:rolleyes: 2 questions:
1) The window frame around the inside has deteriorated, the metal flashing has fallen off and the seal is now falling out. Does the entire window assembly (glass and metal frame) have to be replaced? Or is this a separate hardware assembly (the seal and a metal keeper frame). It looks like I can get the window and metal frame on-line for ~$90.
2) Is it very straight forward for an appliance rookie (me) to dis-assemble the oven door to replace the window?
