Discuss
Kitchenaid Oven Not Heating After Cleaning Cycle
 in
I have a KA Superba convection oven that we have had nothing but problems with over the course of the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kitchenaid Oven Not Heating After Cleaning Cycle
  #1 (permalink)
Old 07-25-2011, 10:51 AM
Junior Member
grov672 is on a distinguished road
Default Kitchenaid Oven Not Heating After Cleaning Cycle
Model Number: KGST307HBS8   Brand: Kitchen Aid   Age: 5 - 10 years
I have a KA Superba convection oven that we have had nothing but problems with over the course of the last few years. Currently we are constantly getting the “close door” light on the display even when the door is closed (any adjustment) and we recently have had both glow starters (not certain of the terminology) replaced (oven and broiler). Last night I was reading about an unrelated issue and someone noted that their oven door was out of whack and so I gently gave a pull on the right side of the door while simultaneously pushing on the left side of the door I was gently and was amazed that the “close door” message stayed off. Excited about this simple fix, I then tried tuned the cleaning cycle and about ˝ hour into the cycle it shut off and now neither the oven nor the broiler will work and the temp on the display simply sits at low.
Based on what I have been reading on this site it could be a number of things, but I think I have a bit of variation that others either did not have or did not mention. My display works fine so I assume the display thermal fuse must be intact. The broiler will actually light as I can see a light blue flame consuming about a 12x12 area on the top of the oven, but still does not heat up.
I am hoping that it is the thermal fuse/disk on the rear of the oven and I will get the part coming asap, however I am open to any other ideas and/or calibration from the experts. I pulled the front door panel off the oven last night and made sure that something had not come unplugged, and I think everything on the door is as it should be. Wondering if I had inadvertently caused some major issues by re-tweaking the door I tweaked it back to the way it was and still the same issue.
Please advise and thank you for your time!
Ads By Google
Related Models
Whirlpool KGST307HBS8
Whirlpool KGST307HBS9
Whirlpool KGST307HBT0
Whirlpool KGST307HBT2
Whirlpool KGST307HBT3
Whirlpool KGST307HBT4
Whirlpool KGST307HBT5
Whirlpool KGST307HBT6
Whirlpool KGST307HBT8
Whirlpool KGST307HBT9
Whirlpool KGST307HWH0
Whirlpool KGST307HWH2
Whirlpool KGST307HWH3
Whirlpool KGST307HWH4
Whirlpool KGST307HWH5
Whirlpool KGST307HWH6
Whirlpool KGST307HWH8
Whirlpool KGST307HWH9
Amana KGT-591 Range - S/c S/i Ddraft Gas
Amana KGT-593 Range - S/c S/i Ddraft Gas
Amana KGT-693 Range - S/c S/i Ddraft Gas
Amana KGT341 Surface Unit - Gas
International KGU5700BS Ref - Sxs
International KGU57990KD Ref - SXS/I&W
International KGU5950BS Ref - Sxs
International KGU5955BS Ref - Sxs
International KGU6465BS Ref - SXS/I&W
International KGU6465BSW Ref - SXS/I&W
International KGU6650 Ref - SXS/I&W
International KGU6651 Ref - SXS/I&W
International KGU6655 Ref - SXS/I&W
International KGU66920 Ref - SXS/I&W
International KGU6695 Ref - SXS/I&W
International KGU66990 Ref - SXS/I&W
International KGU6700BS Ref - SXS/I&W
International KGU6940BS Ref - SXS/I&W
International KGU6945BS Ref - SXS/I&W
Whirlpool KGYE550VAL0
Whirlpool KGYE550VHT0
Whirlpool KGYE550VPL0
Whirlpool KGYE550VTO0
Whirlpool KGYE550VWH0
Whirlpool KGYE560WAL0
Whirlpool KGYE560WHT0
Whirlpool KGYE560WPL0
Whirlpool KGYE560WTO0
Whirlpool KGYE560WWH0
Whirlpool KGYE650VAL0
Whirlpool KGYE650VHT0
Whirlpool KGYE650VPL0
Whirlpool KGYE650VTO0
Whirlpool KGYE650VWH0
Whirlpool KGYE660WAL0
Whirlpool KGYE660WAL1
Whirlpool KGYE660WHT0
Whirlpool KGYE660WPL0
Whirlpool KGYE660WTO0
Whirlpool KGYE660WWH0
Whirlpool KGYE660WWH1
Whirlpool KGYE664WAL0
Whirlpool KGYE664WAL1
Whirlpool KGYE664WHT0
Whirlpool KGYE664WPL0
Whirlpool KGYE664WTO0
Whirlpool KGYE664WWH0
Whirlpool KGYE664WWH1
Whirlpool KGYE665BAL0
Whirlpool KGYE665BAL1
Whirlpool KGYE665BWH0
Whirlpool KGYE665BWH1
Whirlpool KGYE665BWH3
Whirlpool KGYE670BAL0
Whirlpool KGYE670BAL1
Whirlpool KGYE670BAL2
Whirlpool KGYE670BAL3
Whirlpool KGYE670BWH0
Whirlpool KGYE670BWH1
Whirlpool KGYE670BWH2
Whirlpool KGYE670BWH3
Whirlpool KGYE677BWH0
Whirlpool KGYE677BWH1
Whirlpool KGYE677BWH2
Whirlpool KGYE677BWH3
Whirlpool KGYE678BAL0
Whirlpool KGYE678BAL1
Whirlpool KGYE679BBL0
Whirlpool KGYE679BBL1
Whirlpool KGYE700TAL0
Whirlpool KGYE700THT0
Whirlpool KGYE700TPL0
Whirlpool KGYE700TTO0
Whirlpool KGYE700TWH0
Whirlpool KGYE750VAL0
Whirlpool KGYE750VHT0
Whirlpool KGYE750VPL0
Whirlpool KGYE750VTO0
Whirlpool KGYE750VWH0
Whirlpool KGYE760WAL0
Whirlpool KGYE760WAL1
Whirlpool KGYE760WHT0
Whirlpool KGYE760WPL0
Whirlpool KGYE760WTO0
Whirlpool KGYE760WWH0
Whirlpool KGYE760WWH1
Whirlpool KGYE767WWH0
Whirlpool KGYE770BAL0
Whirlpool KGYE770BAL1
Whirlpool KGYE770BAL2
Whirlpool KGYE770BWH0
Whirlpool KGYE770BWH1
Whirlpool KGYE770BWH2
Whirlpool KGYE777BAL1
Whirlpool KGYE777BWH0
Whirlpool KGYE777BWH1
Whirlpool KGYE777BWH2
Whirlpool KGYE778BAL0
Whirlpool KGYE778BAL1
Whirlpool KGYE778BAL2
Whirlpool KGYE800SWH1
Whirlpool KGYE800TAL0
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cleaning cycle killed our KitchenAid Superba double oven, help? plnorcal Oven Repair (including Ranges and Cooktops) 54 04-02-2013 07:47 PM
Kitchenaid oven cleaning failure jimhuiz Oven Repair (including Ranges and Cooktops) 0 03-28-2011 09:11 AM
My KitchenAid oven will not heat after cleaning Dshambo Oven Repair (including Ranges and Cooktops) 2 11-28-2010 06:53 AM
Another KitchenAid Superba stops working after cleaning cycle Artana Oven Repair (including Ranges and Cooktops) 0 02-12-2008 02:45 PM
Frigidaire oven not heating after self cleaning Ken DeLuca Oven Repair (including Ranges and Cooktops) 0 12-29-2007 02:57 PM
