Discuss
Repair Manual needed
 in
I'm looking for a repair manual for my Jenn-Air C301 cooktop. I've contacted Jenn-Air and they replied with "Unfortunately, we
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Repair Manual needed
  #1 (permalink)
Old 03-28-2009, 11:32 AM
Junior Member
romad is on a distinguished road
Default Repair Manual needed
Model Number: C301   Brand: Jenn-Air   Age: More than 10 years
I'm looking for a repair manual for my Jenn-Air C301 cooktop. I've contacted Jenn-Air and they replied with "Unfortunately, we do not have any technical information available in our database that will prove helpful with addressing this concern."
Right now I just need to know how to remove the cage fan from the motor shaft so that I can clean the grease off. I think it is causing an imbalance.
I've scanned the C301 wiring diagram if any one needs it.
Sincerely,
Dennis B. Swaney
Related Models
Jenn-Air C301 SURFACE UNIT- DDRAFT ELE
Jenn-Air C301-C SURFACE UNIT- DDRAFT ELE
Thermador C301U BUILT-IN OVENS
Jenn-Air C302 SURFACE UNIT- DDRAFT ELE
Thermador C302U BUILT-IN OVENS
Roper C3057*0 Ranges, Electric*
Roper C3057X0 Ranges, Electric*
Jenn-Air C306 SURFACE UNIT- DDRAFT ELE
Jenn-Air C306-C SURFACE UNIT- DDRAFT ELE
Hoover C3077
Crosley C31000PAA RANGE- F/S STD GAS
Crosley C31000PAAD RANGE- F/S STD GAS
Crosley C31000PAT RANGE- F/S STD GAS
Crosley C31000PATP RANGE- F/S STD GAS
Crosley C31000PAW RANGE- F/S STD GAS
Crosley C31000PAWD RANGE- F/S STD GAS
Crosley C31000PAWP RANGE- F/S STD GAS
Roper C3107*0 Ranges, Electric*
Roper C3107L0 Ranges, Electric*
Crosley C31100PAA RANGE- F/S STD GAS
Crosley C31100PAV RANGE- F/S STD GAS
Crosley C31100SAA RANGE- F/S STD GAS
Crosley C31100SAAP RANGE- F/S STD GAS
Crosley C31100SAT RANGE- F/S STD GAS
Crosley C31100SATP RANGE- F/S STD GAS
Crosley C31100SAW RANGE- F/S STD GAS
Crosley C31100SAWP RANGE- F/S STD GAS
Crosley C31103SAA RANGE- F/S STD GAS
Crosley C31103SAT RANGE- F/S STD GAS
Crosley C31103SAW RANGE- F/S STD GAS
Crosley C31113WAA RANGE- F/S STD GAS
Crosley C31113WAAP RANGE- F/S STD GAS
Crosley C31113WAB RANGE- F/S STD GAS
Crosley C31113WAT RANGE- F/S STD GAS
Crosley C31113WATP RANGE- F/S STD GAS
Crosley C31113WAV RANGE- F/S STD GAS
Crosley C31113WAVP RANGE- F/S STD GAS
Crosley C31113XAA RANGE- F/S STD GAS
Crosley C31113XAT RANGE- F/S STD GAS
Crosley C31113XAW RANGE- F/S STD GAS
Crosley C31315VAM RANGE- F/S STD GAS
Crosley C31315VAV RANGE- F/S STD GAS
Crosley C31315VBM RANGE- F/S STD GAS
Crosley C31315VBQ RANGE- F/S STD GAS
Crosley C31315VBV RANGE- F/S STD GAS
Crosley C31315XBT RANGE- F/S STD GAS
Crosley C31315XBW RANGE- F/S STD GAS
Roper C3157*0 Ranges, Electric*
Roper C3157W0 Ranges, Electric*
Jenn-Air C316 SURFACE UNIT- DDRAFT ELE
Jenn-Air C316-C SURFACE UNIT- DDRAFT ELE
Jenn-Air C316W SURFACE UNIT- DDRAFT ELE
Jenn-Air C316W-C SURFACE UNIT- DDRAFT ELE
Roper C3257*0 Ranges, Electric*
Roper C3257W0 Ranges, Electric*
Roper C3357*0 Ranges, Electric*
Roper C3357W0 Ranges, Electric*
Whirlpool C3357^0
Roper C3408B0 Ranges, Electric*
Roper C3408B1 Ranges, Electric*
Roper C3408B2 Ranges, Electric*
Roper C3457*0 Ranges, Electric*
Roper C3457*1 Ranges, Electric*
Roper C3457X0 Ranges, Electric*
Roper C3457X1 Ranges, Electric*
Roper C3458*0 Ranges, Electric*
Roper C3458W0 Ranges, Electric*
Magic Chef C3510PVV RANGE- F/S STD ELE
Magic Chef C3521WRV RANGE- F/S STD ELE
Magic Chef C3521XRA RANGE- F/S STD ELE
Magic Chef C3521XRW RANGE- F/S STD ELE
Magic Chef C3523WVA RANGE- F/S STD ELE
Magic Chef C3523WVV RANGE- F/S STD ELE
Magic Chef C3542XRA RANGE- F/S STD ELE
Magic Chef C3542XRW RANGE- F/S STD ELE
Magic Chef C3581VRV RANGE- F/S STD ELE
Magic Chef C3581VUV RANGE- F/S STD ELE
Magic Chef C3581XRA RANGE- F/S STD ELE
Magic Chef C3581XRW RANGE- F/S STD ELE
Thermador C36 COOKTOP
Hoover C3820--- EXTR-W/FIX & ROT BRUSH,TEMPEST
Magic Chef C3842XRA RANGE- S/C F/S ELE
Magic Chef C3842XRW RANGE- S/C F/S ELE
Magic Chef C3862VYV RANGE- S/C F/S ELE
Magic Chef C3862XYB RANGE- S/C F/S ELE
Magic Chef C3868VYV RANGE- S/C F/S ELE
Magic Chef C3882VRV RANGE- S/C F/S ELE
Magic Chef C3882VVV RANGE- S/C F/S ELE
Magic Chef C3882XRA RANGE- S/C F/S ELE
Magic Chef C3882XRB RANGE- S/C F/S ELE
Magic Chef C3882XRW RANGE- S/C F/S ELE
Magic Chef C3882XVA RANGE- S/C F/S ELE
Magic Chef C3888VRV RANGE- S/C F/S ELE
Magic Chef C3888VVV RANGE- S/C F/S ELE
Magic Chef C3888XRA RANGE- S/C F/S ELE
Magic Chef C3888XRW RANGE- S/C F/S ELE
Magic Chef C3888XVA RANGE- S/C F/S ELE
Magic Chef C3888XVW RANGE- S/C F/S ELE
Hoover C4275--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C4277--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C4279--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5023--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5025--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5027--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5029--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5031--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5033--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5035--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5037--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5039--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5041--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5122
Amana C52B ROOM AIR CONDITIONER
Maytag C5AALWH FREEZER- CHEST
Maytag C5ABLWH FREEZER- CHEST
Maytag C5H FREEZER- CHEST
Maytag C5J FREEZER- CHEST
Hoover C6075--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C6077--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Amana C6412301 MISC / ACCESSORY
  #2 (permalink)
Old 03-28-2009, 04:44 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for JENN-AIR C301 | AppliancePartsPros.com
See Item 10 in the parts list click on the picture for other views of the blower wheel.
You will see the screw that holds it onto the shaft.
Theses are often allen key screws.
After you get it off, file down the ridges on the motor shaft left by the screw.
It will make getting it back on a lot easier.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dacor EOR oven technical manual needed sjoyce15 Oven Repair (including Ranges and Cooktops) 0 01-05-2010 11:08 AM
Manual needed Cjmall Dishwasher Repair 1 11-17-2009 06:19 AM
Manual Needed Cjmall Oven Repair (including Ranges and Cooktops) 1 11-15-2009 05:30 PM
Whirlpool Service Manual Needed for Handle Replacement mjohnson Microwave Repair 3 05-02-2009 11:22 PM
Help - Westinghouse SB925 Service Manual needed Westie jax Dishwasher Repair 0 10-05-2008 10:04 PM
