I have a Jenn-air stove, Model JDR8895AAS. When you set the temperature to a setting for either oven, top or bottom, the temperature just takes off and goes to very high, the LED flashes with a code I can't read and then it stops. I had to turn it off at the circuit breaker because the controls didn't respond. Has anyone else had this problem?
