I have a fault code "40" on my range. Was told it needed a noise suppressor. Bought one and went to install it. The instructions tell me to connect the ferrite bead around the j2 wire harness (orange) on the power relay board. Problem is there is no j2 orange wire harness. Would like to know how to proceed, and if 40 on the display requires a noise suppressor or if it is something else wrong with the range.
