| » cooktop |
Model Number: jes8850bas Brand: Jenn-Air Age: 1 - 5 years
A burner on my cooktop is not working properly. It is a "dual burner" and the outside ring works but the inner ring does not turn on.
Do I need to replace a switch or do I need to replace the burner? Thank you. Ads By Google Related Models |
You have a selector switch to choose one or both elements. Make sure it's in the proper position.
I would inspect the element for broken coils. Sometimes you can see through the top with a good flashlight and spot a broken or burnt coil. You can also check with an ohm meter to see if it has continuity. I have swapped the wires on a switch I knew was good to check the switch. You don't have to swap the red and the black wires. UNPLUG THE OVEN FIRST |
| Display Modes | |
| remove old destroyed cooktop and install new cooktop | richlibl | Oven Repair (including Ranges and Cooktops) | 4 | 07-06-2009 10:42 PM |
| cooktop | bjackson99 | Oven Repair (including Ranges and Cooktops) | 2 | 07-02-2009 04:11 AM |
| Whirlpool glass cooktop replacement for gas cooktop | ujohnston | Oven Repair (including Ranges and Cooktops) | 3 | 03-22-2009 01:39 PM |
| Reseat Ceramic Cooktop Panel to Cooktop | Twodoh | Oven Repair (including Ranges and Cooktops) | 3 | 08-23-2008 06:05 PM |
| replacing cooktop with a smaller cooktop | oops | Oven Repair (including Ranges and Cooktops) | 3 | 08-20-2008 12:43 PM |
