Discuss
Dishwasher won't turn ON
 in
Model: 66515819990, Kenmore Ulta Wash Hi, My dishwasher suddenly refuses to turn ON. I do not see any lights in
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Dishwasher won't turn ON
  #1 (permalink)
Old 07-22-2011, 07:36 AM
Junior Member
vrajkuma is on a distinguished road
Default Dishwasher won't turn ON
Model Number: 66515819990   Brand: Kenmore   Age: 5 - 10 years
My dishwasher suddenly refuses to turn ON. I do not see any lights in the panel. I checked the circuit breaker and it seems fine. I even switched it OFF/ON. I also notice about 1.5 inches depth of water in the base of the dishwasher.
1. Could this just be a drain clog problem or drain pump issue. I see the drain pipe from dishwasher connected to the garbage disposal higher than water level in dishwasher. So I assume the pump needs to work to pump out the water. How can I test if pump is fine or get it to drain.
2. Could this be a fuse issue. How can I test if dishwasher is getting electrical power. I don't see a power receptacle to test, so the power wiring is going directly into dishwasher I assume. I don't have a meter, but a simple electrical tester. Do I need a meter to debug this
thanks. any help/pointers appreciated.
Ads By Google
Related Models
Kenmore 66515819990 DISHWASHER
Kenmore 66515819992 DISHWASHER
Kenmore 66515821690 DISHWASHER
Kenmore 66515821691 UNDERCOUNTER DISHWASHER
Kenmore 66515821692 UNDERCOUNTER DISHWASHER
Kenmore 66515822000 DISHWASHER
Kenmore 66515824000 DISHWASHER
Kenmore 66515825690 DISHWASHER
Kenmore 66515825691 UNDERCOUNTER DISHWASHER
Kenmore 66515825692 UNDERCOUNTER DISHWASHER
Kenmore 66515828690 UNDERCOUNTER DISHWASHER
Kenmore 66515828691 UNDERCOUNTER DISHWASHER
Kenmore 66515828692 UNDERCOUNTER DISHWASHER
Kenmore 66515829000 DISHWASHER
Kenmore 66515831790 DISHWASHER
Kenmore 66515831791 DISHWASHER
Kenmore 66515831792 DISHWASHER
Kenmore 66515831793 DISHWASHER
Kenmore 66515831794 DISHWASHER
Kenmore 66515832000 DISHWASHER
Kenmore 66515834000 DISHWASHER
Kenmore 66515835790 DISHWASHER
Kenmore 66515835791 DISHWASHER
Kenmore 66515835792 DISHWASHER
Kenmore 66515835793 DISHWASHER
Kenmore 66515835794 DISHWASHER
Kenmore 66515838790 DISHWASHER
Kenmore 66515838791 DISHWASHER
Kenmore 66515838792 DISHWASHER
Kenmore 66515838793 DISHWASHER
Kenmore 66515838794 DISHWASHER
Kenmore 66515839000 DISHWASHER
Kenmore 6651584990 DISHWASHER
Kenmore 6651584991 DISHWASHER
Kenmore 6651584992 DISHWASHER
Kenmore 6651584993 UNDER COUNTER DISHWASHER
Kenmore 66515862990 DISHWASHER
Kenmore 66515862992 DISHWASHER
Kenmore 6651586580 DISHWASHER
Kenmore 6651586581 DISHWASHER
Kenmore 66515867990 DISHWASHER
Kenmore 66515867992 DISHWASHER
Kenmore 66515869990 DISHWASHER
Kenmore 66515869992 DISHWASHER
Kenmore 66515872000 DISHWASHER
Kenmore 66515874000 DISHWASHER
Kenmore 6651587580 DISHWASHER
Kenmore 66515879000 DISHWASHER
Kenmore 6651587980 DISHWASHER
Kenmore 6651587981 DISHWASHER
Kenmore 6651587982 DISHWASHER
Kenmore 6651587983 DISHWASHER
Kenmore 66515882000 DISHWASHER
Kenmore 66515884000 DISHWASHER
Kenmore 6651588580 Dishwasher
Kenmore 6651588581 Dishwasher
Kenmore 6651588582 Dishwasher
Kenmore 6651588583 DISHWASHER
Kenmore 6651588584 DISHWASHER
Kenmore 66515887000 DISHWASHER
Kenmore 66515889000 DISHWASHER
Kenmore 66515891790 DISHWASHER
Kenmore 66515891791 DISHWASHER
Kenmore 66515891792 DISHWASHER
Kenmore 66515891793 DISHWASHER
Kenmore 66515891794 DISHWASHER
Kenmore 66515892100 UNDERCOUNTER DISHWASHER
Kenmore 66515894100 UNDERCOUNTER DISHWASHER
Kenmore 66515895790 DISHWASHER
Kenmore 66515895791 DISHWASHER
Kenmore 66515895792 DISHWASHER
Kenmore 66515895793 DISHWASHER
Kenmore 66515895794 DISHWASHER
Kenmore 66515898790 DISHWASHER
Kenmore 66515898791 DISHWASHER
Kenmore 66515898792 DISHWASHER
Kenmore 66515899100 UNDERCOUNTER DISHWASHER
Kenmore 6651590840 KENMORE DISHWASHER
Kenmore 66515912000 DISHWASHER
Kenmore 66515912001 DISHWASHER
Kenmore 66515914000 DISHWASHER
Kenmore 66515914001 DISHWASHER
Kenmore 6651591680 DISHWASHER
Kenmore 6651591681 DISHWASHER
Kenmore 66515919000 DISHWASHER
Kenmore 66515919001 DISHWASHER
Kenmore 66515921690 UNDERCOUNTER DISHWASHER
Kenmore 66515921691 UNDERCOUNTER DISHWASHER
Kenmore 66515921692 UNDERCOUNTER DISHWASHER
Kenmore 66515922000 DISHWASHER
Kenmore 66515922001 DISHWASHER
Kenmore 66515923000 DISHWASHER
Kenmore 66515923001 DISHWASHER
Kenmore 66515924000 DISHWASHER
Kenmore 66515924001 DISHWASHER
Kenmore 66515925690 UNDERCOUNTER DISHWASHER
Kenmore 66515925691 UNDERCOUNTER DISHWASHER
Kenmore 66515925692 UNDERCOUNTER DISHWASHER
Kenmore 66515928690 UNDERCOUNTER DISHWASHER
Kenmore 66515928691 UNDERCOUNTER DISHWASHER
Kenmore 66515928692 UNDERCOUNTER DISHWASHER
Kenmore 66515929000 DISHWASHER
Kenmore 66515929001 DISHWASHER
Kenmore 66515932000 DISHWASHER
Kenmore 66515933000 DISHWASHER
Kenmore 66515934000 DISHWASHER
Kenmore 66515937000 DISHWASHER
Kenmore 66515939000 DISHWASHER
Kenmore 665159450 HOME GYM
Kenmore 66515951790 UNDERCOUNTER DISHWASHER
Kenmore 66515951791 UNDERCOUNTER DISHWASHER
Kenmore 66515951792 UNDERCOUNTER DISHWASHER
Kenmore 66515951793 UNDERCOUNTER DISHWASHER
Kenmore 66515951794 UNDERCOUNTER DISHWASHER
Kenmore 66515952000 DISHWASHER
Kenmore 66515953000 DISHWASHER
Kenmore 66515954000 DISHWASHER
Kenmore 66515955790 DISHWASHER
Kenmore 66515955791 Dishwasher
Kenmore 66515955792 Dishwasher
  #2 (permalink)
Old 07-23-2011, 02:34 PM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for KENMORE 66515819990 | AppliancePartsPros.com
I doubt this is your problem as a drain pump will not kill power to the unit unless it has shorted out which is unlikely.
The unit is probably hard wired to the house wiring with a couple wire nuts.
This will be behind the kick plate.
You will have to remove the wire nuts and check for power just be very careful that they do not short to each other or the machine frame.
A high probability is the thermal fuse which is on the control board in the door.
Part number: AP3115186
Often they just blow on their own. If it is blown be sure to use the new harness that comes with it. Sometimes another part will cause it to go but the only real way to tell is give it a try unless you have a clamp on ammeter.
Flip the breaker to the unit. Then open up the door, remove the fuse and check it with a meter, should be 0 ohms.
I would get a meter as you can measure resistance (ohms) which is a lot safer as the power is off. Also it gives more info than what you have.
You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
  #3 (permalink)
Old 07-23-2011, 08:16 PM
Junior Member
Default
Thank You. I will try out the fuse with multimeter and order part if broken.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher will not turn on flyingdragonslayer Dishwasher Repair 0 07-10-2011 06:01 PM
LG Dishwasher will not turn on edryman Dishwasher Repair 2 05-18-2011 05:05 PM
Dishwasher won't turn on. Dmccray Dishwasher Repair 1 01-11-2010 01:50 PM
dishwasher will not turn on Tommi Dishwasher Repair 1 11-11-2009 04:09 AM
Dishwasher doesn't turn on alexander_tait Dishwasher Repair 0 09-27-2009 07:05 PM
