Discuss
Joe Wills
 in
Oven goes off sometimes when baking/broiling. When this happens clock and temp indicator go off. Oven comes back on usually
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Joe Wills
  #1 (permalink)
Old 07-20-2011, 09:45 AM
Junior Member
Joe Wills is on a distinguished road
Default Joe Wills
Model Number: MES5770AAQ   Brand: Maytag   Age: More than 10 years
Oven goes off sometimes when baking/broiling. When this happens clock and temp indicator go off. Oven comes back on usually after a few minutes or after we tap on cooktop bezel.
When clock comes back on, it has lost the minutes it was out, does not flash 12:00 as if power was completely lost. Oven temp must be reset.
If it goes out for 5 mins, for example, at 5:05, it comes back showing that time although other clocks will have advanced to 5:10.
What could cause this; what part should be replaced to fix this?
HELP!
Joe
Ads By Google
Related Models
Maytag MES5770AAQ Range - S/c S/i Ele
Maytag MES5770AAW Range - S/c S/i Ele
Maytag MES5770ACB Range - S/c S/i Ele
Maytag MES5770ACW Range - S/c S/i Ele
Maytag MES5775BAB Range - S/i Std Ele
Maytag MES5775BAF Range - S/i Std Ele
Maytag MES5775BAN Range - S/i Std Ele
Maytag MES5775BAS Range - S/i Std Ele
Maytag MES5775BCB Range - F/s Std Ele
Maytag MES5775BCF Range - F/s Std Ele
Maytag MES5775BCW Range - F/s Std Ele
Maytag MES5870AAA Range - S/c S/i Ele
Maytag MES5870AAB Range - S/c S/i Ele
Maytag MES5870AAC Range - S/c S/i Ele
Maytag MES5870AAQ Range - S/c S/i Ele
Maytag MES5870AAW Range - S/c S/i Ele
Maytag MES5870ACB Range - S/c S/i Ele
Maytag MES5870ACW Range - S/c S/i Ele
Maytag MES5875BAB Range - S/i Std Ele
Maytag MES5875BAF Range - S/i Std Ele
Maytag MES5875BAN Range - S/i Std Ele
Maytag MES5875BAS Range - S/i Std Ele
Maytag MES5875BCB Range - F/s Std Ele
Maytag MES5875BCF Range - F/s Std Ele
Maytag MES5875BCS Range - F/s Std Ele
Maytag MES5875BCW Range - F/s Std Ele
Whirlpool MET3800TW0 Washer/dryer Laundry System
Maytag MET3800TW0 Washer/dryer Laundry System
Whirlpool MET3800TW1 Washer/dryer Laundry System
Maytag MET3800TW1 Washer/dryer Laundry System
Maytag MEV41F-10P Mwave - Cntrtp / Stand Alone
Maytag MEW5527BAB Walloven - S/c Ele
Maytag MEW5527BAW Walloven - S/c Ele
Maytag MEW5527DDB Walloven - S/c Ele
Maytag MEW5527DDW Walloven - S/c Ele
Maytag MEW5530AAB Walloven - S/c Ele
Maytag MEW5530AAW Walloven - S/c Ele
Maytag MEW5530ACB Walloven - S/c Ele
Maytag MEW5530ACW Walloven - S/c Ele
Maytag MEW5530BAB Walloven - S/c Ele
Maytag MEW5530BAW Walloven - S/c Ele
Maytag MEW5530BCB Walloven - S/c Ele
Maytag MEW5530BCW Walloven - S/c Ele
Maytag MEW5530DDB Walloven - S/c Ele
Maytag MEW5530DDW Walloven - S/c Ele
Maytag MEW5627BAB Walloven - S/c Ele
Maytag MEW5627BAW Walloven - S/c Ele
Maytag MEW5627DDB Walloven - S/c Dbl Oven Ele
Maytag MEW5627DDW Walloven - S/c Dbl Oven Ele
Maytag MEW5630BAB Walloven - S/c Ele
Maytag MEW5630BAW Walloven - S/c Ele
Maytag MEW5630DDB Walloven - S/c Dbl Oven Ele
Maytag MEW5630DDW Walloven - S/c Dbl Oven Ele
Maytag MEW6527BAB Walloven - S/c Ele
Maytag MEW6527BAC Walloven - S/c Ele
Maytag MEW6527BAQ Walloven - S/c Ele
Maytag MEW6527BAS Walloven - S/c Ele
Maytag MEW6527BAW Walloven - S/c Ele
Maytag MEW6527CAS Walloven - S/c Ele
Maytag MEW6527DDB Walloven - S/c Ele
Maytag MEW6527DDQ Walloven - S/c Ele
Maytag MEW6527DDS Walloven - S/c Ele
Maytag MEW6527DDW Walloven - S/c Ele
Maytag MEW6530AAB Walloven - S/c Ele
Maytag MEW6530AAW Walloven - S/c Ele
Maytag MEW6530ACB Walloven - S/c Ele
Maytag MEW6530ACW Walloven - S/c Ele
Maytag MEW6530BAB Walloven - S/c Ele
Maytag MEW6530BAC Walloven - S/c Ele
Maytag MEW6530BAQ Walloven - S/c Ele
Maytag MEW6530BAS Walloven - S/c Ele
Maytag MEW6530BAW Walloven - S/c Ele
Maytag MEW6530BCB Walloven - S/c Ele
Maytag MEW6530BCW Walloven - S/c Ele
Maytag MEW6530CAS Walloven - S/c Ele
Maytag MEW6530DDB Walloven - S/c Ele
Maytag MEW6530DDQ Walloven - S/c Ele
Maytag MEW6530DDS Walloven - S/c Ele
Maytag MEW6530DDW Walloven - S/c Ele
Maytag MEW6627BAB Walloven - S/c Ele
Maytag MEW6627BAC Walloven - S/c Ele
Maytag MEW6627BAQ Walloven - S/c Ele
Maytag MEW6627BAS Walloven - S/c Ele
Maytag MEW6627BAW Walloven - S/c Ele
Maytag MEW6627CAS Walloven - S/c Ele
Maytag MEW6627DDB Walloven - S/c Dbl Oven Ele
Maytag MEW6627DDQ Walloven - S/c Dbl Oven Ele
Maytag MEW6627DDS Walloven - S/c Dbl Oven Ele
Maytag MEW6627DDW Walloven - S/c Dbl Oven Ele
Maytag MEW6630BAB Walloven - S/c Ele
Maytag MEW6630BAC Walloven - S/c Ele
Maytag MEW6630BAQ Walloven - S/c Ele
Maytag MEW6630BAS Walloven - S/c Ele
Maytag MEW6630BAW Walloven - S/c Ele
Maytag MEW6630CAS Walloven - S/c Ele
Maytag MEW6630DDB Walloven - S/c Dbl Oven Ele
Maytag MEW6630DDQ Walloven - S/c Dbl Oven Ele
Maytag MEW6630DDS Walloven - S/c Dbl Oven Ele
Maytag MEW6630DDW Walloven - S/c Dbl Oven Ele
Uni MEX731CFS0 Universal/laundry Center
Frigidaire MF18P2 Frg(v1) / 18 " Dishwasher
Frigidaire MF18PA2 Frg(v4) / 18 " Dishwasher
Frigidaire MF18PF2 Frg(v3) / 18 " Dishwasher
Frigidaire MF18PH2 Frg(v2) / 18 " Dishwasher
Frigidaire MF18PW2 Frg(v5) / 18 " Dishwasher
Frigidaire MFC05M0AW0 Frg(v1) / Chest Freezer
Frigidaire MFC05M0BW0 Frg(v1) / Chest Freezer
Frigidaire MFC05M0BW1 Wwh(v1) / Freezer
Frigidaire MFC05M0BW2 Wwh(v2) / Freezer
Frigidaire MFC05M0BW3 Frg(v0) / Freezer
Frigidaire MFC05M0BW4 Frg(v0) / Freezer
Frigidaire MFC05M0BW5 Frg(v0) / Freezer
Frigidaire MFC05M0BW6 Frigidaire/freezer
Frigidaire MFC05M1AW0 Frg(v1) / Chest Freezer
Frigidaire MFC05M1BW0 Frg(v1) / Chest Freezer
Frigidaire MFC05M1BW1 Kel(v1) / Chest Freezer
Frigidaire MFC05M1BW2 Wwh(v1) / Freezer
Frigidaire MFC05M1FW0 Frg(v0) / Freezer
Frigidaire MFC05M1FW1 Frg(v0) / Freezer
Frigidaire MFC05M3B Wwh(v0) / Chest Freezer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
