Discuss
Electric Oven not heating up
 in
The first thing I would check in such situation is the power source. Check if both circuit breakers for the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electric Oven not heating up
  #11 (permalink)
Old 11-28-2007, 08:58 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Check if both circuit breakers for the oven are on.
The control board needs only 120V but it should be 240V for the heating elements to function properly.
Check if there is 120V coming to the thermal fuse.
__________________
Professional appliance repair in Los Angeles, California.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 11-29-2007, 04:35 AM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default power
when you get your meter . put the oven on bake and check your power on thebake element if you do not have 240 volts then your control board is bad. if you have 240 volts then you element is bad.
  #13 (permalink)
Old 12-02-2007, 07:50 PM
SEBISH SEBISH is offline
Junior Member
SEBISH is on a distinguished road
Default
Okay here's what I found. First off the thermal fuse (which I already replaced appears to be blown again). I do have 120V going to the fuse but of course since the fuse is blown I don't have 240V going to the elements. I did check the temp sensor and it read 1089 ohms (which is good). I also checked the elements, 26 ohms (bake) and 18 ohms (broil). According to the manual the broil should be in the 45-55 ohm reading. The bake is good. My question is why would the broil element be bad since we never use it; however, the oven started acting funny after we preformed a self-clean. Ever since the self clean the oven has not worked. Any more suggestions??? I would really prefer not to call a service tech since I'm already into it this far.
  #14 (permalink)
Old 12-02-2007, 11:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Even if you did not use the Broil mode, the broil heating element works every time when you use the Self clean.
In such situation I would recommend to replace the broil heating element due to low resistance.
Regarding the thermal fuse I would recommend to replace it one more time and not to use the Self clean any more until you will perform all checks and repairs according to the Whirlpool service pointer.
- The part number for the thermal fuse (aka thermistor) AP3008987
- The part number for the Broil heating element AP3891570
__________________
  #15 (permalink)
Old 12-10-2007, 07:45 PM
Junior Member
Default
Okay I finally ordered the above parts and received them today. The first thing I did was ohm out the new broil element and it reads the same as my existing element ~18 ohms. The Technical Services sheet says it should read 45-55 ohms. What is the problem here? I would like to replace the fuse but I'm pretty sure it will blow like the last one did, so I am at a lose at what to check next. Any suggestions?
  #16 (permalink)
Old 12-10-2007, 07:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The part you received is the OEM part made by the Whirlpool.
The 45-55 Ohms from the manual could a misprint.
The fuse on the back of the oven is a Thermal fuse and it could be blown only if the oven got overheated.
I would recommend to replace the thermal fuse and not use the self clean.
__________________
  #17 (permalink)
Old 12-11-2007, 08:26 PM
Junior Member
Default
What happens if it blows the fuse again? Where can I look before replacing the fuse?
  #18 (permalink)
Old 12-11-2007, 09:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This is not a Line fuse.
This is a Thermal fuse.
__________________
  #19 (permalink)
Old 12-12-2007, 08:44 PM
Junior Member
Default
I understand its a thermal fuse; however, I have already replaced it once and it didn't work and the fuse was blown.........SO I went ahead and replaced it again and this time I checked the fuse prior to putting it in. The oven works. I guess the original replacement fuse was defective; my fault for not checking it with a meter first.
Anyway, can I return the broil element that is still in the box? What is your return policy?
Thanks for all the help.
  #20 (permalink)
Old 12-12-2007, 08:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I do not work for the APP. I'm just the volunteer here on the forum. You have to call the customer service.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
electric oven VIN Oven Repair (including Ranges and Cooktops) 10 05-22-2008 10:05 PM
GE Electric Oven Terry C Oven Repair (including Ranges and Cooktops) 8 11-21-2007 09:15 AM
electric range oven augiem Oven Repair (including Ranges and Cooktops) 1 10-28-2007 10:59 AM
Frigidaire Electric Range Heating Element Replacement johnhmon Oven Repair (including Ranges and Cooktops) 0 10-06-2007 05:14 PM
Electric Oven bunniez Oven Repair (including Ranges and Cooktops) 1 08-21-2007 05:25 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
