Discuss
BOSCH Oven Temperature Falls
 in
I have a bosch electric range and oven. When I use the oven, it does not hold the temperature I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » BOSCH Oven Temperature Falls
  #1 (permalink)
Old 03-23-2009, 06:36 AM
Junior Member
danthornton1 is on a distinguished road
Default BOSCH Oven Temperature Falls
Brand: Bosch   Age: 1 - 5 years
I have a bosch electric range and oven. When I use the oven, it does not hold the temperature I programmed. For instance, last night I had it on 375 and 20 minutes into the cooking, I reprogrammed to 375 and it displayed the current temperature as 338 and had to reheat to get to 375. Thanks.
  #2 (permalink)
Old 03-24-2009, 11:31 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Higher set temperature takes longer time to preheat. Depend on the oven size and age, 15 - 20 minutes to preheat to 350F is pretty normal. Preheat to 400F can take 5-10 minutes more.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-25-2009, 08:53 AM
Junior Member
Default
Gene--thanks for the response. The issue isn't reall time to preheat, it is that once the oven is preheated, it doesn't stay at the programmed temperature. I will preheat to 375, put in the lasagna, and 20 minutes later the temperature has fallen to 325. Is there a reason the temperature won't hold? THanks a lot.
  #4 (permalink)
Old 03-25-2009, 02:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In that case the temperature control is the culprit. I'm not sure which device controls the oven temperature in your oven. If there is an electronic control board then the problem is there. If there is a regular oven thermostat then the thermostat has to be replaced.
__________________
  #5 (permalink)
Old 04-02-2009, 06:05 AM
Junior Member
Default
Thanks Gene, I really appreciate your help.
  #6 (permalink)
Old 04-02-2009, 02:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Oven temperature Bad jeffdroy Oven Repair (including Ranges and Cooktops) 1 12-22-2009 11:01 PM
Gas oven intermittently shuts off, temperature falls Tombombadillo Oven Repair (including Ranges and Cooktops) 0 09-04-2009 11:44 AM
Oven Temperature Low schredder Oven Repair (including Ranges and Cooktops) 1 09-30-2008 01:51 PM
oven temperature rodrbrown Oven Repair (including Ranges and Cooktops) 0 12-08-2007 12:52 PM
oven temperature rodrbrown Oven Repair (including Ranges and Cooktops) 0 12-08-2007 12:47 PM
