Oven turns on and then goes out. Sometimes it works and sometimes it dosen't. Glow light is still on. Gas is still comming out.
Most likely the igniter become weak. It lets gas out but not enough to support normal flame. The correction is to replace the igniter. The model number you posted does not come up and I'm not able to find the correct part number for the igniter.
I found the correct model # for my oven. it is JGBP28GEJ4BG. Is the igniter the samething as the glow light? The model number on my unit has the BG at the end, is that the same as the model number on the list of numbers without the BG. I also needto replace a set of knobs for the top burners.
Thanks for the help,
Rich Delgado
Rich Delgado
Originally Posted by: Rich Delgado ...1. Is the igniter the samething as the glow light?...
...2. The model number on my unit has the BG at the end, is that the same as the model number on the list of numbers without the BG...
...3. I also needto replace a set of knobs for the top burners... 1. Yes, it is. 2. Yes, it is the same. Actually "BG" stands for the color of the range. 3. The part number for the knob is AP2030935 - The part number for the Bake igniter is AP2009619Here are the break down diagrams and Replacement parts for GE JGBP28GEJ4 | AppliancePartsPros.comGene.
