Discuss
Dacor Oven - Interior Window Glass
 in
Hi, Homemade bread is not only delicious, it (can be) incredibly economical. That is, unless you crack the interior oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Dacor Oven - Interior Window Glass
  #1 (permalink)
Old 03-23-2009, 10:53 AM
puzidid puzidid is offline
Junior Member
puzidid is on a distinguished road
Default Dacor Oven - Interior Window Glass
Model Number: 30" Duel Fuel Range RSD30   Brand: Dacor   Age: 5 - 10 years
Homemade bread is not only delicious, it (can be) incredibly economical. That is, unless you crack the interior oven glass by spilling a little water intended to create steam which helps make for great crust!
At any rate, I need to replace the cracked interior window glass in our Dacor 30" Duel Fuel Range RSD30.
I've found a possible replacement on AppliancePartsPros.com:
Part Number: AP3395638 ($128.70)
However, I am unable to make certain this is the correct part. I called the 877 number, and talked to a parts person, however they too couldn't verify this is the correct part for my oven, and suggested I use this forum.
Does anyone have a way to verify if this is the correct part, and if not, where I might find one?
Thanks in Advance!,
Craig
Related Models
Frigidaire 30-0127-23-03 Tap(v4) / Gas Range
Frigidaire 30-1049-00-01 Tap(v1) / Gas Range
Frigidaire 30-1049-00-02 Tap(v3) / Gas Range
Frigidaire 30-1049-00-03 Tap(v5) / Gas Range
Frigidaire 30-1049-00-04 Tap(v1) / Gas Range
Frigidaire 30-1049-00-05 Tap(v1) / Gas Range
Frigidaire 30-1049-00-06 Tap(v1) / Gas Range
Frigidaire 30-1049-00-07 Tap(v1) / Gas Range
Frigidaire 30-1049-00-08 Tap(v1) / Gas Range
Frigidaire 30-1049-00-09 Tap(v3) / Gas Range
Frigidaire 30-1049-00-10 Tap(v1) / Gas Range
Frigidaire 30-1049-00-11 Tap(v1) / Gas Range
Frigidaire 30-1049-23-01 Tap(v2) / Gas Range
Frigidaire 30-1049-23-02 Tap(v4) / Gas Range
Frigidaire 30-1049-23-03 Tap(v6) / Gas Range
Frigidaire 30-1049-23-04 Tap(v2) / Gas Range
Frigidaire 30-1049-23-05 Tap(v2) / Gas Range
Frigidaire 30-1049-23-06 Tap(v2) / Gas Range
Frigidaire 30-1049-23-07 Tap(v2) / Gas Range
Frigidaire 30-1049-23-08 Tap(v2) / Gas Range
Frigidaire 30-1049-23-09 Tap(v4) / Gas Range
Frigidaire 30-1049-23-10 Tap(v2) / Gas Range
Frigidaire 30-1049-23-11 Tap(v2) / Gas Range
Frigidaire 30-1149-00-01 Tap(v1) / Gas Range
Frigidaire 30-1149-00-02 Tap(v1) / Gas Range
Frigidaire 30-1149-00-03 Tap(v3) / Gas Range
Frigidaire 30-1149-00-04 Tap(v5) / Gas Range
Frigidaire 30-1149-00-05 Tap(v1) / Gas Range
Frigidaire 30-1149-00-06 Tap(v1) / Gas Range
Frigidaire 30-1149-00-07 Tap(v3) / Gas Range
Frigidaire 30-1149-00-08 Tap(v1) / Gas Range
Frigidaire 30-1149-00-10 Tap(v1) / Gas Range
Frigidaire 30-1149-00-11 Tap(v2) / Gas Range
Frigidaire 30-1149-00-12 Tap(v1) / Gas Range
Frigidaire 30-1149-23-01 Tap(v2) / Gas Range
Frigidaire 30-1149-23-02 Tap(v2) / Gas Range
Frigidaire 30-1149-23-03 Tap(v4) / Gas Range
Frigidaire 30-1149-23-04 Tap(v6) / Gas Range
Frigidaire 30-1149-23-05 Tap(v2) / Gas Range
Frigidaire 30-1149-23-06 Tap(v2) / Gas Range
Frigidaire 30-1149-23-07 Tap(v4) / Gas Range
Frigidaire 30-1149-23-08 Tap(v2) / Gas Range
Frigidaire 30-1149-23-10 Tap(v3) / Gas Range
Frigidaire 30-1149-23-11 Tap(v4) / Gas Range
Frigidaire 30-1149-23-12 Tap(v2) / Gas Range
Frigidaire 30-2022-00-11 Tap(v1) / Gas Range
Frigidaire 30-2022-23-11 Tap(v2) / Gas Range
Frigidaire 30-2022-45-11 Tap(v3) / Gas Range
Frigidaire 30-2022-57-11 Tap(v4) / Gas Range
Frigidaire 30-2022-66-11 Tap(v5) / Gas Range
Frigidaire 30-2118-00-01 Tap(v1) / Gas Range
Frigidaire 30-2118-00-02 Tap(v4) / Gas Range
Frigidaire 30-2118-00-03 Tap(v7) / Gas Range
Frigidaire 30-2118-00-04 Tap(v10) / Gas Range
Frigidaire 30-2118-23-01 Tap(v2) / Gas Range
Frigidaire 30-2118-23-02 Tap(v5) / Gas Range
Frigidaire 30-2118-23-03 Tap(v8) / Gas Range
Frigidaire 30-2118-23-04 Tap(v11) / Gas Range
Frigidaire 30-2118-66-01 Tap(v3) / Gas Range
Frigidaire 30-2118-66-02 Tap(v6) / Gas Range
Frigidaire 30-2118-66-03 Tap(v9) / Gas Range
Frigidaire 30-2118-66-04 Tap(v12) / Gas Range
Frigidaire 30-2119-00-01 Tap(v1) / Gas Range
Frigidaire 30-2119-00-02 Tap(v4) / Gas Range
Frigidaire 30-2119-23-01 Tap(v2) / Gas Range
Frigidaire 30-2119-23-02 Tap(v5) / Gas Range
Frigidaire 30-2119-66-01 Tap(v3) / Gas Range
Frigidaire 30-2119-66-02 Tap(v6) / Gas Range
Frigidaire 30-2132-00-01 Tap(v1) / Gas Range
Frigidaire 30-2132-00-02 Tap(v1) / Gas Range
Frigidaire 30-2132-00-03 Tap(v3) / Gas Range
Frigidaire 30-2132-00-04 Tap(v1) / Gas Range
Frigidaire 30-2132-23-01 Tap(v2) / Gas Range
Frigidaire 30-2132-23-02 Tap(v2) / Gas Range
Frigidaire 30-2132-23-03 Tap(v4) / Gas Range
Frigidaire 30-2132-23-04 Tap(v2) / Gas Range
Frigidaire 30-2138-00-01 Tap(v1) / Gas Range
Frigidaire 30-2138-00-02 Tap(v4) / Gas Range
Frigidaire 30-2138-00-03 Tap(v7) / Gas Range
Frigidaire 30-2138-00-04 Tap(v1) / Gas Range
Frigidaire 30-2138-00-05 Tap(v4) / Gas Range
Frigidaire 30-2138-00-06 Tap(v7) / Gas Range
Frigidaire 30-2138-23-01 Tap(v2) / Gas Range
Frigidaire 30-2138-23-02 Tap(v5) / Gas Range
Frigidaire 30-2138-23-03 Tap(v8) / Gas Range
Frigidaire 30-2138-23-04 Tap(v2) / Gas Range
Frigidaire 30-2138-23-05 Tap(v5) / Gas Range
Frigidaire 30-2138-23-06 Tap(v8) / Gas Range
Frigidaire 30-2138-66-01 Tap(v3) / Gas Range
Frigidaire 30-2138-66-02 Tap(v6) / Gas Range
Frigidaire 30-2138-66-03 Tap(v9) / Gas Range
Frigidaire 30-2138-66-04 Tap(v3) / Gas Range
Frigidaire 30-2138-66-05 Tap(v6) / Gas Range
Frigidaire 30-2138-66-06 Tap(v9) / Gas Range
Frigidaire 30-2139-00-01 Tap(v1) / Gas Range
Frigidaire 30-2139-00-02 Tap(v3) / Gas Range
Frigidaire 30-2139-00-03 Tap(v1) / Gas Range
Frigidaire 30-2139-00-04 Tap(v3) / Gas Range
Frigidaire 30-2139-00-05 Tap(v5) / Gas Range
Frigidaire 30-2139-00-06 Tap(v1) / Gas Range
Frigidaire 30-2139-00-07 Tap(v1) / Gas Range
Frigidaire 30-2139-00-08 Tap(v3) / Gas Range
Frigidaire 30-2139-00-09 Tap(v1) / Gas Range
Frigidaire 30-2139-23-01 Tap(v2) / Gas Range
Frigidaire 30-2139-23-02 Tap(v4) / Gas Range
Frigidaire 30-2139-23-03 Tap(v2) / Gas Range
Frigidaire 30-2139-23-04 Tap(v4) / Gas Range
Frigidaire 30-2139-23-05 Tap(v6) / Gas Range
Frigidaire 30-2139-23-06 Tap(v2) / Gas Range
Frigidaire 30-2139-23-07 Tap(v2) / Gas Range
Frigidaire 30-2139-23-08 Tap(v4) / Gas Range
Frigidaire 30-2139-23-09 Tap(v2) / Gas Range
Frigidaire 30-2228-00-01 Tap(v1)
Frigidaire 30-2228-00-02 Tap(v3)
Frigidaire 30-2228-00-03 Tap(v5)
Frigidaire 30-2228-23-01 Tap(v2)
Frigidaire 30-2228-23-02 Tap(v4)
Frigidaire 30-2228-23-03 Tap(v6)
Frigidaire 30-2232-00-01 Tap(v1) / Gas Range
Frigidaire 30-2232-00-02 Tap(v1) / Gas Range
  #2 (permalink)
Old 05-31-2009, 10:55 PM
danvalemi danvalemi is offline
Junior Member
danvalemi is on a distinguished road
Default
Thanks in Advance!,
Craig
Yikes! I just did the same thing while baking bread.
I see you posted this in March. How did things work out with your glass replacement? We also have a Dacor, but I haven't even found our paperwork with the model number yet.
  #3 (permalink)
Old 05-31-2009, 11:06 PM
Junior Member
Default
I am still baking bread on a nearly daily basis, and still living with the cracked glass. I decided as long as there is a chance I will repeat the same mistake there was no point in replacing it. As soon as I master a technique in which there is no chance of the water hitting the glass (perhaps a long necked watering can), I will replace it. But really not looking forward to it!
Our oven is the Dacor 30" Duel Fuel Range RSD30. How about yours? When I get around to this again, perhaps we can share notes (and photos) on how to go about doing the replacement ourselves.
Good Luck!
c
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dacor oven window pack replacement johnamodeo Oven Repair (including Ranges and Cooktops) 0 12-30-2008 05:09 PM
Interior oven glass marty824 Oven Repair (including Ranges and Cooktops) 3 12-29-2008 03:04 PM
Dacor Oven: broken inside window, need help baqqir Oven Repair (including Ranges and Cooktops) 0 10-31-2008 11:50 AM
oven glass window scared inside omnb724 Oven Repair (including Ranges and Cooktops) 0 09-10-2008 08:06 AM
Replacing Interior Oven Door Glass ghassan Oven Repair (including Ranges and Cooktops) 1 03-21-2008 04:38 PM
