I put in self cleaning and when I back, nothing was working.. In the panel outside the house the circuit breaker was on. All GFI are OK. But the control panel doesn't shows any lights. Thanks
The thermal fuse to the control panel has probably failed and needs to be replaced. I wrote about this failure in my post Kitchenaid Double Oven no Heat after Self Clean which is very similar to your Whirlpool. Give it a read and see if this sounds like what is wrong.
Thanks Brian. I opened the control panel and I found a chart. In the shutdown thermal fuse there is 6 different parts number and each one has 6 different stripe color. How can I do in order to know which one is? it is supouse to be one?
The thermal fuse you are seeing in the tech sheet is for the ones located on the back of the machine. The one I am referring to in the post linked above is connected to the control board and when it fails, the display will go out. Look at the photo on the post then locate it on your control board. A multimeter will most likely show it as an open circuit and it needs to be replaced.
