Discuss
Whirlpool Oven Fan
 in
The blower on my Whirlpool oven (microwave over single oven) is noisy. I know the replacement item number, but can
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Oven Fan
  #1 (permalink)
Old 07-29-2011, 06:55 AM
Junior Member
Duke J.. is on a distinguished road
Arrow Whirlpool Oven Fan
Model Number: GMC305PRS01   Brand: Whirlpool   Age: 5 - 10 years
The blower on my Whirlpool oven (microwave over single oven) is noisy. I know the replacement item number, but can I replace it myself as a fairly handy DIY'er? Could I just unplug the darn thing and do without? Is there a service manual available that would help me? Thanks.
Ads By Google
Related Models
Whirlpool GMC305PRS01 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PRS02 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PRT00 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PRT01 30" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC305PRY01 30" Built - in Electric Combo Sensor/sc (gold Line)
General Electric GMR02AAMABB Refrigerator
General Electric GMR02AAMAWW Refrigerator
General Electric GMR02BANABB Refrigerator
General Electric GMR02BANAWW Refrigerator
General Electric GMR02BANBBB Refrigerator
General Electric GMR02BANBWW Refrigerator
General Electric GMR02BANCBB Refrigerator
General Electric GMR02BANCWW Refrigerator
General Electric GMR02BANDBB Refrigerator
General Electric GMR02BANDWW Refrigerator
General Electric GMR02CANBWW Refrigerator
General Electric GMR03DAMAWW Refrigerator
General Electric GMR04AAMABB Refrigerator
General Electric GMR04AAMAWW Refrigerator
General Electric GMR04BANABB Refrigerator
General Electric GMR04BANAWW Refrigerator
General Electric GMR04BANBBB Refrigerator
General Electric GMR04BANBWW Refrigerator
General Electric GMR04BANCBB Refrigerator
General Electric GMR04BANCWW Refrigerator
General Electric GMR04BANDBB Refrigerator
General Electric GMR04BANDWW Refrigerator
General Electric GMR04BARABS Refrigerator
General Electric GMR04BARBBS Refrigerator
General Electric GMR04BARCBS Refrigerator
General Electric GMR04HANBBS Refrigerator
General Electric GMR04HANCBS Refrigerator
General Electric GMR04HANDBS Refrigerator
General Electric GMR04HASACS Refrigerator
General Electric GMR04HASBCS Refrigerator
General Electric GMR06AAMARWW Refrigerator
General Electric GMR06AAMBRWW Refrigerator
General Electric GMR06AAPBB Refrigerator
General Electric GMR06AAPWW Refrigerator
General Electric GMS10AAMALWW Refrigerator
General Electric GMS10AAMARWW Refrigerator
Frigidaire GMT1670AS0 Frigidaire/washer
Frigidaire GMWS1339CS0 Frigidaire/washer
General Electric GN1S15CBL Uc filtration-carbon
Norge GN31113WAM Range - F/s Std Gas
Norge GN31113WAV Range - F/s Std Gas
Norge GN3177WUA Range - F/s Std Gas
Norge GN3177WUW Range - F/s Std Gas
Norge GN3277XUA Range - F/s Std Gas
Norge GN3277XUW Range - F/s Std Gas
Norge GN3531WUA Range - F/s Std Ele
Norge GN3531WUW Range - F/s Std Ele
General Electric GNCF02H Home cond
General Electric GNCF04H Home cond
Thermador GNG12M
Thermador GNG12MW
General Electric GNPR40L00 Softners
General Electric GNPR48L00 Softners
General Electric GNRP40L00 Softners
General Electric GNRP48L00 Softners
International GNS20M82 Ref - Sxs
General Electric GNSF18Z01 Uc filtration-carbon
General Electric GNSF23Z01 Uc filtration-carbon
General Electric GNSF35Z01 Uc filtration-carbon
General Electric GNSF35Z02 Water softeners
General Electric GNSF35Z03 Water softeners
General Electric GNSF35Z04 Softners
General Electric GNSF39A01 Uc filtration-carbon
General Electric GNSF48A01 Uc filtration-carbon
General Electric GNSH45E01 Water softeners
General Electric GNSH45E02 Softners
General Electric GNSH45E03 Softners
General Electric GNSL05CBL Uc filtration-carbon
General Electric GNSL60FBL Wh filt sys
General Electric GNSM48F02 Softners
General Electric GNSM48F03 Softners
General Electric GNSR3150H0WW Washer
General Electric GNSV25CBL Uc filtration-carbon
General Electric GNSV30CCC Uc filtration-carbon
General Electric GNSV30CWW Uc filtration-carbon
General Electric GNSV70FBL
General Electric GNSV70FBL01 Wh filt sys
General Electric GNSV75FWW Wh filt sys
General Electric GNSV75WW01 Wh filt sys
International GNT15M42 Ref - Top Mount
International GNT15M42A Ref - Top Mount
International GNT15M42L Ref - Top Mount
International GNT15M42LA Ref - Top Mount
International GNT15M4XA Ref - Top Mount
International GNT15M4XH Ref - Top Mount
International GNT15M82 Ref - Top Mount
International GNT17M42 Ref - Top Mount
International GNT17M42A Ref - Top Mount
International GNT17M4XA Ref - Top Mount
International GNT17M4XH Ref - Top Mount
International GNT17M92 Ref - Top Mount
International GNT19M4XA Ref - Top Mount
International GNT19M4XH Ref - Top Mount
  #2 (permalink)
Old 07-29-2011, 11:20 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Duke,
If you unplug the power to the blower motor, you'll run the risk of damaging the control printed circuit board, and other somewhat delicate parts. Your best bet is to replace it.
Part number: AP3882906
It's a project that most DIY'rs can do, the hardest part is getting to the fan motor.
I think this will help you out,:
Disconnect the electrical power to the double oven.
Open the lower oven door.
Remove the bottom screw from each of the two side trim pieces.
To remove the side trim, pull the bottom out approximately 2˝, and slide the top down to free it from the control panel.
Remove the four double oven cabinet mounting screws (2 on each side), and pull the oven out of its mounting location so that you can access the back.
To remove the lower blower motor assembly:
Remove the upper rear cover and the lower rear cover (8 screws).
Disconnect the two wires from the lower blower motor terminals.
Remove the three air duct screws and the four mounting screws.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool oven code F3 63 oven won't turn on lkaymen Oven Repair (including Ranges and Cooktops) 5 12-19-2011 06:53 AM
whirlpool mic/oven combination lower oven always hot mail4lily Oven Repair (including Ranges and Cooktops) 1 03-17-2010 12:20 PM
Whirlpool gas oven broiler works, but oven does not bake or heat up smolesen Oven Repair (including Ranges and Cooktops) 0 03-13-2010 10:02 AM
Whirlpool Oven top range works, oven not sportsfandallas Oven Repair (including Ranges and Cooktops) 10 07-20-2009 09:19 PM
Whirlpool Double Wall Oven - Top Oven Not Working bigguy Oven Repair (including Ranges and Cooktops) 6 09-18-2008 09:03 AM
