Discuss
Stoves burner sparking and little box to connect burns up
 in
My burner sparks when I turn it on! I have had to replace this one 3 times cause the box
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Stoves burner sparking and little box to connect burns up
  #1 (permalink)
Old 07-20-2011, 01:26 PM
Junior Member
kimgnz6 is on a distinguished road
Default Stoves burner sparking and little box to connect burns up
Model Number: 79091062601   Brand: Kenmore   Age: 5 - 10 years
My burner sparks when I turn it on! I have had to replace this one 3 times cause the box its plugged into melts/burns up and corodes (spell check). It only happens to this one but now it has become a fire hazard. Before it was occasionally that it would spark but since we have installed this last one it does it everytime I turn it on.
I would hate to have to replace the entire thing cause everything else works perfectly.
Im wondering if there is something that could be shorting the little black box or if I will need to replace it?
Thank you, Kim
Related Models
Kenmore 79091062601 ELECTRIC RANGE
Kenmore 79091062602 ELECTRIC RANGE
Kenmore 79091062603 ELECTRIC RANGE
Kenmore 79091062604 ELECTRIC RANGE
Kenmore 79091063700 ELECTRIC RANGE
Kenmore 79091063701 ELECTRIC RANGE
Kenmore 79091063702 ELECTRIC RANGE
Kenmore 79091063703 ELECTRIC RANGE
Kenmore 79091063704 ELECTRIC RANGE
Kenmore 79091063705 ELECTRIC RANGE
Kenmore 79091064600 ELECTRIC RANGE
Kenmore 79091064601 ELECTRIC RANGE
Kenmore 79091064602 ELECTRIC RANGE
Kenmore 79091069600 ELECTRIC RANGE
Kenmore 79091069601 ELECTRIC RANGE
Kenmore 79091069602 ELECTRIC RANGE
Kenmore 79091069603 ELECTRIC RANGE
Kenmore 79091069604 ELECTRIC RANGE
Kenmore 79091072600 ELECTRIC RANGE
Kenmore 79091072601 ELECTRIC RANGE
Kenmore 79091072602 ELECTRIC RANGE
Kenmore 79091072603 ELECTRIC RANGE
Kenmore 79091073700 ELECTRIC RANGE
Kenmore 79091073701 ELECTRIC RANGE
Kenmore 79091073702 ELECTRIC RANGE
Kenmore 79091073703 ELECTRIC RANGE
Kenmore 79091074600 ELECTRIC RANGE
Kenmore 79091074601 ELECTRIC RANGE
Kenmore 79091074602 ELECTRIC RANGE
Kenmore 79091079600 ELECTRIC RANGE
Kenmore 79091079601 ELECTRIC RANGE
Kenmore 79091079602 ELECTRIC RANGE
Kenmore 79091079603 ELECTRIC RANGE
Kenmore 79091102000 ELECTRIC RANGE
Kenmore 79091102001 ELECTRIC RANGE
Kenmore 79091105890 ELECTRIC RANGE
Kenmore 79091105891 ELECTRIC RANGE
Kenmore 79091105892 ELECTRIC RANGE
Kenmore 79091106890 ELECTRIC RANGE
Kenmore 79091106891 ELECTRIC RANGE
Kenmore 79091106892 RANGE
Kenmore 79091107000 ELECTRIC RANGE
Kenmore 79091107001 ELECTRIC RANGE
Kenmore 7909115892 ELECTRIC RANGE
Kenmore 7909116892 ELECTRIC RANGE
Kenmore 79091312010 ELECTRIC RANGE
Kenmore 79091312011 ELECTRIC RANGE
Kenmore 79091312012 ELECTRIC RANGE
Kenmore 79091312013 ELECTRIC RANGE
Kenmore 79091313010 ELECTRIC RANGE
Kenmore 79091313011 ELECTRIC RANGE
Kenmore 79091313012 ELECTRIC RANGE
Kenmore 79091313013 ELECTRIC RANGE
Kenmore 79091314010 ELECTRIC RANGE
Kenmore 79091314011 ELECTRIC RANGE
Kenmore 79091314012 ELECTRIC RANGE
Kenmore 79091314013 ELECTRIC RANGE
Kenmore 79091319010 ELECTRIC RANGE
Kenmore 79091319011 ELECTRIC RANGE
Kenmore 79091319012 ELECTRIC RANGE
Kenmore 79091319013 ELECTRIC RANGE
Kenmore 79091412010 ELECTRIC RANGE
Kenmore 79091412011 SEARS/RANGE 0582
Kenmore 79091412012 ELECTRIC RANGE
Kenmore 79091412015 ELECTRIC RANGE
Kenmore 79091413010 ELECTRIC RANGE
Kenmore 79091413011 ELECTRIC RANGE
Kenmore 79091413013 ELECTRIC RANGE
Kenmore 79091414010 ELECTRIC RANGE
Kenmore 79091414011 SEARS/RANGE 0582
Kenmore 79091414012 ELECTRIC RANGE
Kenmore 79091414015 ELECTRIC RANGE
Kenmore 79091419010 ELECTRIC RANGE
Kenmore 79091419012 ELECTRIC RANGE
Kenmore 79091419015 ELECTRIC RANGE
Kenmore 79092102010 ELECTRIC RANGE
Kenmore 79092102011 ELECTRIC RANGE
Kenmore 79092102012 ELECTRIC RANGE
Kenmore 79092109010 ELECTRIC RANGE
Kenmore 79092109011 ELECTRIC RANGE
Kenmore 79092109012 ELECTRIC RANGE
Kenmore 79092163010 ELECTRIC RANGE
Kenmore 79092163012 ELECTRIC RANGE
Kenmore 79092183010 ELECTRIC RANGE
Kenmore 79092183011 ELECTRIC RANGE
Kenmore 79092202011 ELECTRIC RANGE
Kenmore 79092202012 ELECTRIC RANGE
Kenmore 79092202013 ELECTRIC RANGE
Kenmore 79092202014 ELECTRIC RANGE
Kenmore 79092203010 ELECTRIC RANGE
Kenmore 79092203011 ELECTRIC RANGE
Kenmore 79092203012 ELECTRIC RANGE
Kenmore 79092203013 ELECTRIC RANGE
Kenmore 79092204011 ELECTRIC RANGE
Kenmore 79092204012 ELECTRIC RANGE
Kenmore 79092204013 ELECTRIC RANGE
Kenmore 79092204014 ELECTRIC RANGE
Kenmore 79092208012 ELECTRIC RANGE
Kenmore 79092208014 ELECTRIC RANGE
Kenmore 79092209012 ELECTRIC RANGE
Kenmore 79092209013 ELECTRIC RANGE
Kenmore 79092209014 ELECTRIC RANGE
Kenmore 79092302010 ELECTRIC RANGE
Kenmore 79092302011 ELECTRIC RANGE
Kenmore 79092302012 ELECTRIC RANGE
Kenmore 79092303010 ELECTRIC RANGE
Kenmore 79092303011 ELECTRIC RANGE
Kenmore 79092303012 ELECTRIC RANGE
Kenmore 79092309010 ELECTRIC RANGE
Kenmore 79092309011 ELECTRIC RANGE
Kenmore 79092309012 ELECTRIC RANGE
Kenmore 79092310100 ELECTRIC RANGE
Kenmore 79092311100 ELECTRIC RANGE
Kenmore 79092312100 ELECTRIC RANGE
Kenmore 79092312300 ELECTRIC RANGE
Kenmore 79092312301 ELECTRIC RANGE
Kenmore 79092312302 ELECTRIC RANGE
Kenmore 79092312303 ELECTRIC RANGE
Kenmore 79092312305 ELECTRIC RANGE
Kenmore 79092312306 ELECTRIC RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
One Burner not sparking brm98072 Oven Repair (including Ranges and Cooktops) 6 01-18-2011 12:54 PM
9' Burner only burns HOT!! BurningHOT Oven Repair (including Ranges and Cooktops) 0 10-21-2009 05:01 AM
Gas burner ignites, burns, shuts off, repeat llew Dryer Repair 5 06-18-2009 03:11 PM
GE burner sparking after spill mbmarsh Oven Repair (including Ranges and Cooktops) 1 05-27-2009 06:33 PM
gas burner ignites, burns , goes out Studly Dryer Repair 0 05-10-2009 05:09 PM
