Discuss
Tappan Oven
 in
The stove top works, the broiler works, the oven does not always ignite with the first try. Could this be
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Tappan Oven
  #1 (permalink)
Old 11-20-2007, 06:11 PM
Chuck McCance Chuck McCance is offline
Junior Member
Chuck McCance is on a distinguished road
Default Tappan Oven
Model Number: 30-3991-00-02   Brand: Tappan   Age: More than 10 years
The stove top works, the broiler works, the oven does not always ignite with the first try. Could this be an igniter issue?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-20-2007, 06:54 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad igniter.
- The part number for the oven igniter AP2150412
- Here are the break down diagrams for the Tappan range Model 30-3991-00-02
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-20-2007, 09:27 PM
Junior Member
Default
Thanks Gene. Do i get to this part from inside the oven?, the back?, front?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
tappan ali12414 Oven Repair (including Ranges and Cooktops) 0 11-03-2007 11:03 AM
Tappan Range Butch Oven Repair (including Ranges and Cooktops) 0 10-29-2007 06:37 PM
Tappan Wall Oven Temp adjustment jmdrapeau Oven Repair (including Ranges and Cooktops) 1 09-29-2007 12:15 PM
Tappan Wall Oven jake Oven Repair (including Ranges and Cooktops) 3 08-13-2007 11:53 PM
Tappan by Frigidaire Gas range jbonatesta Oven Repair (including Ranges and Cooktops) 1 08-08-2007 05:23 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
