 - 10 years
Just got this error code which apparently means that the oven is sensing temperatures of over 900 degrees - not good. My questions are: (1) what is the likely part that is needed to repair?; (2) what does it cost?, (3) can I do the replacement myself?; (4) what would a repairman likely charge? Thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-24-2007, 12:37 PM
Junior Member
Default More re Error Code F2
Don't know how to edit an already posted entry. My wife just told me that when the F2 message comes on the "Cook Time" light blinks. We've never used the Cook Time feature so we've never seen it blink except for now.
  #3 (permalink)
Old 11-25-2007, 07:34 AM
jumptrout51 jumptrout51 is offline
Expert
APP Volunteer
jumptrout51 is on a distinguished road
Default
Probably a bad oven sensor about $50. Yes you can do it.
Unplug range from power. Remove oven racks. Locate sensor(a 3-6 inch by 1/4 inch metal probe).Usually at top of oven cavity,thru the back. Remove screws and pull out. Remove quick disconnect plug. Reverse order to install.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F3 error code mich26 Microwave Repair 3 01-23-2008 07:28 PM
error code 01 platini Washer Repair 5 11-29-2007 12:29 PM
F 1 Error Code Frogburk Oven Repair (including Ranges and Cooktops) 1 08-29-2007 03:10 PM
e-10 error code hoogabooga Washer Repair 0 08-28-2007 03:57 PM
F2 - Error Code Wilson Oven Repair (including Ranges and Cooktops) 3 08-23-2007 10:49 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
