My Jenn-Air stove is having problems with the control panel. The only button that doesn't work is the up arrow. The rest of the control panel works fine. I am assuming that this was the first button to go since I use the up arrow the most. Does the whole control panel need to be replaced, or is there something that can be done to fix the up arrow? I cannot use the timer and can only bake up to 350 degrees w/out the up arrow. I would really like to avoid having to pay around $400 for a new control panel and the labor to repair it.
THIS FORUM IS DEAD!!!!!!! |
