Discuss
Need new door seal--part discontinued
 in
Manufacturing # for oven door seal: 5303285764 Tappan oven made by Frigidaire The rubber seal between the oven and the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Need new door seal--part discontinued
  #1 (permalink)
Old 07-19-2011, 04:16 PM
Junior Member
NaturalMomma is on a distinguished road
Default Need new door seal--part discontinued
Model Number: MGF500PBDF   Brand: Tappan   Age: More than 10 years
5303285764
The rubber seal between the oven and the door has dissintegrated, We have one of the 3 lengths intact, but beginning to crack. The replacement part has been discontinued and no dimensions are offered for a common part. I am hoping you can inform us of how we can repair this and answer some safety concerns.
When I reported this to my land lord, he wanted to glue the rubber pieces back in. First of all, they are cracked and crumbled and no longer functional. Second of all, isn't glue flammable and wouldn't this risk a fire? On looking at the oven there are actually slots for these rubber strips to attach into. If only we can find a comparable part? Do you have any suggestions? I assume I would need to measure the spaces between the attachment slots. Would it be safe to use another part with a similar length, width and thickness? Are there any concerns about the material being different and not designed for that specific oven?
Also, I have used the oven twice now without this seal. Much heat escapes. The door itself and the knobs for the range control get very hot and I need to be careful not to touch them while the oven is on. I'm afraid we might be using a significant amount more of gas for the oven and then the kitchen gets so hot we need more cooling. I've experienced these concerns firsthand. Are there any additional concerns of using the oven without the door seal? Is it a fire hazard? Should I not be using it at all until it is repaired? Or is it safe with some precautions taken like being aware of the heat of the door?
Please tell me your recommendations. Wanting to be able to cook safely.
Much appreciation,
Liz
Ads By Google
Related Models
Frigidaire MGF500PBWA Frg(v3) / Gas Range
Frigidaire MGF500PBWB Frg(v5) / Gas Range
Frigidaire MGF500PBWC Frg(v6) / Gas Range
Maytag MGIMKS Misc / Accessory
Maytag MGIMKT Misc / Accessory
Maytag MGR1100ADW Range - F/s Std Gas
Maytag MGR1320ADA Range - F/s Std Gas
Maytag MGR1320ADW Range - F/s Std Gas
Maytag MGR1320BDW Range - F/s Std Gas
Maytag MGR2320ADA Range - F/s Cont Clean Gas
Maytag MGR2320ADW Range - F/s Cont Clean Gas
Maytag MGR4220ADW Range - S/c F/s Gas
Maytag MGR4410ADH Range - F/s Std Gas
Maytag MGR4410ADL Range - F/s Std Gas
Maytag MGR4410ADW Range - F/s Std Gas
Maytag MGR4410BDA Range - F/s Std Gas
Maytag MGR4410BDQ Range - F/s Std Gas
Maytag MGR4410BDW Range - F/s Std Gas
Maytag MGR4411BDQ Range - F/s Std Gas
Maytag MGR4411BDW Range - F/s Std Gas
Maytag MGR4450ADH Range - F/s Std Gas
Maytag MGR4450ADL Range - F/s Std Gas
Maytag MGR4450ADW Range - F/s Std Gas
Maytag MGR4450BDA Range - F/s Std Gas
Maytag MGR4450BDQ Range - F/s Std Gas
Maytag MGR4450BDW Range - F/s Std Gas
Maytag MGR4451ADB Range - F/s Std Gas
Maytag MGR4451ADQ Range - F/s Std Gas
Maytag MGR4451ADS Range - F/s Std Gas
Maytag MGR4451ADW Range - F/s Std Gas
Maytag MGR4451BDB Range - F/s Std Gas
Maytag MGR4451BDQ Range - F/s Std Gas
Maytag MGR4451BDS Range - F/s Std Gas
Maytag MGR4451BDW Range - F/s Std Gas
Maytag MGR4452ADB Range - F/s Std Gas
Maytag MGR4452ADQ Range - F/s Std Gas
Maytag MGR4452ADS Range - F/s Std Gas
Maytag MGR4452ADW Range - F/s Std Gas
Maytag MGR4452BDB Range - S/c F/s Gas
Maytag MGR4452BDQ Range - S/c F/s Gas
Maytag MGR4452BDS Range - S/c F/s Gas
Maytag MGR4452BDW Range - S/c F/s Gas
Maytag MGR4770ADH Range - F/s Std Gas
Maytag MGR4770ADL Range - F/s Std Gas
Maytag MGR4770ADW Range - F/s Std Gas
Maytag MGR5510ADH Range - S/c F/s Gas
Maytag MGR5510ADL Range - S/c F/s Gas
Maytag MGR5510ADW Range - S/c F/s Gas
Maytag MGR5710ADQ Range - S/c F/s Gas
Maytag MGR5710ADW Range - S/c F/s Gas
Maytag MGR5720ADH Range - S/c F/s Gas
Maytag MGR5720ADL Range - S/c F/s Gas
Maytag MGR5720ADT Range - S/c F/s Gas
Maytag MGR5720ADW Range - S/c F/s Gas
Maytag MGR5720BDQ Range - S/c F/s Gas
Maytag MGR5720BDW Range - S/c F/s Gas
Maytag MGR5721BDQ Range - S/c F/s Gas
Maytag MGR5721BDW Range - S/c F/s Gas
Maytag MGR5729ADA Range - S/c F/s Gas
Maytag MGR5729ADH Range - S/c F/s Gas
Maytag MGR5729ADL Range - S/c F/s Gas
Maytag MGR5729ADQ Range - S/c F/s Gas
Maytag MGR5729ADT Range - S/c F/s Gas
Maytag MGR5729ADW Range - S/c F/s Gas
Maytag MGR5730ADA Range - S/c F/s Gas
Maytag MGR5730ADH Range - S/c F/s Gas
Maytag MGR5730ADQ Range - S/c F/s Gas
Maytag MGR5730ADW Range - S/c F/s Gas
Maytag MGR5730BDB Range - S/c F/s Gas
Maytag MGR5730BDQ Range - S/c F/s Gas
Maytag MGR5730BDW Range - S/c F/s Gas
Maytag MGR5745ADA Range - S/c F/s Gas
Maytag MGR5745ADB Range - S/c F/s Gas
Maytag MGR5745ADW Range - S/c F/s Gas
Maytag MGR5750ADA Range - S/c F/s Gas
Maytag MGR5750ADH Range - S/c F/s Gas
Maytag MGR5750ADQ Range - S/c F/s Gas
Maytag MGR5750ADW Range - S/c F/s Gas
Maytag MGR5750BDB Range - S/c F/s Gas
Maytag MGR5750BDQ Range - S/c F/s Gas
Maytag MGR5750BDW Range - S/c F/s Gas
Maytag MGR5751ADB Range - S/c F/s Gas
Maytag MGR5751ADQ Range - S/c F/s Gas
Maytag MGR5751ADS Range - S/c F/s Gas
Maytag MGR5751ADW Range - S/c F/s Gas
Maytag MGR5751BDB Range - S/c F/s Gas
Maytag MGR5751BDQ Range - S/c F/s Gas
Maytag MGR5751BDS Range - S/c F/s Gas
Maytag MGR5751BDW Range - S/c F/s Gas
Maytag MGR5752ADB Range - S/c F/s Gas
Maytag MGR5752ADQ Range - S/c F/s Gas
Maytag MGR5752ADS Range - S/c F/s Gas
Maytag MGR5752ADW Range - S/c F/s Gas
Maytag MGR5752BDB Range - S/c F/s Gas
Maytag MGR5752BDQ Range - S/c F/s Gas
Maytag MGR5752BDS Range - S/c F/s Gas
Maytag MGR5752BDW Range - S/c F/s Gas
Maytag MGR5754QDQ Range - S/c F/s Gas
Maytag MGR5754QDS Range - S/c F/s Gas
Maytag MGR5754QDW Range - S/c F/s Gas
Maytag MGR5755ADB Range - S/c F/s Gas
Maytag MGR5755ADQ Range - S/c F/s Gas
Maytag MGR5755ADW Range - S/c F/s Gas
Maytag MGR5755BDB Range - S/c F/s Gas
Maytag MGR5755BDQ Range - S/c F/s Gas
Maytag MGR5755BDW Range - S/c F/s Gas
Maytag MGR5755QDB Range - S/c F/s Gas
Maytag MGR5755QDQ Range - S/c F/s Gas
Maytag MGR5755QDS Range - S/c F/s Gas
Maytag MGR5755QDW Range - S/c F/s Gas
Maytag MGR5765QDB Range - S/c F/s Gas
Maytag MGR5765QDQ Range - S/c F/s Gas
Maytag MGR5765QDS Range - S/c F/s Gas
Maytag MGR5765QDW Range - S/c F/s Gas
Maytag MGR5770ADA Range - S/c F/s Gas
Maytag MGR5770ADB Range - S/c F/s Gas
Maytag MGR5770ADQ Range - S/c F/s Gas
Maytag MGR5770ADW Range - S/c F/s Gas
Maytag MGR5770BDB Range - S/c F/s Gas
Maytag MGR5770BDQ Range - S/c F/s Gas
  #2 (permalink)
Old 08-09-2011, 11:58 AM
Junior Member
Thumbs up Thank you so much!!
Dear Joe,
Thank you for coming through so fast! Somehow my original message was ignored and then the customer service rep, yesterday, put me through a repeat circle of one of the many hours of research I had previously done and did not even address why my original post got overlooked. Made me never want to use this site again. It was my idea to repost my question and I am glad that I did. You came through! And also redeemed this site.
[Perhaps the rep did bring it to your attention, and if he did I thank him. I do wish he had listened better to me, though. ]
It is so refreshing to get the answer I need. I appreciate you understanding the problem, recognizing the work I had already done, and finding a solution. Yay, Joe!! I'm going to order the parts now!
Thank you, thank you, thank you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Door Hinge Discontinued Part #316007005 clevelandohio1111 Oven Repair (including Ranges and Cooktops) 0 09-10-2009 09:34 AM
Replacement part for discontinued part #9741559 James F Morin Dishwasher Repair 2 06-03-2009 12:06 PM
Door seal part #843 glenewilliams Dishwasher Repair 1 05-21-2009 06:57 PM
door spring part discontinued jaklassie Dishwasher Repair 1 05-05-2009 04:21 PM
Need discontinued part for Jenn-Air range. Part #74002173 Clock component Sandi Gainey Oven Repair (including Ranges and Cooktops) 0 03-25-2009 05:33 PM
