Discuss
Oven not working
 in
Oven will not turn on. When turning oven knob to diffenent positions there is no response or light indicting oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven not working
  #1 (permalink)
Old 07-29-2011, 03:28 PM
Junior Member
bulldogdad is on a distinguished road
Default Oven not working
Model Number: Unable to find   Brand: Tappan   Age: More than 10 years
Oven will not turn on. When turning oven knob to diffenent positions there is no response or light indicting oven is on. Elements will not heat up. Unknown if problem is with oven knob or elements are burnt out. Oven has both top and bottom element. Looked everywhere for model number but cannot find it.
Ads By Google
Related Models
Norge UNGA2H0 Range - F/s Std Gas
Norge UNGA2H1 Range - F/s Std Gas
Norge UNGA2HK0 Range - F/s Std Gas
Norge UNGA2HK1 Range - F/s Std Gas
Norge UNGA3G1 Range - F/s Std Gas
Norge UNGA3G2KV Range - F/s Std Gas
Norge UNGA3G2LNX Range - F/s Cont Clean Gas
Norge UNGA3G2LNX-BO Range - F/s Cont Clean Gas
Norge UNGA3G2NX Range - F/s Std Gas
Norge UNGA3G2NX-BO Range - F/s Std Gas
Norge UNGA6H2GLNW Range - F/s Cont Clean Gas
Norge UNGA6H2GLNW-AD Range - F/s Cont Clean Gas
Norge UNGC3G1 Range - F/s Std Gas
Norge UNGCA82-1 Range - F/s Std Gas
Norge UNGCA83-1G-11 Range - F/s Std Gas
Norge UNGCW82-1 Range - F/s Std Gas
Norge UNGCW83-1G-11 Range - F/s Std Gas
Norge UNGF3G1 Range - F/s Std Gas
Norge UNGH2HK0 Range - F/s Std Gas
Norge UNGH3G1 Range - F/s Std Gas
Norge UNGH3G2KV Range - F/s Std Gas
Norge UNGH3G2LNX Range - F/s Cont Clean Gas
Norge UNGH3G2LNX-BO Range - F/s Cont Clean Gas
Norge UNGH3G2NX Range - F/s Std Gas
Norge UNGH3G2NX-BO Range - F/s Std Gas
Norge UNGH3G2NX-NO Range - F/s Std Gas
Norge UNGHA82-1 Range - F/s Std Gas
Norge UNGHW82-1 Range - F/s Std Gas
Norge UNGW2H0 Range - F/s Std Gas
Norge UNGW2H1 Range - F/s Std Gas
Norge UNGW2HK0 Range - F/s Std Gas
Norge UNGW2HK1 Range - F/s Std Gas
Norge UNGW3G1 Range - F/s Std Gas
Norge UNGW3G2KV Range - F/s Std Gas
Norge UNGW3G2LNX Range - F/s Cont Clean Gas
Norge UNGW3G2LNX-BO Range - F/s Cont Clean Gas
Norge UNGW3G2NX Range - F/s Std Gas
Norge UNGW3G2NX-BO Range - F/s Std Gas
Norge UNGW6H2GLNW Range - F/s Cont Clean Gas
Norge UNGW6H2GLNW-AD Range - F/s Cont Clean Gas
Maytag UNVIM98 Misc / Accessory
Amana URC517MP Commercial Microwaves
Amana URCS511 Commercial Microwaves
Amana URCS511A  Commercial Microwaves
Amana URFS511 Commercial Microwaves
Amana URFS518S  Commercial Microwaves
Amana URS511 Commercial Microwaves
Amana URS511M Commercial Microwaves
Amana URS511MB  Commercial Microwaves
Amana URS511P  Commercial Microwaves
Menu Master US11EA  Commercial Microwaves
Maytag UXA1000AAB Misc / Accessory
Maytag UXA1000AAP Misc / Accessory
Maytag UXA1000AAQ Misc / Accessory
Maytag UXA1000AAW Misc / Accessory
Maytag UXA1027ADB Misc / Accessory
Maytag UXA1027ADQ Misc / Accessory
Maytag UXA1027ADW Misc / Accessory
Maytag UXA1030ADB Misc / Accessory
Maytag UXA1030ADQ Misc / Accessory
Maytag UXA1030ADW Misc / Accessory
Jenn-Air UXA9007AAB Misc / Accessory
Jenn-Air UXA9007AAQ Misc / Accessory
Jenn-Air UXA9007AAW Misc / Accessory
Maytag UXT2030AAB Hood
Maytag UXT2030AAQ Hood
Maytag UXT2030AAS Hood
Maytag UXT2030AAW Hood
Maytag UXT2036AAB Hood
Maytag UXT2036AAQ Hood
Maytag UXT2036AAS Hood
Maytag UXT2036AAW Hood
Maytag UXT3030AAB Hood
Maytag UXT3030AAQ Hood
Maytag UXT3030AAS Hood
Maytag UXT3030AAW Hood
Maytag UXT3036AAB Hood
Maytag UXT3036AAQ Hood
Maytag UXT3036AAS Hood
Maytag UXT3036AAW Hood
Maytag UXT4030AAB Hood
Maytag UXT4030AAQ Hood
Maytag UXT4030AAS Hood
Maytag UXT4030AAW Hood
Maytag UXT4036AAB Hood
Maytag UXT4036AAQ Hood
Maytag UXT4036AAS Hood
Maytag UXT4036AAW Hood
Maytag UXT5230ADB Hood
Maytag UXT5230ADQ Hood
Maytag UXT5230ADS Hood
Maytag UXT5230ADW Hood
Maytag UXT5236ADB Hood
Maytag UXT5236ADQ Hood
Maytag UXT5236ADS Hood
Maytag UXT5236ADW Hood
Maytag UXT5430ADB Hood
Maytag UXT5430ADQ Hood
Maytag UXT5430ADS Hood
Maytag UXT5430ADW Hood
Maytag UXT5436ADB Hood
Maytag UXT5436ADQ Hood
Maytag UXT5436ADS Hood
Maytag UXT5436ADW Hood
Thermador V-206
Thermador V-207
Thermador V-6
Thermador V-QT-200
Thermador V-QT-300
Thermador V-QT-400
Thermador V-QT-90
Whirlpool V125
Whirlpool V135
Frigidaire V13A Frg(v1) / Upright Freezer
  #2 (permalink)
Old 07-30-2011, 03:17 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Without a model number I do not know if I can be of much help.
Is this an oven or a range/stove?
What else if anything works?
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef Double Oven Upper oven not working scri8e Oven Repair (including Ranges and Cooktops) 18 12-30-2012 04:50 PM
Kenmore Elite oven - PF error, oven not working virginia3 Oven Repair (including Ranges and Cooktops) 1 06-24-2009 11:29 AM
ge oven not working. Oven door lock problem? Deano1 Oven Repair (including Ranges and Cooktops) 6 11-10-2008 01:02 PM
Oven not working-Stovetop working Jame Oven Repair (including Ranges and Cooktops) 8 10-08-2008 09:08 AM
Whirlpool Double Wall Oven - Top Oven Not Working bigguy Oven Repair (including Ranges and Cooktops) 6 09-18-2008 09:03 AM
