| » Control Pad or Circuit Board Problem? |
Model Number: GW395LEP00 Brand: Whirlpool Age: 1 - 5 years
Suddenly my oven controls will not work. The touch pad's buttons will not all work...some do...some don't. The clock cannot be set. The 'lock' and 'unlock' functions work, the 'start', 'clear', temp 'down' buttons beep, but do nothing else. There is a display seen for the lock/unlock and the only other time the display lights is when I disconnect the lead from the control panel to the circuit board and it displays 'E1 F2, which just tells me the panel is disconnected from the board. I need to determine if this is a circuit board or control panel problem. Any suggestions as to how I can do this...or is my description of the problem sufficient for you to give an opinion?
Thanks... Ads By Google Related Models |
There is an error in the model number you posted. Between "P" and "0" suppose to be one more letter. Verify the model number and post it back.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Gene:
Thank you very much for the reply to my question re. the control pad. After posting my question I found out my wife had a pot boil over yesterday. I saw no sign of dirt or moisture when I first took the control panel apart but, as the touchpad itself is a sealed unit, I heated it slightly for a couple of hours...and now it's working fine! Thanks again! |
Louis Luu,
When and how it beeps? Does it only beep or it shows any error code? Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FEB386WECH Frg(v0) / Wall Oven | AppliancePartsPros.com Gene.
__________________
Quote:
Gene, I have a FRIGIDAIRE oven model gleb30s8aba. I got the F1 code for a few weeks and was always able to reset. The oven control buttons stopped working. Only the clock works. I've replace the control unit, yet the clock is still the only thing working. Any ideas? |
Very likely the problem is a shorted keypad which is a part of the control panel.
- The control panel Part number: AP2127538 Gene.
__________________
Quote:
I've replaced the control board. How do I test the new board to verify if the keypad is shorted? |
The "F1" error code means "control failure". Control in your model consists of two parts: control board and control panel.
If the oven control buttons stopped working (per your description on the problem) then the first failure suspect is the control panel with keypad. At least this is the part I would replace first. There are no instrumental tests provided by the manufacturer for such situation. Gene.
__________________
| Display Modes | |
| Control Board Problem?? | tps43 | Microwave Repair | 0 | 01-16-2010 02:21 PM |
| Control Panel/Circuit Board | S.Lynch55 | Washer Repair | 0 | 04-05-2009 02:44 PM |
| Control Board Problem | watsjo | Oven Repair (including Ranges and Cooktops) | 0 | 06-20-2008 05:23 AM |
| Control Board Problem? | anacaparob | Oven Repair (including Ranges and Cooktops) | 7 | 01-24-2008 07:16 AM |
| Replacing control panel circuit board | vickie | Dishwasher Repair | 1 | 01-14-2008 02:51 AM |
