Discuss
Jenn Air motor voltage.
 in
Replaced a bad rocker switch(fan/light). Turned on motor, it ran very slow for about 2minutes, then kicked in high for
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn Air motor voltage.
  #1 (permalink)
Old 03-26-2009, 08:16 PM
Junior Member
hvach3-1 is on a distinguished road
Default Jenn Air motor voltage.
Model Number: S136   Brand: Jenn-Air   Age: More than 10 years
Replaced a bad rocker switch(fan/light). Turned on motor, it ran very slow for about 2minutes, then kicked in high for about 5 seconds before it quit and smoked. I tested the voltage output at the power cord to the fan, it read 24v. Is this the correct votage? The stove was purchased used, so I don't know the history. The switch was very simple to wire, matched wire for wire. The only way to mess up would be if the previous switch was miswired. The reason for replaceing switch was that it was obviously bad, would not turn on fan or light, just felt spongy w/no click.
I feel certain the motor is fried, I just don't want to smoke another if there is a malfunction in the control circuit. Any ideas?
Ads By Google
Related Models
Jenn-Air S136 Range - S/c S/i Ddraft Ele
Jenn-Air S136-C Range - S/c S/i Ddraft Ele
Hoover S1361---
Jenn-Air S136B Range - S/c S/i Ddraft Ele
Jenn-Air S136B-C Range - S/c S/i Ddraft Ele
Jenn-Air S136W Range - S/c S/i Ddraft Ele
Jenn-Air S136W-C Range - S/c S/i Ddraft Ele
Hoover S1410--- Port - Slim Style,suitcase,power,compact
Hoover S1420--- Port - Slim Style,suitcase,power,compact
Hoover S1420050 Port - Slim Style,suitcase,power,compact
Amana S148CA01  Ref - SXS/I&W
Amana S148CA03  Ref - SXS/I&W
Amana S148DA01  Ref - Sxs
Amana S148DA03  Ref - Sxs
Jenn-Air S156 Range - S/c S/i Ddraft Ele
Jenn-Air S156-C Range - S/c S/i Ddraft Ele
Jenn-Air S156B Range - S/c S/i Ddraft Ele
Jenn-Air S156B-C Range - S/c S/i Ddraft Ele
Jenn-Air S156W Range - S/c S/i Ddraft Ele
Jenn-Air S156W-C Range - S/c S/i Ddraft Ele
Amana S16 Freezer - Vertical
Jenn-Air S160 Range - S/c S/i Ddraft Ele
Jenn-Air S160-C Range - S/c S/i Ddraft Ele
Jenn-Air S161 Range - S/c S/i Ddraft Ele
Jenn-Air S166 Range - S/c S/i Ddraft Ele
Jenn-Air S166-C Range - S/c S/i Ddraft Ele
Jenn-Air S166B Range - S/c S/i Ddraft Ele
Jenn-Air S166B-C Range - S/c S/i Ddraft Ele
Jenn-Air S166W Range - S/c S/i Ddraft Ele
Jenn-Air S166W-C Range - S/c S/i Ddraft Ele
Amana S16L Freezer - Vertical
Jenn-Air S176 Range - S/c S/i Ddraft Ele
Jenn-Air S176B Range - S/c S/i Ddraft Ele
Jenn-Air S176W Range - S/c S/i Ddraft Ele
Amana S19E Ref - SXS/I&W
Frigidaire S2-06B1E Kel(v0) / Room Air Conditioner
Amana S20 Freezer - Vertical
General Electric S2000D0WW Washer
General Electric S2000D2WW Washer
General Electric S2000D5WW Washer
Hoover S2001---
Hoover S2003--- Stick - Handy,broom,light Wt,compact
Hoover S2005--- Stick - Handy,broom,light Wt,compact
Hoover S2007--- Stick - Handy,broom,light Wt,compact
Hoover S2009--- Stick - Handy,broom,light Wt,compact
Hoover S2011--- Stick - Handy,broom,light Wt,compact
Hoover S2013--- Stick - Handy,broom,light Wt,compact
Hoover S2015--- Stick - Handy,broom,light Wt,compact
Hoover S2029--- Stick - Handy,broom,light Wt,compact
Hoover S2031--- Stick - Handy,broom,light Wt,compact
Hoover S2033--- Stick - Handy,broom,light Wt,compact
Hoover S2037--- Stick - Handy,broom,light Wt,compact
Hoover S2039--- Stick - Handy,broom,light Wt,compact
Hoover S2041--- Stick - Handy,broom,light Wt,compact
Hoover S2043--- Stick - Handy,broom,light Wt,compact
Hoover S2047--- Stick - Handy,broom,light Wt,compact
Frigidaire S204F1SA Kel(v1) / Room Air Conditioner
Hoover S2053--- Stick - Handy,broom,light Wt,compact
Hoover S2053032 Stick - Handy,broom,light Wt,compact
Hoover S2053042 Stick - Handy,broom,light Wt,compact
Hoover S2053942 Stick - Handy,broom,light Wt,compact
Hoover S2055--- Stick - Handy,broom,light Wt,compact
Hoover S2057--- Stick - Handy,broom,light Wt,compact
Frigidaire S205A1QA Kel(v0) / Room Air Conditioner
Hoover S2085--- Stick - Handy,broom,light Wt,compact
Hoover S2087--- Stick - Handy,broom,light Wt,compact
Hoover S2087900 Stick - Handy,broom,light Wt,compact
Frigidaire S208C1E Kel(v1) / Room Air Conditioner
Frigidaire S208C1E2 Kel(v1) / Room Air Conditioner
Frigidaire S208C1QA Kel(v0) / Room Air Conditioner
Frigidaire S208D1QA Kel(v1) / Air Conditioner
Hoover S2095--- Stick - Handy,broom,light Wt,compact
Hoover S2097--- Stick - Handy,broom,light Wt,compact
Hoover S2099--- Stick - Handy,broom,light Wt,compact
Amana S20A Freezer - Vertical
General Electric S2100E1WW Washer
General Electric S2100E4WW Washer
General Electric S2100E6WW Washer
General Electric S2100E7WW Washer
General Electric S2100G0WW Washer
General Electric S2100G2WW Washer
Hoover S2103--- Stick - Handy,broom,light Wt,compact
Hoover S2105--- Stick - Handy,broom,light Wt,compact
Hoover S2105050 Stick - Handy,broom,light Wt,compact
Hoover S2105180
Hoover S2131--- Stick - Handy,broom,light Wt,compact
Hoover S2135--- Stick - Handy,broom,light Wt,compact
Hoover S2139080 Stick - Handy,broom,light Wt,compact
Hoover S2141--- Stick - Handy,broom,light Wt,compact
Hoover S2147--- Stick - Handy,broom,light Wt,compact
Hoover S2149--- Stick - Handy,broom,light Wt,compact
Hoover S2155--- Stick - Handy,broom,light Wt,compact
Hoover S2200--- Stick - Handy,broom,light Wt,compact
Hoover S2200001 Stick - Handy,broom,light Wt,compact
General Electric S2200Y0WW Washer
General Electric S2200Y1WW Washer
General Electric S2200Y3WW Washer
Hoover S2201--- Stick - Handy,broom,light Wt,compact
Hoover S2203--- Stick - Handy,broom,light Wt,compact
Hoover S2211--- Stick - Handy,broom,light Wt,compact
Hoover S2211100 Stick - Handy,broom,light Wt,compact
Hoover S2220--- Stick - Handy,broom,light Wt,compact
Magic Chef S22FA-2KLX Range - Cont Clean Dbl Oven Gas
Magic Chef S22FK-2KLX Range - Cont Clean Dbl Oven Gas
Magic Chef S22FN-2KLX Range - Cont Clean Dbl Oven Gas
Magic Chef S22FY-2KLX Range - Cont Clean Dbl Oven Gas
Amana S23 Freezer - Vertical
Amana S23A Freezer - Vertical
Amana S23B Freezer - Vertical
Amana S25 Freezer - Vertical
Hoover S2505--- Stick - Handy,broom,light Wt,compact
Hoover S2509--- Stick - Handy,broom,light Wt,compact
Hoover S2515
Hoover S2531--- Stick - Handy,broom,light Wt,compact
Hoover S2535--- Stick - Handy,broom,light Wt,compact
Hoover S2541--- Stick - Handy,broom,light Wt,compact
Hoover S2541040 Stick - Handy,broom,light Wt,compact
Hoover S2543--- Stick - Handy,broom,light Wt,compact
Hoover S2545--- Stick - Handy,broom,light Wt,compact
Hoover S2551--- Stick - Handy,broom,light Wt,compact
  #2 (permalink)
Old 03-27-2009, 01:34 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for JENN-AIR S136 | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag_library/docs/16000446(ER001-00).pdf
Motor looks like it should be 120 volts.
Pull it as it should be labeled as to voltage.
Check it with a meter for continuity.
Not sure what it should be but should have continuity also check each connector to it's case.
__________________
  #3 (permalink)
Old 03-27-2009, 02:47 PM
Junior Member
Default Thanks for the help.
The wireing diagram helped a lot, but I'm still a little puzzled. With a volt meter reading @the motor power cord(motor unplugged), I read 110v from L1 to neutral w/the rocker switch on. With the oven turned on(this should also turn on motor) and switch off, I read 20v L1 to N. Here's the kicker, w/both switch on and oven on, I read 230v L1 to N. I pulled off the ground wire from the lower element and found it to be hot. I surmise the ground wire is shorted to L2(not sure) putting 230v from L1 to N. , but wouldn't this trip the breaker? Any ideas? Thanks again.
  #4 (permalink)
Old 03-28-2009, 05:19 AM
Senior Expert
APP Volunteer
Default
Just to clarify, is the problem with the COOLING FAN?
It runs off the L2 side of the line
Or is it the BLOWER MOTOR which is off the L1 side.
__________________
  #5 (permalink)
Old 03-28-2009, 08:31 AM
Junior Member
Default
Its the exhaust motor.
  #6 (permalink)
Old 03-28-2009, 10:20 AM
Senior Expert
APP Volunteer
Default
OK, following is for Blower Motor upper left hand side of wiring diagram.
This looks OK. What is it with the rocker switch off?
This is probably just ghost voltage, the true reading is probably 0 volts.
Cannot see how turning the oven on will turn the fan on, as it is connected in with the surface elements not the oven.
Is this reading across the blower motor or is it at L1.
I am missing something here. There should not be a grounded wire at the element. It should run between L1 and L2, of coarse with thermostats also in this circuit path.
No, as long as there is a device to drop the voltage between these two points it will not blow a breaker.
Did this unit ever run correctly or is it new to you?
__________________
  #7 (permalink)
Old 03-28-2009, 02:25 PM
Junior Member
Default
I don't recall the voltage w/nothing on. 230v read from L1 to N at the power cord to motor (motor out of circuit). The same opening in back of oven (where L1 and L2 feed lower element) also has a green wire coming out going to screw on the frame along w/another green wire. This oven was purchased from an acquaintance who wouldn't lie (could have forgotten). Said he used it for a month or so till he closed on his house and moved in his own appliances, said it worked fine in all modes.
  #8 (permalink)
Old 03-28-2009, 04:14 PM
Senior Expert
APP Volunteer
Default
Sorry!!! hvach3-1 if I took my head out of my you know what I would have noticed this was stated in your first post.
I assume you have already checked the unit over for a loose connection or a wire that has shorted to the frame.
I would say you have a wiring problem somewhere.
So now the trick is trying to isolate it.
Might be an idea to check the wiring at the switch just to make sure it matches the wiring diagram.
Next I would unplug the stove top inserts. Do not know what you have.
Do you have 4 elements or two elements and a grill etc.?
Now try measuring the voltage at the blower plug as you did earlier.
Next unplug the unit and remove the wires from the oven elements with the elements in place. Sometimes elements can short to ground where they touch the frame re: support legs etc.
Then measure them for resistance both should be around 20 ohms.
Now measure from the elements connector to the frame should be infinite.
I find it very strange that the oven is affecting the blower.
__________________
  #9 (permalink)
Old 04-01-2009, 10:54 AM
Junior Member
Default
I was mistaking the grill for the bake element. The fan is supposed to come on w/the grill. I checked the house power, correct. I then checked the power @the terminal block w/the fan plugged in, correct. I then checked power again w/fan rocker switch on, 120v L1 to N, 120v L2 to N, 230v L1 to L2. Now when I turn on the oven, I get L1 to N nothing, and L2 to N 230v. What in the world? Well any way I've given up and dumped the stupid thing. There's no way you can think of that this could be a house wiring problem is there? I checked power @ the receptical w/the cord unplugged, I also checked that the cord was properly wired.
  #10 (permalink)
Old 04-01-2009, 11:26 AM
Senior Expert
APP Volunteer
Default
I would doubt it because everything is OK till you turn the oven on.
There is something that is wired wrong or shorted out.
One way to trouble shoot this is by disconnecting different things like the bake element etc. and continually checking the power till it checks OK.
Then it has something to do with the last device you disconnected.
I will sit down and take another look to see if I can figure out a possible cause.
Is this a 3 wire or a 4 wire electrical hook up?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Icemaker Motor Voltage ronaldasocco Refrigerator & Freezer Repair 2 12-27-2009 01:51 PM
Jenn Air Noisy---suspect air flow motor/fan dave_55 Refrigerator & Freezer Repair 0 12-20-2009 12:55 PM
jenn air dishwasher motor steveray1956 Dishwasher Repair 0 03-19-2009 06:34 AM
jenn air dishwasher motor steveray1956 Oven Repair (including Ranges and Cooktops) 0 03-19-2009 06:23 AM
no voltage telstaman Refrigerator & Freezer Repair 0 03-20-2008 09:55 AM
