Discuss
F1 failure code in self clean mode only
 in
I have a range that displays F1 error code ONLY when in self cleaning mode after 1 1/2 hrs.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » F1 failure code in self clean mode only
  #1 (permalink)
Old 11-20-2007, 06:01 PM
scruffydog scruffydog is offline
Junior Member
scruffydog is on a distinguished road
Default F1 failure code in self clean mode only
Model Number: PLCS389DCB   Brand: Frigidaire   Age: 1 - 5 years
I have a range that displays F1 error code ONLY when in self cleaning mode after 1 1/2 hrs. Otherwise range works perfectly. When attempting to buy EOC part on ApplianceParts website, there are similar model numbers as PLCS389DCB but none exact. This slide-in range has a gas stove top with an electric convection oven. Is this a special oven and I have to get part from manufacturer? Or can you recommend other vendors?
Thanks!
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-20-2007, 06:50 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would recommend to replace is the oven temperature sensor (aka the temperature probe), not the EOC. Also check the wire harness from the sensor to the EOC.
- The part number for the oven temperature sensor AP3363354
- The part number for the EOC (just in case) AP3581500
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-27-2007, 05:36 PM
Junior Member
Default How reliable are the oven failure codes?
Thanks Gene!
If the problem is the temperature sensor as you indicate, wouldn't the unit generate a different failure code?
A different way to ask the same question: How accurate / reliable are the oven error codes?
  #4 (permalink)
Old 11-27-2007, 05:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
They are pretty accurate but you have to know how to understand them.
__________________
  #5 (permalink)
Old 11-27-2007, 06:30 PM
judy shultz judy shultz is offline
Junior Member
judy shultz is on a distinguished road
Default
how can I get a manual for my gallery stove? Someone gave it to me but no instructions . I'm trying to clean the self cleaning oven but......
  #6 (permalink)
Old 11-27-2007, 07:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I need the complete model number of the product.
Post it as a new thread, please.
__________________
  #7 (permalink)
Old 12-13-2007, 02:30 PM
Junior Member
Default Possible to repair unit in place?
I'm going to try to repair this. Because of the tight fit, I'd rather not slide out this unit to repair it if I don't have to. To access the EOC and inspect wiring harness, could I just remove the top? Is this possible?
Are there disassembly instructions available somewhere?
  #8 (permalink)
Old 12-13-2007, 08:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm afraid you would not get full access to the oven sensor and its wires from the front of the unit.
You can try.
And forget about EOC for a while. Do the oven sensor first.
__________________
  #9 (permalink)
Old 12-13-2007, 08:29 PM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default Frigidaire gallery stove...
Quote:
if you goto Frigidaire.com, usually somewhere around the customer support tab, there is a way to get manuals for most models ( have exact model # )
jim
  #10 (permalink)
Old 12-27-2007, 12:20 PM
Junior Member
Default
Replacing the oven probe cured the problem.
Thanks Gene!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bake mode does not maintain set temperature good28 Oven Repair (including Ranges and Cooktops) 13 09-30-2008 12:07 PM
Stove doesn't work after self-cleaning mode alfrenzel Oven Repair (including Ranges and Cooktops) 9 12-13-2007 09:48 PM
Sensor Dry Mode drew Dryer Repair 1 12-13-2007 08:32 PM
fried by power failure? tonyfix Oven Repair (including Ranges and Cooktops) 0 10-06-2007 03:23 PM
Maytag - Dryer not heating timer mode freebird Dryer Repair 0 08-16-2007 12:06 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
