Discuss
Whirlpool oven will not heat
 in
I recently self-cleaned the oven. Ever since, it will not heat at all in either bake or broil modes. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool oven will not heat
  #1 (permalink)
Old 07-31-2011, 11:13 PM
Junior Member
edgar87tsi is on a distinguished road
Default Whirlpool oven will not heat
Model Number: RBS305PDQ6   Brand: Whirlpool   Age: More than 10 years
I recently self-cleaned the oven. Ever since, it will not heat at all in either bake or broil modes. I removed the temp. sensor and unplugged it. It measures 1100 ohms at its connector contacts at room temperature. If I hold the off button (on the control panel) down for a few seconds, E2-F3- error code appears. Should I check wiring to sensor? Is it possible that both BAKE and BROIL relays have welded contacts, and would this relay condition be consistent with E2-F3- error code? Thanks.
Ads By Google
Related Models
Whirlpool RBS305PDQ6
Whirlpool RBS305PDQ8
Whirlpool RBS305PDQ9
Whirlpool RBS305PDS12
Whirlpool RBS305PDS14
Whirlpool RBS305PDS16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDS17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT10
Whirlpool RBS305PDT11
Whirlpool RBS305PDT12
Whirlpool RBS305PDT13
Whirlpool RBS305PDT14
Whirlpool RBS305PDT16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT8
Whirlpool RBS305PDT9
Whirlpool RBS305PDZ1
Whirlpool RBS305PDZ10
Whirlpool RBS305PDZ2
Whirlpool RBS305PDZ4
Whirlpool RBS305PDZ6
Whirlpool RBS305PDZ8
Whirlpool RBS305PDZ9
Whirlpool RBS305PRB00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRQ00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRS00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRT00 30" Built - in Electric Oven Self Clean
Whirlpool RBS307PDB1
Whirlpool RBS307PDB2
Whirlpool RBS307PDB4
Whirlpool RBS307PDQ1
Whirlpool RBS307PDQ2
Whirlpool RBS307PDQ4
Frigidaire RBSF117E1 BLACK Frg(v3) / Electric Cooktops and Control Box
Frigidaire RBSF117EL1 Frg(v2) / Electric Cooktops and Control Box
Frigidaire RBSF117EW1 Frg(v1) / Electric Cooktops and Control Box
Frigidaire RBSF129EL0 Frg(v4) / Electric Range
Frigidaire RBSF129EW0 Frg(v3) / Electric Range
Frigidaire RBUGCF95ED Frg(v6) / Wall Oven
Frigidaire RBUGCF95EK Frg(v7) / Wall Oven
Frigidaire RBUGCF95EW Frg(v5) / Wall Oven
Amana RC-10B Commercial Microwaves
Amana RC-10B-DD Commercial Microwaves
Amana RC-10B-PB Commercial Microwaves
Amana RC-10D Commercial Microwaves
Amana RC-10PB Commercial Microwaves
Amana RC-10S Commercial Microwaves
Amana RC-10SD Commercial Microwaves
Amana RC-10SE Commercial Microwaves
Amana RC-14 Commercial Microwaves
Amana RC-14B Commercial Microwaves
Amana RC-14S Commercial Microwaves
Amana RC-14SD Commercial Microwaves
Amana RC-14SE Commercial Microwaves
Amana RC-14T Commercial Microwaves
Amana RC-14TD Commercial Microwaves
Amana RC-14TE Commercial Microwaves
Amana RC-20 Commercial Microwaves
Amana RC-20SE Commercial Microwaves
Amana RC-6D Commercial Microwaves
Amana RC-6PB Commercial Microwaves
Amana RC-7D Commercial Microwaves
Amana RC-7PB Commercial Microwaves
Amana RC-8 Commercial Microwaves
Amana RC04880A1D Room Air Conditioner
Amana RC04880A1D REV Room Air Conditioner
Amana RC04880A1DR Room Air Conditioner
Amana RC04880A1DR REV Room Air Conditioner
Amana RC04880A1E Room Air Conditioner
Amana RC04880A1X Room Air Conditioner
Amana RC04880A1X REV Room Air Conditioner
Amana RC04880A1XR Room Air Conditioner
Amana RC04880A1XR REV Room Air Conditioner
Amana RC05010A1D Room Air Conditioner
  #2 (permalink)
Old 08-01-2011, 03:40 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL RBS305PDQ6 ELECTRIC WALL OVEN | AppliancePartsPros.com
If you disconnected it and measured it at the control board then you have checked the wiring and the sensor reads OK.
Check the connection at the control board for corrosion or a bad solder joint or a crack in the copper foil (circuit tracks).
Often a bad solder joint will be a duller gray or have pinholes or the components connection will move in the solder.
A magnifying glass helps here.
No the error is sensor related.
I am assuming that when you checked the sensor the unit was unplugged and it did not reset.
Sounds like the sensor circuit on the board is toast.
You may want to try AppliancePartsPros as you have done the troubleshooting they will let you return the board if it does not fix your problem.
See their return policy.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool oven doesn't heat bullfrog Oven Repair (including Ranges and Cooktops) 2 10-20-2011 06:46 PM
Whirlpool oven won't heat up_pilot Oven Repair (including Ranges and Cooktops) 3 01-23-2011 05:31 AM
Whirlpool gas oven won't heat jakecat Oven Repair (including Ranges and Cooktops) 0 11-14-2010 05:35 PM
Whirlpool gas oven broiler works, but oven does not bake or heat up smolesen Oven Repair (including Ranges and Cooktops) 0 03-13-2010 10:02 AM
Whirlpool oven won't heat Lamb Oven Repair (including Ranges and Cooktops) 4 08-04-2009 08:17 PM
