Discuss
Viking broiler ignitor problem
 in
My gas broiler does not work. I changed the ignitor - still not working. With the broiler set to "on"
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Viking broiler ignitor problem
  #1 (permalink)
Old 03-20-2009, 06:36 AM
Junior Member
skidgllfs is on a distinguished road
Default Viking broiler ignitor problem
Model Number: VGR 366   Brand: -other-   Age: More than 10 years
My gas broiler does not work. I changed the ignitor - still not working. With the broiler set to "on" I attached one probe from my multimeter to the wire that runs from the thermostat to the ignitor and the other probe to the wire that runs from the ignitor to the dual valve (essentially replacing the ignitor with the meter)I get no reading. If I attach one probe to the wire that runs from the thermostat to the ignitor and then ground the other lead from the meter on the oven frame it registers 125v. The wire that runs form the ignitor to the dual valve appears to be in good condition. The oven works fine. The thermostat has two wires - one to the broiler ignitor and another to the oven ignitor. A wire runs from each ignitor to the dual valve (oven & broiler).Any suggestions?
Ads By Google
Related Models
Amana VHC-2 RANGE- S/C S/I DDRAFT GAS
General Electric VISR208DT8WW Washer
General Electric VISR208DTAWW Washer
General Electric VISR309JT5AA Washer
General Electric VISR309JT6AA Washer
General Electric VISR309JT8AA Washer
General Electric VISR309JTAAA Washer
General Electric VJSR2070T2AB Washer
General Electric VJSR2070T2WB Washer
General Electric VJSR2070T3AB Washer
General Electric VJSR2070T3WB Washer
General Electric VJSR2070T5AB Washer
General Electric VJSR2070T5WB Washer
General Electric VJSR2070T6AB Washer
General Electric VJSR2070T6WB Washer
General Electric VJSR2070T8AB Washer
General Electric VJSR2070T8WB Washer
General Electric VJSR2070TAAB Washer
General Electric VJSR2070TAWB Washer
Gaggenau VK111-610
Gaggenau VK230-610
General Electric VKSR2100T2WW Washer
General Electric VKSR2100T3WW Washer
General Electric VKSR2100T5WW Washer
General Electric VKSR2100T6WW Washer
General Electric VKSR2100T8WW Washer
General Electric VKSR2100TAWW Washer
General Electric VKXR4100T2WW Washer
General Electric VKXR4100T3WW Washer
General Electric VKXR4100T5WW Washer
General Electric VKXR4100T6WW Washer
General Electric VKXR4100T8WW Washer
General Electric VKXR4100TAWW Washer
Gaggenau VL021-707
Gaggenau VL022-707
Gaggenau VL023-707
Gaggenau VL030-707
Gaggenau VL031-707
Gaggenau VL040-707
Gaggenau VL041-707
Gaggenau VL051-707
Gaggenau VL330-707
Gaggenau VL331-707 211100 UP
Gaggenau VL331-707upto 211099
General Electric VLD4209L15BB Dishwasher
General Electric VLD4209L15SS Dishwasher
General Electric VLD4209L15WW Dishwasher
General Electric VLD4209L20BB DISHWASHER
General Electric VLD4209L20SS DISHWASHER
General Electric VLD4209L20WW DISHWASHER
General Electric VLLR1020T0WO Washer
General Electric VLLR1020T1WO Washer
General Electric VLSR1090G0WW Washer
General Electric VLSR1090G2WW Washer
General Electric VLXR1020A0WO Washer
General Electric VLXR1020A1WO Washer
General Electric VLXR1020A2WO Washer
General Electric VLXR1020A3WO Washer
General Electric VLXR1020A4WO Washer
General Electric VLXR1020A4WW Washer
General Electric VLXR1020A5WO Washer
General Electric VLXR1020D0WO Washer
General Electric VLXR1020D2WO Washer
General Electric VLXR1020D5WO Washer
General Electric VLXR1020T2WB Washer
General Electric VLXR1020T3WB Washer
General Electric VLXR1020T4WB Washer
General Electric VLXR1020T5WB Washer
General Electric VLXR1020T8WB Washer
General Electric VLXR1020TAWB Washer
Thermador VM-275
Thermador VM-300
Thermador VM-350
Thermador VM-400
Thermador VM-410 HOOD VENTILATOR
Thermador VM-450
Magic Chef VM11A-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11B-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11B-8PDY MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11BN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11C-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11CN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11D-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11D-8P-DY MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11DN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11EB-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11EV-8P MWAVE- MOUNTED UNDER CABINET
Maytag VM12AB MWAVE- MOUNTED UNDER CABINET
Maytag VM12AM MWAVE- MOUNTED UNDER CABINET
Maytag VM12AV MWAVE- MOUNTED UNDER CABINET
Maytag VM12AV-1 MWAVE- MOUNTED UNDER CABINET
Thermador VM410
Magic Chef VM9B-8 MWAVE- MOUNTED UNDER CABINET
Frigidaire VP21AW3 Tap(v1) / Gas Range
Frigidaire VP21AW3-23 Tap(v2) / Gas Range
Frigidaire VP21AW4 Tap(v3) / Gas Range
Frigidaire VP21AW4-23 Tap(v4) / Gas Range
Frigidaire VP30AW3 Tap(v1) / Gas Range
Frigidaire VP30AW3-23 Tap(v2) / Gas Range
Frigidaire VP30AW4 Tap(v3) / Gas Range
Frigidaire VP30AW4-23 Tap(v4) / Gas Range
Frigidaire VP30BW2 Tap(v1) / Gas Range
Frigidaire VP30BW2-23 Tap(v2) / Gas Range
Frigidaire VP30BW3 Tap(v3) / Gas Range
Frigidaire VP30BW3-23 Tap(v4) / Gas Range
Frigidaire VP30CW2 Tap(v1) / Gas Range
Frigidaire VP30CW2-23 Tap(v2) / Gas Range
Frigidaire VP30CW3 Tap(v3) / Gas Range
Frigidaire VP30CW3-23 Tap(v4) / Gas Range
Frigidaire VP36DW2 Tap(v1) / Gas Range
Frigidaire VP36DW2-23 Tap(v2) / Gas Range
Frigidaire VP36DW3 Tap(v3) / Gas Range
Frigidaire VP36DW3-23 Tap(v4) / Gas Range
Thermador VQT1000 VENTILATOR
Thermador VQT600 VENTILATOR
Thermador VR-1000 VENTILATOR
Thermador VR-1400 VENTILATOR
Thermador VR-600
Thermador VR1000
Gaggenau VR122-612
  #2 (permalink)
Old 03-21-2009, 08:33 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Ok, Goodrich or Goodyear, who has the blimp? LOL!!!! No seriously, Let's do this. Unplug the oven, and put your meter on ohms, and go to the dual valve. There should be 2 terminals for the broil, and 2 for the bake. Take the 2 wires of the valveside that goes to the broil, and check for continuity. If you don't get continuity the valve would be bad. If you get a reading, and the ignitor that you put in, is good, you would then have a control problem. Tom
  #3 (permalink)
Old 03-26-2009, 05:18 PM
Junior Member
Default
What is "continuity". Also, can I check this without unplugging the range - it weighs about 300lbs and there is no way I can pull it out from the wall to unplug it.
  #4 (permalink)
Old 03-26-2009, 05:44 PM
Junior Member
Default
I was able to unplug the range. There is no continuity on the broil side of the valve. The bake side does show continuity. Does this mean I need a new dual valve?
  #5 (permalink)
Old 03-27-2009, 04:07 AM
Senior Expert
APP Volunteer
Default
that is correct. that means that the broil ignitor won't get power. you got it!!!!!!! tom
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Viking Range dreaded ignitor ISLAND Oven Repair (including Ranges and Cooktops) 1 12-21-2010 09:29 PM
Viking ignitor troubleshooting wordfool Oven Repair (including Ranges and Cooktops) 3 12-21-2010 09:28 PM
Viking cooktop ignitor Doug Camphuis Oven Repair (including Ranges and Cooktops) 0 11-28-2009 04:10 PM
Viking range ignitor won't stop dixitquedeus Oven Repair (including Ranges and Cooktops) 0 10-08-2009 08:10 PM
Substitute Oven Ignitor for Viking radialengine Oven Repair (including Ranges and Cooktops) 2 08-17-2009 05:13 PM
