Discuss
Magic chef F1 same ole story
 in
I inherited this appliance when I purchased the home, so I don't now how old this range/oven is. I noticed
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Magic chef F1 same ole story
  #1 (permalink)
Old 03-28-2009, 12:53 PM
Junior Member
yemoto is on a distinguished road
Default Magic chef F1 same ole story
Model Number: 6498VTA   Brand: Magic Chef   Age: 1 - 5 years
I inherited this appliance when I purchased the home, so I don't now how old this range/oven is. I noticed other people having the same problem with the display of the F1 and the constant beeping. All I know is when I remove the panel (membrane) on the outside that has the buttons, my problem goes away, so it sounds like I should replace that part. However, there are those that have the same problem and have replaced that part and still have that problem. Of course, neither part is cheap and I cannot return the item is plugged in, what would you suggest?
Dennis
Related Models
Magic Chef 6498VTA RANGE- S/C S/I GAS
Magic Chef 6498VTV RANGE- S/C S/I GAS
Magic Chef 6498VVA GAS RANGE
Magic Chef 6498VVD RANGE- S/C S/I GAS
Magic Chef 6498VVV RANGE- S/C S/I GAS
Magic Chef 6498XRA RANGE- S/C S/I GAS
Magic Chef 6498XRS RANGE- S/C S/I GAS
Magic Chef 6498XRW RANGE- S/C S/I GAS
Magic Chef 6498XTA RANGE- S/C S/I GAS
Magic Chef 6498XTS RANGE- S/C S/I GAS
Magic Chef 6498XTW RANGE- S/C S/I GAS
Magic Chef 6498XVB RANGE- S/C S/I GAS
Magic Chef 6498XVS RANGE- S/C S/I GAS
Magic Chef 64EA-3CKW RANGE- S/C S/I GAS
Magic Chef 64EB-3CKW RANGE- S/C S/I GAS
Magic Chef 64EN-3CKW RANGE- S/C S/I GAS
Magic Chef 64EY-3CKW RANGE- S/C S/I GAS
Magic Chef 64FA-3CKVW RANGE- S/C S/I GAS
Magic Chef 64FA-3CKW RANGE- S/C S/I GAS
Magic Chef 64FA-3CKX RANGE- S/C S/I GAS
Magic Chef 64FA-3CKXW RANGE- S/C S/I GAS
Magic Chef 64FB-3CKW RANGE- S/C S/I GAS
Magic Chef 64FK-3CKX RANGE- S/C S/I GAS
Magic Chef 64FK-3CKXW RANGE- S/C S/I GAS
Magic Chef 64FN-3CKVW RANGE- S/C S/I GAS
Magic Chef 64FN-3CKW RANGE- S/C S/I GAS
Magic Chef 64FN-3CKX RANGE- S/C S/I GAS
Magic Chef 64FN-3CKXW RANGE- S/C S/I GAS
Magic Chef 64FY-3CKW RANGE- S/C S/I GAS
Magic Chef 64FY-3CKX RANGE- S/C S/I GAS
Magic Chef 64FY-3CKXW RANGE- S/C S/I GAS
Magic Chef 64H-4TKVW RANGE- S/C S/I GAS
Magic Chef 64H-4TKXW RANGE- S/C S/I GAS
Magic Chef 64HA-4TKVW RANGE- S/C S/I GAS
Magic Chef 64HA-4TKXW RANGE- S/C S/I GAS
Magic Chef 64HK-4TKXW RANGE- S/C S/I GAS
Magic Chef 64HN-4TKVW RANGE- S/C S/I GAS
Magic Chef 64HN-4TKXW RANGE- S/C S/I GAS
Hoover 65
Amana 650.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 650.001 RANGE- S/C S/I DDRAFT GAS
Magic Chef 6500PRA RANGE- S/I STD ELE
Magic Chef 6500PRW RANGE- S/I STD ELE
Magic Chef 6500SRS RANGE- S/I STD ELE
Frigidaire 6504A WASHER
Frigidaire 6504B WASHER
Frigidaire 6504C WASHER
Frigidaire 6504D WASHER
Frigidaire 6504E WASHER
Frigidaire 6504E-87 WASHER
Frigidaire 6505A WASHER
Frigidaire 6505B WASHER
Frigidaire 6505C WASHER
Frigidaire 6506-87A WASHER
Frigidaire 6506-87C WASHER
Frigidaire 6506-87D TOP LOAD WASHER
Frigidaire 6506-87E TOP LOAD WASHER
Frigidaire 6506A WASHER
Frigidaire 6506B WASHER
Frigidaire 6507-87A WASHER
Frigidaire 6507-87C WASHER
Frigidaire 6507-87D WASHER
Frigidaire 6507-87E TOP LOAD WASHER
Frigidaire 6507A WASHER
Frigidaire 6508D WASHER
Hoover 651
Amana 651.000 RANGE- S/C S/I DDRAFT GAS
Amana 651.001 RANGE- S/C S/I DDRAFT GAS
Amana 651.002 RANGE- S/C S/I DDRAFT GAS
Amana 651.003 RANGE- S/C S/I DDRAFT GAS
Amana 651.004 RANGE- S/C S/I DDRAFT GAS
Amana 651.006 RANGE- S/C S/I DDRAFT GAS
Kenmore 65189918100 WRINGER WASHER
Admiral 651AH RANGE- S/C F/S ELE
Admiral 651WH RANGE- S/C F/S ELE
Admiral 653AH-HV RANGE- F/S STD ELE
Admiral 653AH-V RANGE- F/S STD ELE
Admiral 653AJ-HV RANGE- F/S STD ELE
Admiral 653AJ-V RANGE- S/C F/S ELE
Admiral 653AJ-V-CX RANGE- F/S STD ELE
Admiral 653WH-HV RANGE- F/S STD ELE
Admiral 653WH-V RANGE- F/S STD ELE
Admiral 653WJ-HV RANGE- F/S STD ELE
Admiral 653WJ-V RANGE- S/C F/S ELE
Admiral 653WJ-V-CX RANGE- F/S STD ELE
Admiral 654AD-HVW RANGE- F/S STD ELE
Admiral 654AG-HVW RANGE- F/S STD ELE
Admiral 654AH-ELVW RANGE- F/S CONT CLEAN ELE
Admiral 654AH-EVW RANGE- F/S STD ELE
Admiral 654AH-EW RANGE- F/S STD ELE
Admiral 654WD-HVW RANGE- F/S STD ELE
Admiral 654WG-HVW RANGE- F/S STD ELE
Admiral 654WH-ELVW RANGE- F/S CONT CLEAN ELE
Admiral 654WH-ELW RANGE- F/S CONT CLEAN ELE
Admiral 654WH-EW RANGE- F/S STD ELE
Magic Chef 6551WRA RANGE- S/I STD ELE
Magic Chef 6551WRW RANGE- S/I STD ELE
Magic Chef 6551WUA RANGE- S/I STD ELE
Magic Chef 6551WUB RANGE- S/I STD ELE
Magic Chef 6551WUW RANGE- S/I STD ELE
Magic Chef 6551XRA RANGE- S/I STD ELE
Magic Chef 6551XRW RANGE- S/I STD ELE
Magic Chef 6551XUA RANGE- S/I STD ELE
Magic Chef 6551XUB RANGE- S/I STD ELE
Magic Chef 6551XUW RANGE- S/I STD ELE
Admiral 655AH-CVW RANGE- F/S STD ELE
Admiral 655WH-CVW RANGE- F/S STD ELE
Admiral 656AH-EHVW RANGE- F/S STD ELE
Admiral 656HH-EHVW RANGE- F/S STD ELE
Admiral 656WH-EHVW RANGE- F/S STD ELE
Frigidaire 6589-80 WASHER
Frigidaire 6589-80B WASHER
Frigidaire 6589-87 WASHER
Maytag 65C DRYER- GAS
Magic Chef 65HA-1 RANGE- S/I STD ELE
Magic Chef 65HA-3W RANGE- S/I STD ELE
Magic Chef 65HA-3X RANGE- S/I STD ELE
Magic Chef 65HN-1 RANGE- S/I STD ELE
Magic Chef 65HN-3W RANGE- S/I STD ELE
Magic Chef 65HN-3X RANGE- S/I STD ELE
  #2 (permalink)
Old 03-28-2009, 01:29 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
that is the gig, with this electronic stuff. we look up the codes, and it is about 75% correct. but, just the shear fact, that you unplugged the touch pad, and the noise stopped, i believe you are on the right track. the f1 codes is touch pad. tom
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
magic chef elizabeth reiling Refrigerator & Freezer Repair 1 01-04-2010 02:46 PM
Magic chef gsonny50 Refrigerator & Freezer Repair 0 12-28-2009 01:36 PM
Magic Chef maverick0923 Oven Repair (including Ranges and Cooktops) 1 11-27-2009 12:35 PM
Magic Chef jeany Refrigerator & Freezer Repair 1 10-16-2009 05:31 PM
